On Sun, 08 Jul 2007 13:10:44 GMT, Matt Whiting
wrote: The problem is that many northeast airports are very busy and have long taxi times. I've spent 30 minutes on the taxiway at Philly, Washington National (pre 9/11 obviously), and Boston. On a 95 F day, this is extremely unpleasant, even with the windows open (one nice 182 advantage). Philly, Wash, Boston? No need to go there! I've spent 30 minutes on the ground at Martha's Vineyard, New Bedford, and Danbury. |
Yeah the TO delays are a problem-trapped in a swealtering cockpit is
no fun. Thanks for all the opinions. Andy |
![]() wrote in message ups.com... Yeah the TO delays are a problem-trapped in a swealtering cockpit is no fun. Thanks for all the opinions. What kind of airplane are you looking to put A/C in? (Cher 260?) New, or retro-fit? Even if you need it, your equipment _might_ not be able to handle it. |
![]() "B A R R Y" wrote in message ... On Sun, 08 Jul 2007 13:10:44 GMT, Matt Whiting wrote: The problem is that many northeast airports are very busy and have long taxi times. I've spent 30 minutes on the taxiway at Philly, Washington National (pre 9/11 obviously), and Boston. On a 95 F day, this is extremely unpleasant, even with the windows open (one nice 182 advantage). Philly, Wash, Boston? No need to go there! I've spent 30 minutes on the ground at Martha's Vineyard, New Bedford, and Danbury. Try 20 minutes waiting on the ground in Altus, OK :~( |
Matt Barrow wrote:
"B A R R Y" wrote in message ... On Sun, 08 Jul 2007 13:10:44 GMT, Matt Whiting wrote: The problem is that many northeast airports are very busy and have long taxi times. I've spent 30 minutes on the taxiway at Philly, Washington National (pre 9/11 obviously), and Boston. On a 95 F day, this is extremely unpleasant, even with the windows open (one nice 182 advantage). Philly, Wash, Boston? No need to go there! I've spent 30 minutes on the ground at Martha's Vineyard, New Bedford, and Danbury. Try 20 minutes waiting on the ground in Altus, OK :~( I'm sure that is no fun. The worst I had was about 20 minutes at Detroit several years ago in the midst of one of their worst heat waves ever. It was 102 according to the radio station, but on the ramp my OAT was nearly pegged. And it was humid to boot. It wasn't even all that cool at 7,000 on the way home! I'd have given up a lot of useful load for AC that day... Matt |
B A R R Y wrote:
On Sun, 08 Jul 2007 13:10:44 GMT, Matt Whiting wrote: The problem is that many northeast airports are very busy and have long taxi times. I've spent 30 minutes on the taxiway at Philly, Washington National (pre 9/11 obviously), and Boston. On a 95 F day, this is extremely unpleasant, even with the windows open (one nice 182 advantage). Philly, Wash, Boston? No need to go there! I've spent 30 minutes on the ground at Martha's Vineyard, New Bedford, and Danbury. Probably waiting on a slot from ZBW! :-) Matt |
![]() Anybody have any experience with air conditioning in their plane-Nice to have? Silly accessory? Don't leave home without it? 80% Summer flying in Northeast. Thanks for your opinion. Andy As others have stated, you cannot use if for takeoff. So, you use it on the ground and then turn it on again in the climb. 4 minutes into the climb, you are usually into cooler air anyway and shut it off. Google A/C and see the persistent problems with these units. They are R-12 systems in most planes. If you think it is expensive to get a car charged with R-12, wait till you see what it will cost to get an A&P to do it - if you can find one. Likely you will have to talk an auto tech into bringing his equipment out to the airport for the A&P to watch him charge the system. Then, you get to pay 2 folks for one operation. R-134? Many techs will not do a conversion because they can screw up some systems irreparably. Even though many have converted Pipers, the local auto tech has no experience and likely will not want to "experiment" with a very expensive airplane. The hoses are now 20-30+ years old. They leaked like crazy when new and have not gotten any better with age. If an auto tech charges the plane, they will likely give you the speech about how they are required to investigate why the system needed a charge and fix it. Or, they may refuse to charge it at all UNTIL the leak is found and fixed. As others have said, they rob you of 70 odd pounds in the Pipers. For a 140 that is 10% of its useful load and precludes any thoughts of a third person. The alternator belts and pulleys are the biggest pain. After 1000 hours, the pulleys wear due to the high tension required on the skinny alternator belt. Once worn, you can throw belts in as little as 2 hours. Ironically, the compressor belt usually never breaks. Which would you choose to go South unpredictably? We removed ours and got back 43 pounds. We left the drop door and condenser in because of the hassle of removing it. The cost to "convert" back to stock can be staggering and the parts are NOT easy to identify and find. Opinions vary, but in many Midwest/Northern parts of the country, it is not worth the hassle. Good Luck, Mike |
On Jul 8, 6:41 am, Mike Spera wrote:
They are R-12 systems in most planes...R-134? Many techs will not do a conversion because they can screw up some systems irreparably. Even though many have converted Pipers, the local auto tech has no experience and likely will not want to "experiment" with a very expensive airplane... Mike I can't imagine that converting an R-12 system to R-134 wouldn't require an STC. |
150flivver wrote:
On Jul 8, 6:41 am, Mike Spera wrote: They are R-12 systems in most planes...R-134? Many techs will not do a conversion because they can screw up some systems irreparably. Even though many have converted Pipers, the local auto tech has no experience and likely will not want to "experiment" with a very expensive airplane... Mike I can't imagine that converting an R-12 system to R-134 wouldn't require an STC. I was not heading in that direction. My thought was that some R-12 systems contained some funky oil that turned to glue when R-134 oil hit it. Hence, some auto guys will not do a "conversion" and risk getting into a huge beef if the system gets all gummed up. I would imagine that those same auto wrenches would also balk at going to the local airport to "try out" converting a Piper from 12 to 134. I would never suggest that a conversion would require and STC. But, some FAA critter might. Good Luck, Mike |
I don't know if it is an stc thing, but there are conversions available.
It has always been far cheaper to stick with r12 in my seneca. I seem to remembe being told is was about 6k to convert. John 150flivver wrote: On Jul 8, 6:41 am, Mike Spera wrote: They are R-12 systems in most planes...R-134? Many techs will not do a conversion because they can screw up some systems irreparably. Even though many have converted Pipers, the local auto tech has no experience and likely will not want to "experiment" with a very expensive airplane... Mike I can't imagine that converting an R-12 system to R-134 wouldn't require an STC. |
Silly L/D stats | Andy[_1_] | Soaring | 1 | April 9th 07 05:14 AM |
Silly controller | Robert M. Gary | Instrument Flight Rules | 123 | August 30th 06 01:56 AM |
Saab 340 air conditioning? | John Clonts | Piloting | 1 | July 14th 06 05:00 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
Air Conditioning System for Homebuilts? | JPAviation | Home Built | 18 | February 6th 04 03:24 AM |
