Boeing Flies Blended Wing Body Research Aircraft
Old July 26th 07, 06:27 PM posted to rec.aviation.piloting
Larry Dighera
Default Boeing Flies Blended Wing Body Research Aircraft
The Boeing Company http://www.boeing.com/news/releases/index.html
CHICAGO, July 26, 2007 -- The innovative Boeing [NYSE: BA] Blended
Wing Body (BWB) research aircraft -- designated the X-48B -- flew for
the first time last week at NASA's Dryden Flight Research Center at
Edwards Air Force Base in California.
The 21-foot wingspan, 500-pound unmanned test vehicle took off for the
first time at 8:42 a.m. Pacific Daylight Time on July 20 and climbed
to an altitude of 7,500 feet before landing 31 minutes later.
"We've successfully passed another milestone in our work to explore
and validate the structural, aerodynamic and operational efficiencies
of the BWB concept," said Bob Liebeck, BWB program manager for Boeing
Phantom Works, the company's advanced R&D unit. "We already have begun
to compare actual flight-test data with the data generated earlier by
our computer models and in the wind tunnel."
The X-48B flight test vehicle was developed by Boeing Phantom Works in
cooperation with NASA and the U.S. Air Force Research Laboratory to
gather detailed information about the stability and flight-control
characteristics of the BWB design, especially during takeoffs and
landings. Up to 25 flights are planned to gather data in these
low-speed flight regimes. Following completion of low-speed flight
testing, the X-48B likely will be used to test the BWB's low-noise
characteristics, as well as BWB handling characteristics at transonic
speeds.
Two X-48B research vehicles have been built. The vehicle that flew on
July 20 is Ship 2, which also was used for ground and taxi testing.
Ship 1, a duplicate of Ship 2, completed extensive wind tunnel testing
in 2006 at the Old Dominion University NASA Langley Full-Scale Tunnel
in Virginia. Ship 1 will be available for use as a backup during the
flight test program.
Three turbojet engines enable the composite-skinned research vehicle
to fly up to 10,000 feet and 120 knots in its low-speed configuration.
Modifications would need to be made to the vehicle to enable it to fly
at higher speeds. The unmanned aircraft is remotely piloted from a
ground control station in which the pilot uses conventional aircraft
controls and instrumentation while looking at a monitor fed by a
forward-looking camera on the aircraft.
The Boeing BWB design resembles a flying wing, but differs in that the
wing blends smoothly into a wide, flat, tailless fuselage. This
fuselage blending helps to get additional lift with less drag compared
to a circular fuselage. This translates to reduced fuel use at cruise
conditions. And because the engines mount high on the back of the
aircraft, there is less noise inside and on the ground when it is in
flight.
"While Boeing constantly explores and applies innovative technologies
to enhance its current and next-generation products, the X-48B is a
good example of how Boeing also looks much farther into the future at
revolutionary concepts that promise even greater breakthroughs in
flight," said Bob Krieger, Boeing chief technology officer and
president of Phantom Works.
While a commercial passenger application for the BWB concept is not in
Boeing's current 20-year market outlook, the Advanced Systems
organization of Boeing Integrated Defense Systems' (IDS) is closely
monitoring the research based on the BWB's potential as a flexible,
long-range, high-capacity military aircraft.
"The BWB concept holds tremendous promise for the future of military
aviation as a multi-purpose military platform in 15 to 20 years," said
Darryl Davis, Boeing IDS Advanced Systems vice president and general
manager of Advanced Precision Engagement and Mobility Systems. "Its
unique design attributes will result in less fuel burn and a greatly
reduced noise footprint, which are important capabilities to offer our
Air Force and mobility customers."
NASA's participation in the project is focused on fundamental,
edge-of-the-envelope flight dynamics and structural concepts of the
BWB. Along with hosting the X-48B flight test and research
activities, NASA Dryden provided engineering and technical support --
expertise garnered from years of operating cutting-edge unmanned air
vehicles.
The two X-48B research vehicles were built by Cranfield Aerospace
Ltd., in the United Kingdom, in accordance with Boeing requirements.
Old July 26th 07, 08:38 PM posted to rec.aviation.piloting
Dallas
Photo of the test model:
http://www.nasa.gov/images/content/1..._boeing_hi.jpg
Dallas
Old July 27th 07, 12:29 AM posted to rec.aviation.piloting
Morgans[_2_]
"Dallas" wrote in message
I want one, just like that!
It sure would make a dandy remote control model !!!
Really though, it is interesting. I did not know they were still working on the
concept.
I would fly in one, if you put a viewscreen in front of my seat, linked with
cameras outside to choose from. That is what I had heard they said would be the
arrangement.
Old July 27th 07, 02:48 AM posted to rec.aviation.piloting
Phil
concept.
arrangement.
I think Boeing would be really smart to pursue this technology. It
will lead to airliners that are much more efficient than the current
layout. If Boeing doesn't do it, you can bet that Airbus or Embraer,
or eventually maybe even the Chinese aircraft manufacturers will.
And I think for the generation growing up today on video games and
computer screens, having a view screen instead of a window won't be a
hardship.
Old July 27th 07, 03:09 AM posted to rec.aviation.piloting
Morgans[_2_]
hardship.
Plus, think of the views that you would never get to see, even with a window
seat. Most of the time, I end up getting a window seat right above the wing,
anyway. Can't see much from there!
A view, as you are looking out the cockpit when landing would be pretty cool, I
think.
Plus you could see the scenery without all of those nose and forehead prints on
the windows, and you would not have to try and look through all of those
scratched up Plexiglas windows.
Yep, give me a viewscreen, with the choice of what camera I want to use.
Old July 27th 07, 01:59 PM posted to rec.aviation.piloting
Neil Gould
Recently, Morgans posted:
hardship.
window seat. Most of the time, I end up getting a window seat right
above the wing, anyway. Can't see much from there!
pretty cool, I think.
prints on the windows, and you would not have to try and look through
all of those scratched up Plexiglas windows.
use.
A little reality check... Most likely, one would get to choose which dirty
camera lens to "best" view the scenery.
Neil
Old July 28th 07, 04:07 PM posted to rec.aviation.piloting
Matt Whiting
concept.
arrangement.
hardship.
That may be true, but my understanding is that all market survey work
done to date has shown consumers to soundly reject an airplane without
windows. However, maybe future generations will have a different view
as you say.
Matt
Old July 28th 07, 04:53 PM posted to rec.aviation.piloting
Morgans[_2_]
"Matt Whiting" wrote
That may be true, but my understanding is that all market survey work done
to date has shown consumers to soundly reject an airplane without windows.
However, maybe future generations will have a different view as you say.
If the airline could offer you a ticket reduced 25% in price, that same
market survey would suddenly find that the people really like having no
windows. g
Money talks, BS walks, as the saying goes.
Old July 28th 07, 05:16 PM posted to rec.aviation.piloting
Roy Smith
as you say.
Is there enough of a cargo market to make a cargo-only design?
I know I'm being just a little absurd here, but imagine if you came up with
a design which was so much more efficient than the current fleet that it
could capture 100% of the cargo market over the next 10 years. Could you
make that fly with no pax sales?
Old August 3rd 07, 04:04 AM posted to rec.aviation.piloting
Phil
On Jul 29, 7:51 pm, Richard Riley wrote:
On Thu, 26 Jul 2007 18:48:30 -0700, Phil
hardship.
It's actually left over from Douglas.
One big reason it hasn't gone as passenger liner is what the people
outboard would experience (plus and minus Gs) as the plane banks.
It could be banked more slowly to mitigate that, especially if it had
fly-by-wire controls. And people experience those same feelings now
in turbulence anyway. I suspect that if you were to offer people a
more roomy plane with a lower ticket price, you would get lots of
takers. I hate flying stuffed in like a sardine in a can. A blended
body aircraft could have more room for passengers. Imagine if an
airline started flying an airplane with twice as much legroom, more
aisles, and wider seats. Maybe even seats that really recline. And
at a lower cost. Let's say 5 or 10 percent lower. I bet they would
fill those planes on most flights. Wouldn't you be willing to pay
less to get more?
Boeing 777 wide-body aircraft set an endurance record for a non-stop commercial flight Larry Dighera Piloting 8 November 14th 05 09:12 PM
Boeing to decide on wide-body 747 by mid-year -CEO NewsBOT Simulators 0 February 18th 05 09:46 PM
Roll Stability in lifting body and flying wing aircraft Fred the Red Shirt Home Built 2 December 3rd 04 10:24 PM
Design merit of blended wing aircraft Rob Mohr General Aviation 0 June 13th 04 02:45 PM
Blended wing bodies and sailplanes...? Robert Bates Soaring 8 December 23rd 03 09:34 PM
