			#21
			 "B2431" wrote in message ... From: "Bill Silvey" "B2431" wrote in message From: "Gord Beaman" ( "Tarver Engineering" wrote: snip Especially when describing what a Pitot tube is and what it does. ;-) You mean the kind of pitot tube that produces two pressures to make IAS? The same kind Henri Pitot used to measure water flow? That would not be the kind the lunes of ram believe in. John this is getting tiresome... -- -Gord. Gord, give up on tarver, now he thinks pitot tubes PRODUCE pressure. Not only that they produce TWO pressures. The poor man is beyond help. Dan, U. S. Air Force Moreover, he thinks they produce two pressures and produce airspeed as well. The man's beyond hope, he is. -- It is obvious he thinks a pitot tube produces pitot and static pressures Yes Dan, you pathetic moron, that is what a pitot tube does.  |
			 "B2431" wrote in message ... From: Jim Thomas Date: 10/7/2003 8:22 PM Central Daylight Time Message-id: . net Actually, flight-test nose booms pick up both Pitot (dynamic) and static pressure. I'll bet the one on the X-1 did, too. Jim Thomas I bet the X-1 had a pitot-static tube No, the X-1 had a pitot tube, friggin' moron.  |
			 "Ed Rasimus" wrote in message ... On 08 Oct 2003 05:26:31 GMT, (B2431) wrote: From: Jim Thomas Date: 10/7/2003 8:22 PM Central Daylight Time Message-id: . net Actually, flight-test nose booms pick up both Pitot (dynamic) and static pressure. I'll bet the one on the X-1 did, too. Jim Thomas I bet the X-1 had a pitot-static tube witch detects pitot and static pressure. In fact he said "pitot tube" which only detects pitot pressure. There really is a difference between a pitot and a pitot-static tube. Then tarver came along and said a pitot tube "produces" pressure. Neither a pitot tube nor a pitot static tube produces pressure, they simply sense them. First, during the period of the X-1, and for many years thereafter, the common practice was for the pitot tube to provide dynamic pressure Pitot port, a pitot tube is Henri pitot's invention and it provides both static and dynamic pressure. Don't get too involved in Dan's mental illness, Ed.  |
Ed Rasimus  wrote:
	[snipped for brevity] Third, the much earlier assertions that pitot tubes were somehow relevant only to jet engine powered aircraft is absurd. Conventional (i.e. piston-driven) aircraft has just as much of a requirement for measurement of pitot pressure. And, even sailplanes, with no engine at all, use a pitot tube for airspeed indication. Yep, we even have 'em on our trikes. Of course, they're not the complicated (and more accurate) flush type "Y" static systems with vents on the fuselage as you described, however, they're reasonably accurate for our purposes (e.g: low & slow in the 25-95 kt. range). For an ASI that uses a pitot tube to measure the difference between ram pressure and static pressure, all you need is a pitot tube with it's opening facing straight into the oncoming air. We found that the size of the hole is not critical. Usually it's just a short length of 1/4-inch aluminum tubing that can be inserted into plastic tubing and routed to the fitting on the back of the instrument. For static pressure, we simply use the "static" fitting which is also on the back of the ASI guage itself, which can be left open as long as the instrument is protected from the airstream. Sometimes the forward edge of the pitot tube is rounded a bit to smooth the flow, but I doubt that it makes much difference at typical trike speeds. The main concern for getting accurate readings from a pitot tube airspeed indicator (as opposed to the even more simple but accurate "Hall" type ASI that looks like a rain guage) is locating the tube. It needs to face straight into the flow at cruising speed (which often means a downward angle when the craft is sitting on the ground) and it needs to be in "clean air" meaning as far forward as possible and not in the wake of any obstructions. For an altimeter, we don't need a pitot tube and just a "static" port is fine. Again, if the altimeter is in a pod (that's not hermetically sealed) there's usually no need to connect anything to that little brass fitting on the back of the altimeter in order to get a decent altitude reading. Poor Henri, he probably never would have believed what his invention has wrought on Usenet. I'm wondering if Henri would think this neverending, silly thread is as amusing and entertaining as I think it is.  |
			 Mike Marron wrote: [snipped for brevity] I'm wondering if Henri would think this neverending, silly thread is as amusing and entertaining as I think it is. Don't knock it. In this politically correct age Tarver presents one of the few remaining opportunities to bait the mentally impaired for entertainment. Dave  |
Dave Holford  wrote:
	Mike Marron wrote: [snipped for brevity] I'm wondering if Henri would think this neverending, silly thread is as amusing and entertaining as I think it is. Don't knock it. In this politically correct age Tarver presents one of the few remaining opportunities to bait the mentally impaired for entertainment. Very true, however, after one peek under the hood, the tarv fish was so incredibly stupid and ugly and stunk so badly that I quickly reached for my needlenose pliers, yanked the hook from his bleeding jaw and tossed the critter back in. Haven't gone tarv fishing since!  |
			#29
			 "Dave Holford" wrote in message ... Mike Marron wrote: [snipped for brevity] I'm wondering if Henri would think this neverending, silly thread is as amusing and entertaining as I think it is. Heni would wonder how you got so ignorant. Don't knock it. I have a wonderful time twisting up the idiots of ram. In this politically correct age Tarver presents one of the few remaining opportunities to bait the mentally impaired for entertainment. Yes and I enjoy my idiot catch and release program on usenet.  |
			#30
			 Pitot port, a pitot tube is Henri pitot's invention and it provides both static and dynamic pressure. Don't get too involved in Dan's mental illness, Ed. Tarver, time to put up or shut up. Cite one verifiable source, other than you, that defines, uses or decribes a "pitot port." It is evident you think a pitot tube without integral static ports is a "pitot port." Take a look at the pitot tube on a C-130, it has no integral static ports. The static ports are mounted on the sides of the fuselage. The C-130 tech orders call it a pitot tube. Now take a look at the pitot-static tube on the F-4E, all the relevent tech orders call it a pitot-static tube. If you want I can scan you a page from the 1F-4E-0-6. I make that offer to anyone who doubts me on this. I have tried various search engines to find "pitot port" and the only references ever returned point to you and no one else. I have worked with far more pitot and pitot static tubes than you have. How about explaining to us why Pitot needed to measure static pressure when he was measuring the velocity of water? Since water doesn't compress he didn't need to know static pressure for velocity. I bet you will now make a few rude comments having nothing to do with the subject as is your wont when asked to provide proof. Dan, U. S. Air Force, retired  |
| Thread Tools | |
| Display Modes | |
| Pitot tube prices | B2431 | Home Built | 2 | May 16th 04 09:13 PM |
| FS: 1985 (General Chuck) "Yeager" Autobiography 1st Edition Book | J.R. Sinclair | Aviation Marketplace | 0 | January 28th 04 06:38 AM |
| FS: 1985 (General Chuck) "Yeager" Autobiography 1st Edition Book | Jim Sinclair | Aviation Marketplace | 0 | October 23rd 03 07:10 AM |
| Aircrew casualities | ArtKramr | Military Aviation | 84 | October 15th 03 10:50 PM |
| FS: 1985 (General Chuck) "Yeager" Autobiography 1st Edition Book | Jim Sinclair | Aviation Marketplace | 0 | September 24th 03 05:50 AM |
