#21
The engine and disk are well behind the pilot; I would be more concerned about the tail rotor driveshaft...
-- Dan D. .. "Badwater Bill" wrote in message ... On Wed, 20 Aug 2003 21:03:59 -0700, "Jim" wrote: Bill, seventy turbines have been shipped to the customers of Helicycle just last week. They are modified by BJ just for the Helicycle. It is the standard engine now. Jim Damn. I didn't know that. The guy above gave me the link to see it. Great! I love it. I'll tell you what happened to me here. I sort of knew that BJ Schram was working with the Solar turbine from talking with Ric Stitt. In fact maybe Ric even told me that BJ was doing what you said above. I got confused because TEAM (Tennessee Engineering and Manufacturing) who built the MINIMAX had an airplane that rang a bell in my head like that helicycle that BJ is screwing with. I thought someone had put a turbine on one of those ultralight airplanes of TEAM's. They had something they called the Aerial cycle or something like that about 10 years ago, but I can't remember what the exact name was. So, I was corn-fused a bit about it, thinking it was on an airplane. Let me ask you guys who know about this a question. What if the Solar detonates or starts coming apart. Is there appropriate shielding around the turbine to protect the pilot? BWB |
Two Brits died in a Benson gyroglider -- about the safest thing
in the air. Well, nobody put in the bolts that hold the rotorhead bearing together. It had a press fit that held up for a few flights, then the GD rotor came off. And that is in the simplest rotorcraft ever built, a machine with exactly two moving parts. 4 moving parts without the bolts. |
![]() Kevin O'Brien wrote: I have some concerns about the Solar turbine exploding They don't seem to do this in the Boeing-Vertol helicopters that they are the APU in, particularly the CH-47. Boeing-Vertol helicopters and the CH-47 don't run an APU 45% over their rated duty cycle. They also contain the APU within a housing area that will contain the shrapnel. may not be enough protection around the turbine vanes to protect the pilot. the pilot's arse is not inline with the vanes. Of course, if they shred the structure it doesn't really matter because his arse is headed for a reckoning with terra firma. The pilots "arse" is 2 foot away from the APU. A Claymore mine explodes in all directions, sending shrapnel "mostly" one direction. So dose an APU. How many pieces of shrapnel sent the pilot's way is acceptable? But that don't matter at all. As I said to Dennis Chitwood: "But worse than anything, due to the high rpm of an APU, the compressor and blades are under a great deal of centrifugal force. If you have ever seen an APU explode, you will never forget it. APU's are only used inside an aircraft where it is encased in an explosion proof housing, so that when it explodes it will contain most of the blast, which goes out sideways in every direction, not out the tail pipe like that idiot Joe Rinke and Rick Stitt says. Therefore, when an APU on a Mini-500 (or any other helicopter) explodes, and it will someday if it is used long enough to fail, it will immediately cut off the tail boom causing the helicopter to tumble end over end falling to the ground and taking the pilot all the way down, probably alive while knowing a horrible death is seconds away." Also, Solar, themselves will probably do what they can to help B.J. in making it more reliable and more safe. This, I doubt. 1) Lawyers. (need I say more?). 2) the market can't afford new Solars, only surplus ones. Surplus availability hinges on a shrinking military, or one that is growing so fast that it can replace equipment with new marks. I don't think either is in the cards, given the world situation and the budgetary one. You are absolutely correct there. They wouldn't touch you guys with a 10 foot pole! If you can't keep a proven 2 stroke running, you sure as heck can't handle an APU. They are just so complex and so much can go wrong\ Often experienced people get killed because they don't have the RIGHT experience. think of the Mini -- some of those guys were very high time in fixed wing. I know Allen was your friend, but Bill, do you think if he had all those hours in low-inertia Robbies that he would have tried to go over that wire? Instead his time was almost all in high-inertia Bells... they would have forgiven him, the Mini, which put him in that position in the first place with its bad design, had no forgiveness in it. That's not correct. Allen loved his Mini-500, and enjoyed flying it over anything else, and said it had great characteristics. He stood up in front of groups of people and said that. Also, the Mini-500 has a high inertia blade system. It demonstrated hovering auto's as high as 15 feet routinely at air shows in front of thousands of people. Furthermore, the Mini-500 was not at fault at all in Allen's death. Allen failed to install the correct jet's the flight before, and seized the engine, recovering with a perfect Auto rotation. He called me and asked what to do. I said overhaul the engine, he decided not to. The next flight he took off and "he" decided to fly low over the power line. As that point the engine failed again due to the damage it sustained from the flight before. He milked as much inertia from the system as he could, but couldn't span the great distance. I don't believe there was a helicopter built that could have gone that far. As for the Mini-500 being a bad design, then why has there never been a crash due to the fault of the Mini-500? Sure, you can spew your propaganda, but the facts speak for themselves. Dennis Fetters |
![]() I in no way meant to compare the Rotorway and the Mini. My statement was that new Helicopter pilots especially those that don't even have their helicopter rating yet have NO business being helicopter test pilots and I stand by that statement. All of the kit manufacturers have it in their power to do things to stop the extremely low time pilots. It would be in their best interest to do so. "Blueskies" wrote in message gy.com... There is no comparison between the Rotorways and the Mini500. The Rotorway is pretty mature and is well engineered, and the I think everyone knows the story of the Mini. Rotorway grew beyond the management capabilities of Scram (IMHO), so he is now developing this Helicycle. I've got to say the one I saw flying was one smooth running machine... -- Dan D. . "Gig Giacona" wrote in message ... "pac plyer" wrote in message om... (Badwater Bill) wrote snip good stuff In the end, personally speaking...my life is not worth 1 second in an experimental helicopter. I will never fly in one or test fly one again, no matter who approves it. I even worry all the time in the Robinsons. They are just so complex and so much can go wrong, if you survive a few thousand hours, you've done real well. I think, if you screw with any of them long enough (from jet rangers, to MD-500's and especially experimentals), you'll get bit. BWB Man am I glad you're the one that said this, because that's exactly how I feel. Got friends who fly these things and it worries me. My friend Kirk is breaking in a beautiful Rotoway that he sunk 60K into. It's stunning. Looks like a million dollars. But this maiden experimental flight was on his solo signoff (he did have a lot of factory instruction.) Scared the **** out of all of us. I talked to him and think I convinced him to break it in slowly, don't do aggressive turns against the asphalt etc, at least for a while. Now his op looks a little more conservative. But there are other worries. Every 50 hours he has to lash the valves! At 1500 hrs he has to THROW away the entire airframe. Can that be right? Man! I was thinking of building one, but not any more. pacplyer nervous fixed-wing pilot This brings up an excellent point. I have done zero research on the issue but pacplyer's story is hardly the first I've heard of Rotoways and Mini-500s that first flights were done by very low time pilots including those that have just been signed off for solo. I got my PP R-H in '96 after 17 years and 300 hours of fixed wing time and there is no way in hell I was ready to be the test pilot in a newly built helicopter. Helicopters are hard to fly. Much harder than fixed wing than just about any fixed wing aircraft. I have little doubt that if not most at least many of the accidents with armature built experimental helicopters are because the builders had not a bit of business being helicopter test pilots. |
The way I hear it, the Helicycle folks will not sell a kit until the purchaser has demonstrated solo flight in an R22...
-- Dan D. .. "Gig Giacona" wrote in message ... I in no way meant to compare the Rotorway and the Mini. My statement was that new Helicopter pilots especially those that don't even have their helicopter rating yet have NO business being helicopter test pilots and I stand by that statement. All of the kit manufacturers have it in their power to do things to stop the extremely low time pilots. It would be in their best interest to do so. "Blueskies" wrote in message gy.com... There is no comparison between the Rotorways and the Mini500. The Rotorway is pretty mature and is well engineered, and the I think everyone knows the story of the Mini. Rotorway grew beyond the management capabilities of Scram (IMHO), so he is now developing this Helicycle. I've got to say the one I saw flying was one smooth running machine... -- Dan D. . "Gig Giacona" wrote in message ... "pac plyer" wrote in message om... (Badwater Bill) wrote snip good stuff In the end, personally speaking...my life is not worth 1 second in an experimental helicopter. I will never fly in one or test fly one again, no matter who approves it. I even worry all the time in the Robinsons. They are just so complex and so much can go wrong, if you survive a few thousand hours, you've done real well. I think, if you screw with any of them long enough (from jet rangers, to MD-500's and especially experimentals), you'll get bit. BWB Man am I glad you're the one that said this, because that's exactly how I feel. Got friends who fly these things and it worries me. My friend Kirk is breaking in a beautiful Rotoway that he sunk 60K into. It's stunning. Looks like a million dollars. But this maiden experimental flight was on his solo signoff (he did have a lot of factory instruction.) Scared the **** out of all of us. I talked to him and think I convinced him to break it in slowly, don't do aggressive turns against the asphalt etc, at least for a while. Now his op looks a little more conservative. But there are other worries. Every 50 hours he has to lash the valves! At 1500 hrs he has to THROW away the entire airframe. Can that be right? Man! I was thinking of building one, but not any more. pacplyer nervous fixed-wing pilot This brings up an excellent point. I have done zero research on the issue but pacplyer's story is hardly the first I've heard of Rotoways and Mini-500s that first flights were done by very low time pilots including those that have just been signed off for solo. I got my PP R-H in '96 after 17 years and 300 hours of fixed wing time and there is no way in hell I was ready to be the test pilot in a newly built helicopter. Helicopters are hard to fly. Much harder than fixed wing than just about any fixed wing aircraft. I have little doubt that if not most at least many of the accidents with armature built experimental helicopters are because the builders had not a bit of business being helicopter test pilots. |
On Mon, 25 Aug 2003 13:46:44 -0500, "Gig Giacona"
wrote: When I was able to demonstrate Solo flight in an R-22 I was not ready to be a helicopter test pilot. I probably still aren't. Yeah, no ****. I'm a commercial helicopter pilot who flies all the time with about 600 hours logged now and about 2000 hours in government helicopters that isn't logged. I'm not qualified to be a test pilot in some experimental piece of crap...and never will be. I have to hand it to the people who build these things then think they can test fly them to work out the bugs of blade tracking and balancing and the sympathetic resonances between all the moving parts. More power to them. They are brave men. I'm not so brave. I flew R-22's 8 hours this weekend and an R-44 for about 4 hours around thunderstorms here in the Southwest. I was real happy to think that I had a proven machine around me. Even then, some-one of a thousand parts could have failed and that would have been the end. BWB |
Just a comment on the worship of "Certified parts" I have a switch panel
containing Potter&Bromfields "certified" switch/circuit breakers. Two have failed from internal mechanical (not electrical) failings. I've got a couple of other switches that I added (mine's a homebuilt so I don't have to just use "certified" parts) that have served for years without problem. Note these were Radio Shack at approx. 1/8 the cost and so far 10 times the reliability. Other stories of failed "certified" engines come to mind. 0320-H series for one. I agree that "Certification" should buy some reliability over non certified parts, but there is no real guarantee. BTW I self taught in a Benson Gyrocopter in the 60's (no dual was available) So did my wife. We never bent anything or scratched a blade. The ship is as safe as the pilot is proficient and aware of the limits. Stu Fields "Badwater Bill" wrote in message ... True. If you have to fly rotary-wing, a gyro is simpler. However there have been an absolutely amazing panoply of fatals in those. Most of them totally preventable. It's mostly due to the tucking since the center of thrust is above the CG and the drag component of the rotor system is way above the CG. When you do a negative g pushover or even hit a bump that does the same thing, you take away the drag. The thrust dumps you over in a tuck. Someone (Gig Giacona?) mentioned the low-timers pranging in Minis. Well, that instantiates a much more general case. How many prangs happen on first flights? Many, many, many. There are a bunch of reasons for this... my personal belief is that if you are the builder, mechanic and test pilot, not enough people are eyeballing the flying machine, and you're gonna overlook something. Yep. Right on. I deleted your comments about Allen Barklage, but I wanted to respond. The Mini-500 has a higher inertia rotorsystem than the R-22 as I recall. Allen loved flying that Mini-500 and his weight was good for it too IIRC. You can blame fetters about a lot of stuff but Allen, of all people, should have known about clearing the wires and the capability of that machine. Gil Armbruster called me the night before he died. We talked about the problems of warming up the engine before you pulled pitch. Gil told me he had pulled pitch and saw the tempertature drop as the thermostat opened. He knew that he hadn't warmed the thing up all the way. Rotax said if you do that you probably scuff the bottom of the piston since it expands into a water cooled (constant diameter) cylinder wall. Once you do that you get aluminum all over the bottom end of the cylinder and you are setting yourself up for a complete seizure. I old Gil that the night before he died. But Gil went out and flew over trees the next day. Why would he do that? Why would Allen fly over wires when he's had some problems with his engine just prior to the thing killing him. Not me. You wouldn't have caught me in these without tearing them down to inspect them. I think there were/are lots of problems with the parts on the Mini-500 as I've said for years. They wear out too soon. They are not like the Robinson helicopter parts that are proven over and over to 2000 hours or 10 million cycles. But, with that in mind, why would anyone fly an Exec 162 over wires or over trees when they are made out of the same NON-helicopter, NON-certified components? I don't get it. I've killfiled fetters long ago, but someone will tell him of this thread an I'm sure that he will have his 2 cents to say too. BWB |
![]() I agree that "Certification" should buy some reliability over non certified parts, but there is no real guarantee. BTW I self taught in a Benson Gyrocopter in the 60's (no dual was available) So did my wife. We never bent anything or scratched a blade. The ship is as safe as the pilot is proficient and aware of the limits. Man, you got that right. Keep your head and do it with baby steps and the probability is that you'll make it. I fly my gyro all the time and it's a Snobird pusher with the thrust line well above the CG. I just keep my hand on the throttle and tell myself "Power is destablizing...get the throttle off if she bucks on you." I ain't dead yet, but that doesn't mean that it won't kill me if I do something stupid. BWB Stu Fields "Badwater Bill" wrote in message .. . |
#30
... (snip) I ain't dead yet, but that doesn't mean that it won't kill me if I do something stupid. BWB, I'm glad you think the R-22 is a safer rotary wing aircraft than some others. But today's FAA accident summary, with 14 entries, included two for the R-22, one fatal and the other merely serious injury. ;-( |
turbo video | Peter Holm | Aerobatics | 13 | September 29th 04 11:31 PM |
