Fuel Prices For The July Pilgrimage
Old May 25th 07, 12:27 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
Matt Whiting
Default Fuel Prices For The July Pilgrimage
Rich S. wrote:
I have since corrected the design deficiencies but I can't do anything about
the weather (no matter what ALgore says). One thing I can do is be very
careful as to when and where I burn mogas. I will not buy it from a source
which is unknown to me. This lets out every strange airport. I will not use
mogas on hot days nor at high altitudes.
Why is mogas from an unknown source worse than avgas from an unknown source?
Matt
Old May 25th 07, 05:50 PM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
Rich S.[_1_]
"Matt Whiting" wrote in message
source?
Although I cannot cite a reference, it has always been my belief that Avgas
is subject to tighter inspection procedures from the refinery to the
customer. Also, I think that Mogas is blended more specifically for seasonal
use. If the FBO is not selling a large quantity (compared to the size of his
tank) you may get Mogas that is several months old. This means it could be
blended inappropriately for the season - or simply be just old gas with less
volatiles and/or water from condensation.
Rich S.
Old May 25th 07, 01:04 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
M[_1_]
On May 24, 11:44 am, "Rich S."
We left home and flew to Pullman in eastern Washington for the first fillup.
When we were passing 25 mi. north of Helena, MT, the engine quit - vapor
locked. Contributing factors were the high temperature (85 F @ 9500'), the
(I suspect) old mogas I bought in Pullman, and my fuel system design, having
the electric pump forward of the firewall and no forward-facing air scoops
on the tank vents.
What model of the plane is this?
Old May 25th 07, 06:02 PM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
Rich S.[_1_]
"M" wrote in message
CP-323a Emeraude, although the fuel system was of my own design and
construction. I have added a blast tube to cool the electric fuel pump and
an air scoop on the vents to pressurize the fuel tanks.
http://temp.corvetteforum.net/c4/elwood89//harvey5.jpg
Rich S.
Old May 25th 07, 07:53 PM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
Montblack
("Rich S." wrote)
Nice pic
Montblack
Old May 26th 07, 04:33 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.homebuilt
Tim Hickey
I have a Zenith CH-300 with an O-320. I had a similar problem in the
beginning. I did as you have done, plus insulated the fuel lines,
installed a small heat reflective shield over the gascolater, and ran
a blast tube down to the mechanical fuel pump. Since then (about 1990)
I have run over 9000 gallons of mogas through the machine with out
problem. Although I will always let the engine (and the fuel pump that
is bolted to the case) cool between flights. If I know that I will be
doing flights without allowing a cool down period, I will put 100LL in
one tank, and take off on it.
On Fri, 25 May 2007 09:02:46 -0700, "Rich S."
roups.com...
Rich S.
Zenith CH-300 Driver.
Fuel Prices For The July Pilgrimage RST Engineering Piloting 46 June 15th 07 11:45 PM
Fuel Prices For The July Pilgrimage RST Engineering Owning 46 June 15th 07 11:45 PM
Fuel Prices Ross Richardson Owning 60 September 30th 05 03:06 AM
Fuel Prices ~R Rotorcraft 0 September 10th 05 04:56 PM
Fuel Prices S Green Piloting 0 May 9th 04 10:47 PM
