#21
"Kev" wrote in message oups.com... On May 14, 7:43 pm, Bob Noel wrote: Didn't the B-25 guys bombing Japan fly low too? I think they were actually afraid of hitting fishing boats if they went that low. The most famous ground effect demo has to be that of the Hughes' Spruce Goose "takeoff" in harbor. Least famous, but more important, were the use of ground effect by some of the US Navy NC flying boats to make the first transatlantic crossing in 1919 by airplane. Cheers, Kev I believe the mission was designed to go in low to avoid being seen by defending fighters. Also, the bomb runs were briefed low to insure specific target destruction. This led to the low altitude decision that afforded the both of these two worlds. Dudley Henriques |
"Blanche" wrote in message ... Can you have "ground effect" over water? Yes, if you are low enough. |
"Dudley Henriques" wrote in message ... There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Don't you have to be within half the wing span to benefit much from ground effect? |
"Maxwell" wrote in message ... "Dudley Henriques" wrote in message ... There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Don't you have to be within half the wing span to benefit much from ground effect? Ground effect can be considered generally or more accurately for a specific aircraft. GENERALLY speaking, you can begin to consider ground effect a factor about a wingspan's distance above the surface. Dudley Henriques |
Dudley Henriques wrote:
"Blanche" wrote in message ... On 5/14/2007 2:03:24 AM, "Bravo Two Zero" wrote: A small plane crashed into Lake Pleasant, just outside of Phoenix, at approx 8pm Friday, while the pilot was reportedly talking on his cellphone and flying 10 feet above the water. Can you have "ground effect" over water? There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Dudley Henriques Maybe a true story but I think the the odds are they would have been much better off at high altitude. As I understand it, induced drag is only reduced by 10% at 50% of wing span above surface. At 20% of wing span altitude the drag is still ~70% (Surface skimming birds actually go lower, nearly touching the water with their wing tips). Of course if the Stratocourser dropped to say 10' it could have worked better... -kersplash! Cheers MarkC |
"Dudley Henriques" wrote in message ... "Paul Tomblin" wrote in message ... In a previous article, "Dudley Henriques" said: There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Sounds like an Ernie Gann story. You know, I think you might be right. It might very well have been from Fate is the Hunter; but I think I remember seeing it in some magazine as well years ago. Wouldn't your MPG be better at altitude? |
"Bravo Two Zero" wrote: A small plane crashed into Lake Pleasant, just outside of Phoenix, at approx 8pm Friday, while the pilot was reportedly talking on his cellphone and flying 10 feet above the water. According to thr FAA, the pilot was talking on a cellphone to a friend in a boat below and asked the friend to shine a flashlight in the air to signal the boat's location. If he is dead, he may qualify for a Darwin Award. |
"Matt Barrow" wrote Wouldn't your MPG be better at altitude? Considering the great reduction of induced drag while in ground effect, it would depend on the engine, I would think. RPM's would have to be reduced until the power output of the engine is down below 55% or thereabouts, and it would have to be leaned aggressively. Why don't we get someone to do an extended run along the surface of the ocean, and then do the same test at altitude, and report back. It would be interesting, I think! g -- Jim in NC |
#29
"DR" wrote in message ... Dudley Henriques wrote: "Blanche" wrote in message ... On 5/14/2007 2:03:24 AM, "Bravo Two Zero" wrote: A small plane crashed into Lake Pleasant, just outside of Phoenix, at approx 8pm Friday, while the pilot was reportedly talking on his cellphone and flying 10 feet above the water. Can you have "ground effect" over water? There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Dudley Henriques Maybe a true story but I think the the odds are they would have been much better off at high altitude. As I understand it, induced drag is only reduced by 10% at 50% of wing span above surface. At 20% of wing span altitude the drag is still ~70% (Surface skimming birds actually go lower, nearly touching the water with their wing tips). Of course if the Stratocourser dropped to say 10' it could have worked better... -kersplash! Cheers MarkC If I remember right, nobody reporting on the incident reflected on what they might have done, only on what they actually did. They very well might have optimized range at altitude. I can't remember the specifics involved. Knowing the exact circumstances would make it a lot more clear for those interested in making a judgment on the incident I would imagine. Dudley Henriques |
#30
"Matt Barrow" wrote in message ... "Dudley Henriques" wrote in message ... "Paul Tomblin" wrote in message ... In a previous article, "Dudley Henriques" said: There's a great story about the crew of a Pan Am Stratocruiser I think it was, who were low on fuel and a long way out over the ocean. They let down to within a wingspan's distance over the water, leaned it back a ton, played with the RPM, and made it home. Can't remember the source of the story, but I do remember reading it a long time ago. Sounds like an Ernie Gann story. You know, I think you might be right. It might very well have been from Fate is the Hunter; but I think I remember seeing it in some magazine as well years ago. Wouldn't your MPG be better at altitude? A lot would depend on what you had to expend in resources to get up there from where you were when the decision had to be made . Not sure at all what the circumstances were in this incident. Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Karl Treier | Aviation Marketplace | 3 | December 18th 04 12:37 AM |
| Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Aardvark J. Bandersnatch, MP | Naval Aviation | 2 | December 18th 04 12:37 AM |
| Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Aardvark J. Bandersnatch, MP | General Aviation | 2 | December 18th 04 12:37 AM |
| Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Karl Treier | Naval Aviation | 0 | November 7th 04 08:17 PM |
