Air Traffic/Pilot Terminology
Old July 23rd 07, 08:24 AM posted to rec.aviation.piloting
Thomas Borchert
Default Air Traffic/Pilot Terminology
Tom,
Both FAA links below are obsolete.
Hmm. They work just fine.
Thomas Borchert (EDDH)
Old July 23rd 07, 09:48 AM posted to rec.aviation.piloting
Tom L.
On Mon, 23 Jul 2007 09:24:54 +0200, Thomas Borchert
Tom,
Interestingly, I get this for both links:
Page Not Found
Sorry, but the page you have requested has moved or no longer exists.
Please use the links provided below to find the resource you were
looking for:
Home
* FAA Home
and if I enter only the first part of the links
(http://www.faa.gov/atpubs) I get forwarded to
http://www.faa.gov/airports_airtraff.../publications/
Mysterious....
Old July 23rd 07, 12:06 PM posted to rec.aviation.piloting
Thomas Borchert
Tom,
Hmm. Weird! I copied them from the displayed publication right before I
posted. They don't work now. So thanks for correcting.
Old July 23rd 07, 06:28 PM posted to rec.aviation.piloting
On Jul 23, 11:34 am, Andrew Gideon wrote:
On Sun, 22 Jul 2007 19:19:05 -0700, wrote:
It said there were over a 150 options. I was
wondering if you could recommend a few.
To what type of traffic do you want to listen? A busy commercial airport?
A busy general aviation airport? A sector of airspace (perhaps near some
airport)? Something else?
- Andrew
I'm not sure. I'm new to this. I guess a commercial airport? i'm
looking for something that has a lot of tranmissions and activity and
possibly something interesting going on.
Old July 23rd 07, 07:47 PM posted to rec.aviation.piloting
Peter R.
On 7/22/2007 10:19:03 PM, " wrote:
I didn't miss your post. It said there were over a 150 options. I was
wondering if you could recommend a few. Or are they all the same.
Ah, sorry for the misinterpretation. I thought my link didn't make it
through.
The feeds on LiveATC.net are a total blend of activity, from the busiest
class B airport (JFK, Boston Logan, BWI, etc) to the smaller, slower class D
airport (very small towered airports), and from center feeds (typically
higher altitude, en-route portions) to HF (Atlantic ocean crossing routes).
Perhaps the most entertaining ATC feed on LiveATC.net that draws the most
listeners every day is the JFK (John F Kennedy airport, New York City) ground
feed, whereby you can listen to the organized chaos of controllers directing
lots of aircraft from the gates to the runways and visa versa. With a
combination of NYC controller attitude to pilots who cannot understand the
complex taxi instructions, there are always tense or humorous moments.
http://audio.liveatc.net:8012/kjfk_del_gnd.m3u
However, if you desire the complex air coordination, Boston Approach or any
of the New York approaches, at:
http://audio.liveatc.net:8012/kbos_final.m3u
or
http://audio.liveatc.net:8012/kjfk_app_final.m3u
These are especially interesting when a strong line of thunderstorms is about
to move into the area. Check your favorite weather radar site, then hop over
to LiveATC.net and pick a feed for an airport about to be overrun by
thunderstorms.
I volunteer the Syracuse, NY, feed. Syracuse is a class C (moderately busy
mid-sized airport) in upstate NY. This feed blends approach with tower to
provide a more complete picture of the first or last 15 minutes of a flight.
This feed is he
http://audio.liveatc.net:8012/ksyr.m3u
Peter
Old July 23rd 07, 09:17 PM posted to rec.aviation.piloting
GeorgeC[_2_]
In his first post he ask what BUGSY. BUGSY is Malone-Dufort Airport at Malone,
NY and later he ask what heavy was. My guess is he's near Montreal.
- Andrew
GeorgeC
  #30
Old July 24th 07, 01:36 AM posted to rec.aviation.piloting
James Sleeman
On Jul 23, 1:57 pm, " wrote:
What exactly is
a squawk and what is it's function?
Aircraft (in general) have a device called a "transponder" which is a
little device that basically tells the air traffic controllers who the
aircraft is (and typically these days, how high it is).
To cut a long story (which you can find on Wikipedia -
http://en.wikipedia.org/wiki/Transponder_(aviation) ) short, each
aircraft is assigned a code which the pilot enters into the
transponder, and this code is broadcast to air traffic control to
identify the aircraft. This code is called the "squawk" code.
There are also some standard squawk codes, one used "by default" for
VFR flight, one for if the aircraft gets hijacked (if the pilot can
enter the code without the hijackers noticing), another for general
emergencies etc...
VFR terminology in Class B Matt Piloting 17 February 27th 07 03:55 PM
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Traffic 2004 vs Ultimate Traffic Tlewis95 Simulators 3 August 13th 04 05:39 AM
New Aviation Terminology DeltaDeltaDelta Piloting 45 December 4th 03 08:31 AM
Humour: CO DATA PAGE TERMINOLOGY CAT:BTN SUB:DES PGE:TRM Dave Kearton Military Aviation 0 September 24th 03 10:38 AM
