Air Compressor Horsepower/Wattage/Amperage
Old June 18th 07, 09:49 PM posted to rec.aviation.homebuilt,rec.aviation.owning
RST Engineering
Default Air Compressor Horsepower/Wattage/Amperage
I thought I had this compressor power thing down to a pretty good science
until they started screwing around with "rated watts" and "peak power" and
all that crap that makes their compressor look really good until you go to
use it.
Back when we were using "real" horsepower I used a figure of 750 (to make it
easy to calculate, I believe 746 is the actual number) watts per horsepower
and an efficiency factor of 85% so that a one horse motor would take 860
watts to do the actual work.
But then you multiplied that times two for "starting" wattage for a couple
of seconds to give 1725 watts under start and then times three for starting
under some volume of air left in the compressor reservoir or about 2600
watts.
That presses my 2200 watt continuous duty (2800 watts peak) fairly close to
the load limit, but certainly gives a margin for error that seems
reasonable.
Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight
Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even
worse, buy the Sears compressor only to not have it work), will somebody
please do a reality check on me for horsepower/watts for this lashup.
(Note ... convert watts to amperes by dividing watts by 120 volts).
860w=7a 1725w=14a 2600w=21a
Sears and Harbor Freight are damned near clueless about this sort of stuff.
If anybody has a source I can reference for running/starting/starting under
load for air compressors it would be well received.
I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4
horse toy straight to one horse with darned little in between.
"Dream as if you'll live forever. Live as if you'll die today."
--James Dean
Old June 18th 07, 10:53 PM posted to rec.aviation.homebuilt,rec.aviation.owning
use it.
watts.
reasonable.
--James Dean
Have you ever noticed that in the horsepower place on the motor
dataplate it says something like "SPL"?
The motor mfg doesn't want to be complicit on the out right lying
done by the compressor mfgs, who never heard that 750 watts = 1 hp.
Charletons. BH
Old June 18th 07, 10:57 PM posted to rec.aviation.homebuilt,rec.aviation.owning
B A R R Y
On Mon, 18 Jun 2007 14:53:30 -0700, "
NOTHING beats Shop-Vac HP ratings.
6HP from a 15 amp 120v outlet! Awesome! G
Old June 18th 07, 11:58 PM posted to rec.aviation.homebuilt,rec.aviation.owning
cavelamb himself
Good golly, I hadn't noticed that before!
15 amps at 120 V is 1800 watts
Roughly 746 (100% efficiency) watts per HP
750 x 6 = 4476 watts
Less than 1/2 the claimed power!
I wonder if I could take it back and exchange it for
a REAL 6 hp vac???
Old June 19th 07, 12:02 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Peter Dohm
"B A R R Y" wrote in message
news
240% efficiency is very impressive--for a single phase motor!
The last time that I wandered through the tool department at Sears, I saw
what appeared to be the same compressor that I used to own. Mine could
manage about 2CFM at 40PSI, and claimed to be 2HP on the aforementioned 120V
circuit--IIRC with a continued draw of about 10A. The new ones were
claiming either 4 or 6 CFM, and I believe that the pressure may have been
higher as well, on the same electrical power. So the problem is not new,
but it is getting much worse.
Peter
(In the future, tools will be rated like sound systems.)
Old June 19th 07, 12:28 PM posted to rec.aviation.homebuilt,rec.aviation.owning
B A R R Y[_2_]
Let's hope the tradition doesn't extend to airplane power plants. G
Old June 20th 07, 02:16 AM posted to rec.aviation.homebuilt,rec.aviation.owning
kontiki
Oh don't worry, it will.
Old June 20th 07, 02:39 AM posted to rec.aviation.homebuilt,rec.aviation.owning
cavelamb himself
Well, there was the 150 horse Franklin.
And the 60 horse VW.
Old June 23rd 07, 11:07 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
starting under some volume of air left in the compressor reservoir or
about 2600 watts.
Most air compressors have a valve that lets off the air pressure in the line
between the pump and the tank, when they shut off.
You can tell if it has this feature, by seeing a little air line going to
the pressure on/off switch.
You may not need to multiply so big for starting with air in the tank.
Old June 24th 07, 12:20 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Ron Rosenfeld
On Mon, 18 Jun 2007 13:49:59 -0700, "RST Engineering"
use it.
watts.
reasonable.
Jim,
Living off-grid, and generating most of my own power from renewables, I am
somewhat familiar with your issue. Although your approach may make
theoretical sense, in the real world (as you found out) it frequently
doesn't work.
The startup surge for an electric motor is given by a parameter called
"locked rotor amps" (means pretty much what it says). This can either be
measured (with a clamp-on ammeter), or derived from a letter on the
nameplate of the actual motor multiplied by the running amps.
A compressor is one of the more difficult devices to start. Without
specific data, I would figure starting amps to be at least five times the
nameplate amperage rating. Fugedabout trying to convert nameplate HP to
startup surge. It might be less, or not.
So far as your generator is concerned, it is likely that the ratings assume
a power factor of 1. But an induction motor, such as is in your
compressor, will have a power factor considerably less than 1. This
further increases the amount of "real power" the generator must supply.
And may also explain why the nameplate amperage rating seems higher than
what you predict by using HP and an assumed efficiency.
I happen to have a Sears 1HP compressor (1.5HP Peak). Mine has a nameplate
rating of 10.5A @ 120V. I could not see/locate the nameplate on the motor
itself, so I figured a 52.5A startup surge (5X). My inverter has a 78A
peak capacity (46A continuous) so I figured things would work -- and they
have.
Your 2800W peak generator translates to 23.3A at 120VAC. If you have the
same Sears compressor as I do, I'm not surprised that the generator will
have a problem starting it.
Another issue that comes up with compressors has to do with flat spots on
the rotor as they age. This causes them to draw the locked rotor amp
startup current for a longer period of time when new. This can also cause
an otherwise adequately sized system to "blow" on startup, occasionally.
--ron
more horsepower T-Bone Piloting 11 March 20th 06 10:56 PM
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Thermals and Horsepower Ken Kochanski (KK) Soaring 14 January 9th 05 05:50 PM
Air Compressor for RV Builder John Bundy Home Built 5 March 27th 04 01:47 PM
Horsepower Andre Home Built 3 July 18th 03 10:50 AM
