![]() Did the Imperial Japanese Army Air Force and the Imperial Japanese Navy Air Force operate any of the same make of aircraft? As a rule, no. The requirements were quite different up to 1941, when they sudden moved closer together. (That's why the Nakjima Ki-43 Hayabusa was suddenly yanked off the shelf and put into service: the army was told that it required a 500-mile-range fighter for the Malaya invasion.) I think both services operated Japan-built DC-2s and 3s, but even here I think of the Douglases as navy planes. The army used a Japan-built Lockheed Super Electra for dropping paratroops, and used bombers for heavy cargo. Army planes had French throttles: you pulled the throttle toward you for full power; the navy followed English-American style. So it would take some retraining before a pilot could fly an airplane from the other service. Army and navy radios couldn't communicate with one another. An army machine-gun bullet wouldn't fit a navy machine gun nominally of the same caliber. They made the famously contentious U.S. army and navy look like models of interservice cooperation. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
I am surprised no-one mentioned the Ki-100 (Dinah) - used by both
services although in small numbers, and also the Ki-49 Hiryu (Peggy), used by both. Unless my memory is hideously deformed.... -- G Hassenpflug * IJN & JMSDF equipment/history fan |
![]() On Mon, 28 Jul 2003, Gernot Hassenpflug wrote: I am surprised no-one mentioned the Ki-100 (Dinah) - used by both services although in small numbers, The Ki.100 was NOT the "Dinah" - the "Dinah" was the Ki.46 and the Ki.100 never received an allied code name although the Ki.100 was a radial-engined development of the Ki.61 "Tony" Neither the Ki.46, the Ki.61, or the Ki.100 was ever operated by IJNAF units however. They were all IJAAF aircraft. and also the Ki-49 Hiryu (Peggy), used by both. Unless my memory is hideously deformed.... The Ki.49 had the allied code name "Helen". And was used exclusively by IJAAF units. The "Peggy" was the Ki.67 which -was- used in small numbers under the designation "Yakakuhi" by the IJNAF. So far as I can tell, all the aircraft operated by the IJNAF were transfers from the IJAAF and none were purpose-built for the IJNAF Cheers and all, |
![]() "Gernot Hassenpflug" wrote in message ... I am surprised no-one mentioned the Ki-100 (Dinah) - used by both services although in small numbers, and also the Ki-49 Hiryu (Peggy), used by both. Unless my memory is hideously deformed.... -- G Hassenpflug * IJN & JMSDF equipment/history fan It is The Ki-100 was a Ki-61-II with a 1500 hp Mitsubishi Ha-112-II radial engine and was definitely an army aircraft The Ki-46 Dinah was also an army aircraft as was the Ki-49 Helen The Ki-67 Peggy was designed for the Japanese air force but was used by the IJN albeit in small numbers, first being used by them in the attacks against the US 3rd fleet off Formosa in late 1944. Keith |
Cub Driver wrote in message . ..
An army machine-gun bullet wouldn't fit a navy machine gun nominally of the same caliber. There was just one exception; both services used the licence-built German 7.92mm MG 15 flexible gun (although they used different designations...). What is even more suprising is the lack of standardisation WITHIN each service. I put a photo in 'Flying Guns: WW2' showing all of the different aircraft ammo of up to 20mm which they used in service; the IJN used five different calibres, the IJA used six, and the only common element was the 7.92x57. There were also three different 30mm, three different 37mm... Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Military gun and ammunition discussion forum: http://forums.delphiforums.com/autogun/messages/ |
![]() Well, there was the Zero for one. The A6M Zero wasn't in service with the Japanese army air force. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
A small number of the Army's Type 4 Heavy Bomber 'Hiryu' was used by
the Navy under the name 'Yasukuni'. http://www.wwiitech.net/main/japan/aircraft/ki-67/ http://www.214th.com/ww2/japan/ki-67/ (JDupre5762) wrote in message ... Did the Imperial Japanese Army Air Force and the Imperial Japanese Navy Air Force operate any of the same make of aircraft? It seems to me that that at least with some combat aircraft the two services might have economically ordered from the same production lines and saved some money and opened up some factories for producing more of other types of aircraft? John Dupre' |
![]() A small number of the Army's Type 4 Heavy Bomber 'Hiryu' was used by the Navy under the name 'Yasukuni'. That's the equivalent of naming an aircraft Arlington National Cemetery! Not a very cheerful prospect for the crew. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
Wasn't it suicidal anyway?
A big, fat bomber with an underslung torpedo flying a steady course... An excellent target for AA fire in late 1944. Cub Driver wrote in message . .. A small number of the Army's Type 4 Heavy Bomber 'Hiryu' was used by the Navy under the name 'Yasukuni'. That's the equivalent of naming an aircraft Arlington National Cemetery! Not a very cheerful prospect for the crew. all the best -- Dan Ford email: www.danford.net/letters.htm#9 see the Warbird's Forum at http://www.danford.net/index.htm Vietnam | Flying Tigers | Pacific War | Brewster Buffalo | Piper Cub |
Cub Driver writes:
A small number of the Army's Type 4 Heavy Bomber 'Hiryu' was used by the Navy under the name 'Yasukuni'. That's the equivalent of naming an aircraft Arlington National Cemetery! Not a very cheerful prospect for the crew. I don't know, Yasukuni is a well-established name in Japanese history and shinto, and the fact that one shrine is famous in its association does not give it the same connotations as the ANC (which for me, as a South African, has other associations too!). Yasukuni basically means peaceful country, and it is a noble name. Japanese people nowadays might associate Yasukuni-jinja with war criminals, but just yasukuni is often found in literature, and in religious and historical texts. -- G Hassenpflug * IJN & JMSDF equipment/history fan |
WTD: ANC Manual (Army Navy Civil) for Air Traffic Control | [email protected] | Aviation Marketplace | 0 | October 20th 04 04:06 AM |
WTB: ANC Manual (Army Navy Civil) air traffic~1950's?(correctedpost) | [email protected] | Aviation Marketplace | 0 | February 27th 04 08:13 AM |
WTB: ANC Manual (Army Navy Civil) Air Traffic Control - 1950's? | [email protected] | Aviation Marketplace | 0 | February 25th 04 07:03 AM |
Army Aircraft Operator Manuals | TJ | Aviation Marketplace | 0 | January 13th 04 03:45 AM |
FS Books USAF, Navy, Marine pilots and planes | Ken Insch | Military Aviation | 0 | July 20th 03 02:36 AM |
