Towing glider trailers with a VW Jetta Wagon?
Old August 24th 07, 01:20 PM posted to rec.aviation.soaring
chipsoars
Default Towing glider trailers with a VW Jetta Wagon?
On Aug 24, 7:59 am, Dan G wrote:
On Aug 24, 1:15 am, Eric Greenwell wrote:
A caravan is quite different creature than a glider trailer, so I'd
hesitate to accept their values without knowing more.
Did the 7% figure
apply to single axle trailers towed with standard hitches, meaning no
dampeners or load distributing hitches?
Yes - single axle, no dampers. You really shouldn't need one.
Can you give me a link to the document you are quoting from?
The original work from Bath University was published in the Caravan
Club's magazine "En Route" in 1994. They still publish the resulting
guidelines though - there's a limited amount he
http://preview.tinyurl.com/y8uqrk
The full details are in the member's handbook.
Dan
I have seen some information published (US) stating that the hitch
tongue weight should be in the 10-15% range for a conventional (not
5th wheel hitch).
I found an excellent guide from Sherline, a scale manufacturer:
http://www.sherline.com/lmbook.htm
and from CA DMV:
http://www.dmv.ca.gov/pubs/dl648/dl648pt12.htm
Both use the 10-15% hitch weight.
eTrailer.com sells hitches and uses the same hitch load factor.
Also important is the vehicle loading. The weight on the hitch does
impact vehicle load and it is important to have the entire rig as
level as possible.
Chip F.
Led lights for glider trailers Mal[_4_] Soaring 11 July 12th 07 12:06 AM
Glider Towing Available - Payson AZ (& local) [email protected] Soaring 0 June 5th 07 10:20 PM
Welcom Wagon at Air Venture Tom Wait Home Built 1 May 5th 06 03:00 AM
Pic trailers culverflyer Soaring 1 May 5th 04 01:37 AM
Glider trailer towing Jeff Landfield Soaring 0 July 21st 03 04:25 AM
