On 4/25/2007 6:08:03 PM, "Blueskies" wrote:
What is the airspeed at 2000 fpm? How long can you fly in the red arc : and not exceed V-dive without breaking the airplane? Theoretically, in : smooth air, forever. I have been able to get over 2000 fpm and without going into yellow or red in my Bonanza V35 with gear down, RPMs back to around 2100, and MP back to 15 inches. The trick in the Bonanza is to slow it up first while level (RPM and throttle back, drop gear), then begin the descent. -- Peter |
Peter R. wrote: On 4/25/2007 6:08:03 PM, "Blueskies" wrote: What is the airspeed at 2000 fpm? How long can you fly in the red arc : and not exceed V-dive without breaking the airplane? Theoretically, in : smooth air, forever. I have been able to get over 2000 fpm and without going into yellow or red in my Bonanza V35 with gear down, RPMs back to around 2100, and MP back to 15 inches. The trick in the Bonanza is to slow it up first while level (RPM and throttle back, drop gear), then begin the descent. Me too. I can peg the VSI and never get near the yellow line in my S35. |
"Peter R." wrote in message ... : On 4/25/2007 6:08:03 PM, "Blueskies" wrote: : : What is the airspeed at 2000 fpm? How long can you fly in the red arc : : and not exceed V-dive without breaking the airplane? Theoretically, in : : smooth air, forever. : : I have been able to get over 2000 fpm and without going into yellow or red in : my Bonanza V35 with gear down, RPMs back to around 2100, and MP back to 15 : inches. The trick in the Bonanza is to slow it up first while level (RPM and : throttle back, drop gear), then begin the descent. : : -- : Peter That is a bad quote, not what I said above... |
"john smith" wrote in message ... In article , "Matt Barrow" wrote: Second - get the plane on the ground PRONTO, but where I want it, not where a draggy, gear down configuration might put me in a worse spot than I already am. One of the things the POH does say, is that the fast way to get down is to extend the gear and full flaps. Does it specify with the engine running? If you've got an engine fire, that option _maybe_ out. When you are taking advantage of the turbocharger to go higher, getting down from over 10,000 to lower altitudes while you're on fire becomes urgent. Agreed. With the gear down, however, you've narrowed your options. Over the midwest, it's not likely a problem. Over rougher terrain it's a different story. Maybe I'm just used to flying over rough terrain, so I'm averse to dropping the gear until I'm "good n' ready". I've never measured, but I wonder how much a side slip would help dump altitude. |
"Matt Barrow" wrote With the gear down, however, you've narrowed your options. Over the midwest, it's not likely a problem. Over rougher terrain it's a different story. Maybe I'm just used to flying over rough terrain, so I'm averse to dropping the gear until I'm "good n' ready". How about the option to put the gear back up, after the majority of the altitude has been lost, and a landing site has been chosen that dictates the gear up decision? -- Jim in NC |
On Apr 26, 2:37 pm, "Morgans" wrote:
"Matt Barrow" wrote With the gear down, however, you've narrowed your options. Over the midwest, How about the option to put the gear back up, after the majority of the altitude has been lost, and a landing site has been chosen that dictates the gear up decision? -- Jim in NC Jim, this is exactly how the airline guys are taught. The emergency decent is done with the gear down in most situations. I would imagine that the POH in most GA planes states something similar. |
On Wed, 25 Apr 2007 12:15:08 -0400, john smith
wrote: Once-upon-a-time I allegedly was asked to bid an insurance job on a Turbo Arrow IV. The airplane involved was on it's way to the East Coast to cross the big pond. Was cruising around 10,000 ft msl over a local rural county airport with a 4200 ft runway (750 ft msl) when a fitting failed on top of the turbo. The fitting had apparently been added to tee an hourmeter oil pressure switch into the oil pressure supply line to the turbo. If I remember correctly, this supply line is also tee'd to the oil pressure gage in the cabin. When the fire erupted, the pilot secured the engine (fuel selector prop mixture mags master), dropped the flaps and gear, and descended in a slipping circular pattern to the field, and landed/rolled out on the runway. Being a single-engine constant-speed NON-feathering propeller, the engine continued to windmill, the engine-driven oil pump emptied the engine sump oil though the failed fitting, feeding the fire. The first thing that I noted when examining the 'plane was that the bracket that the extend retract cylinder mounts to on the bottom of the firewall/belly angle was only attached by a small portion of the firewall. the belly skin behind it was burnt/virtually gone. The bracket was rotated down/forward approximately 60 degrees from it's "normal" position. Damage forward of the firewall was localized "below" and "aft" of the broken fitting. I do not recall the firewall being perforated, but the upholstery material/insulation blanket on the cabin side of the firewalll showed signs of some serious heat. The belly skin was rippled from the firewall to where the fuselage bottom "breaks" upward to the empennage, between the center hat sections that run longitudinally on the belly. The belly skin was perforated immediately behind the firewall, but only (only??!!) had a couple of small holes in it. The carpet/tunnel trim down the center of the cabin had evidence of overheating, and several burnt spots. As I recall, the bottom cowling was heat-damaged, but the only place the fire exited the cowling was out the center nose gear opening. IMHO, the pilot did exactly the right thing. I would "dirty-up" the airplane with whatever I could hang out in the breeze so I could descend at the highest rate. Have never experimented with time to descend dirty vs. clean, but I do know that it takes f-o-r-e-v-e-r to come back down clean after doing a turbo critical altitude check. Have also allegedly burned a couple of brush piles, and there ain't nuthin that burns quite like an old tire... Long story short, haven't been there done that, but I've seen it done. TC One of the aircraft I fly is a 1982 Piper Turbo Arrow IV. Nowhere in the POH does it mention the emergency procedure for a turbocharger failure resulting in an oil fed fire in the engine compartment. Do you drop the gear or leave it up? My thinking is to drop it to keep the nose gear tire from being consumed as additional fuel and to move more air through the engine compartment while in a dive/steep descent to blow out a fire Anyone with actual experience? |
john smith wrote: One of the aircraft I fly is a 1982 Piper Turbo Arrow IV. Nowhere in the POH does it mention the emergency procedure for a turbocharger failure resulting in an oil fed fire in the engine compartment. Do you drop the gear or leave it up? It seems like the first question you have to answer is "how would you tell that was the failure?" If you can't answer that, then the question is the same as "what do you do if you have an engine fire?" Having said that, I guess if you *knew* that an oil leak was feeding the fire, you'd have to decide whether shutting down the engine would stop it or not. Mike Beede |
Mike Beede wrote:
It seems like the first question you have to answer is "how would you tell that was the failure?" If you can't answer that, then the question is the same as "what do you do if you have an engine fire?" When a turbocharger fails , the manifold pressure drops to what it would be for a normally aspirated engine. |
| Thread Tools | |
| Display Modes | |
