Your opinion on this landing
Old May 13th 07, 04:00 PM posted to rec.aviation.piloting
mike regish
Default Your opinion on this landing
They pull those wings up at the tips, no?
mike
"Matt Whiting" wrote in message
I've seen a few videos of airliner wings stressed to failure and when they
fail it looks like a small explosion with debris flying everywhere, but
much of that is the test apparatus flying around. The failure occurred at
a point. It simply isn't possible to design a wing perfectly enough or,
harder yet, assemble it uniformly enough to get a distributed failure.
Matt
Old May 13th 07, 04:08 PM posted to rec.aviation.piloting
Jose
No. Not in the test I saw. They pull up at various points along the
wing, simulating normal wing loading.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old May 13th 07, 06:11 PM posted to rec.aviation.piloting
Maxwell
"Jose" wrote in message
t...
This might be the test you recall Jose. I would have to agree it was hardly
a pin-point failure, and certainly not at the root. Seems to be a pretty
good example of a well designed wing.
http://youtube.com/watch?v=6Uo0C01Fwb8
Old May 13th 07, 06:54 PM posted to rec.aviation.piloting
Robert M. Gary
Jose
God doesn't play with dice, his dice just have a lot more sides than
Einstein understood.
-Robert
Old May 13th 07, 08:52 PM posted to rec.aviation.piloting
Jose
No, this wasn't it. What I recall (IIRC) was in German - maybe it was
an Airbus wing. There were three views, I thought I had them on my hard
drive but alas, I don't.
Nonetheless, this one is similar in that the failure happened all at
once, all over.
Jose
Old May 13th 07, 11:40 PM posted to rec.aviation.piloting
Matt Whiting
Jose wrote:
The failure occurred at a point. It simply isn't possible to design a
Well, yes, but at the time of failure, the rest of the wing (in the test
I saw) was stresesed very close to =its= breaking point, so once it let
go wherever it did, the other points also let go.
Not likely with an aluminum structure. The failure will quickly lessen
the stress on the remaining structure and it will not self-destruct.
I'm still waiting to see the video of this self-destructing wing. I'm
betting it is urban legend, but if there's proof I'd love to see it.
Matt
Old May 13th 07, 11:48 PM posted to rec.aviation.piloting
Matt Whiting
hardly a pin-point failure, and certainly not at the root. Seems to be
a pretty good example of a well designed wing.
once, all over.
Jose
You need glasses and a hearing aid. At about the 3:27 point the wing is
clearly shown with a kink at one point and the narrator says that the
other wing failed at the same LOCATION (not locations) but wasn't
visible. Sure, some of the skin flew off above the failure point, but
the entire wing didn't even come close to a uniform failure.
Matt
Old May 14th 07, 12:16 AM posted to rec.aviation.piloting
Morgans[_2_]
the stress on the remaining structure and it will not self-destruct. I'm
still waiting to see the video of this self-destructing wing. I'm betting
I remember seeing a show on the making of the 777, and it was in a giant
wing testing rig, and it failed as was predicted at some certain spar
number, but a bunch of the rest blew apart too, since when the one place
failed. all of the stress was transferred to many other locations.
That type of failure is the only way I can see it all failing at the same
time, too.
The odds of the whole wing failing at once is......Astronomical!
  #29
Old May 14th 07, 12:41 AM posted to rec.aviation.piloting
Maxwell
other wing failed at the same LOCATION (not locations) but wasn't visible.
Sure, some of the skin flew off above the failure point, but the entire
It clearly didn't fail at a single location, and certainly not the root like
you predicted, your trollyness.
Go away, you are starting to sound like MX in drag.
  #30
Old May 14th 07, 12:48 AM posted to rec.aviation.piloting
Jose
I'm still waiting to see the video of this self-destructing wing. I'm betting it is urban legend,
IT is not an urban legend. I have seen it.
Well, it's not an urban legend unless I'm also an urban legend.
Jose
lowrance 500 opinion d&tm Piloting 2 March 17th 07 06:57 AM
Your opinion about helmets? Dave Russell Aerobatics 8 March 13th 04 02:32 PM
Opinion on the lowrance airmap 500 Pascal Duchemin Products 4 February 24th 04 09:26 PM
Opinion on club share Paul Folbrecht Owning 10 January 8th 04 05:17 AM
Opinion on this please Frederick Wilson Home Built 11 December 24th 03 06:01 PM
