Replacement for C130?
Old September 29th 03, 05:25 AM
Tex Houston
"Hobo" wrote in message
"Tex Houston" wrote:
Granted, these are the stretched
version, CC-130J, but are part of the planned or delivered total of 168
C-130J/CC-130J.
What is the weight capacity of the stretched version? How does it
compare to the new Airbus plane?
Sorry, you will have to do your own research. I suggest "Air Force
Magazine" May 2003 and www.google.com .
Example:
http://www.fas.org/man/dod-101/sys/ac/c-130.htm
http://www.af.mil/news/factsheets/C_130_Hercules.html
http://www.airforce-technology.com/projects/hercules/
Airbus Military is at:
http://www.airbusmilitary.com/home.html
but I know very little about them and I figure the chance of the USAF buying
the Airbus 400M as a C-130 replacement is nil.
Tex Houston
Old September 29th 03, 05:32 AM
David Bromage
C-130J/CC-130J.
From official documentation of both companies.
C-130J C-130J-30 A400M
MTOW 69,750kg 74,393kg 110,850kg
Max payload 17,373kg 21,690kg 25,000kg
Range @ max payload 2729nm 2517nm 1700nm
Speed 356kts 356kts 300kts
Unit cost (US$) ~$48m ~$55m ~$80m
Cheers
David
Old September 29th 03, 05:48 AM
Darrell A. Larose
David Bromage ) writes:
C-130J/CC-130J.
Cheers
David
So the Airbus will be bought by many air forces as carries 15% more
payload. Has 60% of the range, is 16% slower and costs 45% more.
Old September 29th 03, 08:11 PM
Oryx
"David Bromage" wrote in message
C-130J/CC-130J.
Cheers
David
There's a mistake in the speeds you listed. The values quoted for the C-130J
and C-130J-30 are KTAS (knots, True Air Speed). The 300 kts published by
Airbus is, and they are very specific about that, CAS (calibrated air
speed). The values for the C-130's are, to be more specific, TAS at 22,000
feet. In comparison, an A400 doing 300 KCAS at 22,000 feet would be flying
approximately 425 KTAS, considerably faster than the C-130J. Even more, the
design cruise altitude for the A400 is 29,000 ft, at which 300 KCAS would be
approximately 480 KTAS. The cruise Mach number for the C-130J is listed as
Mach 0.59, while that of the Airbus is 0.68 - 0.72.
Also, Airbus quotes 37,000 kg as max payload. With this payload they indeed
claim 1700nm range. However, for a similar payload to the max payload of the
C130 (20,000 kg), the range of the A400 is listed as 3550 nm.
KX170B/175B replacement knobs Lane_Pilot Aviation Marketplace 0 April 25th 04 08:50 PM
Magneto/comm interference on TKM MX-R Narco 120 replacement Eugene Wendland Home Built 5 January 13th 04 03:17 PM
piston connecting rod bolt replacement Dick Home Built 5 October 7th 03 03:34 PM
Narco MK 16 replacement SoulReaver714 Aviation Marketplace 1 September 23rd 03 05:38 PM
Hellfire Replacement Eric Moore Military Aviation 6 July 2nd 03 03:22 AM
