M wrote:
Another factor, which only has to do with economy, is that we pay for fuel in volume (gallons), not pounds. If Jet A and 100LL are both $4 per gallon, you get more pounds of jet A with that $4. These two factor combined, diesel powered Cessna would burn about 30% less $ worth of fuel per hour at the same power output, assuming JetA and 100LL cost the same per gallon. That's quite significant. These days it seems that Jet A is consistently less per gallon than 100LL. Its also true that the federal taxes on JETA is significantly higher than AVGAS, thus the price you actually pay is not a lot less than AVGAS. |
On Sat, 06 Oct 2007 01:41:50 GMT, "Vaughn Simon"
wrote in : "Larry Dighera" wrote in message news ![]() I like the idea that there is more energy per pound in Jet A fuel than AvGas, Whoa! There is more energy in Jet A per GALLON. Depending on which weight and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs per pound. Remember, Jet fuel is heavier than gasoline. Vaughn Okay. The point is, that there should be a commensurate increase in range. |
Larry Dighera wrote:
On Sat, 06 Oct 2007 01:41:50 GMT, "Vaughn Simon" wrote in : "Larry Dighera" wrote in message news ![]() I like the idea that there is more energy per pound in Jet A fuel than AvGas, Whoa! There is more energy in Jet A per GALLON. Depending on which weight and BTU averages you are using, Jet A and Avgas come out pretty close on BTUs per pound. Remember, Jet fuel is heavier than gasoline. Vaughn Okay. The point is, that there should be a commensurate increase in range. That depends. Most diesel engines weigh more than similar power gas engines. So, you may well have less fuel capacity to stay within weight limits. Matt |
I like the idea that there is more energy per pound in Jet A fuel than AvGas, but I have no idea of the failure modes nor expected TBO and other performance, operational, and maintenance issues. What should a pilot expect to find has changed in the Thielert engine equipped C-172 other than higher power available at altitude, increased range, and fewer refueling options? The lower fuel burn comes not from the higher energy of Jet-A, but rather from the higher compression ratio which converts a higher percentage of the energy to useful work. Diesel comes closer to an ideal Carnot cycle than gasoline. |
On Oct 6, 7:26 am, kontiki wrote:
wrote: The lower fuel burn comes not from the higher energy of Jet-A, but rather from the higher compression ratio which converts a higher percentage of the energy to useful work. Diesel comes closer to an ideal Carnot cycle than gasoline. How much better fuel economy and efficiency would result if modern internal combustion designs were made easily available to the GA fleet (versus diesel engines) ? These new diesel engines employ the latest of modern technology in terms of materials and design, where our old Lycomings and Continentals are basically 75 year old technology. Not a fair (or even logical) comparison IMHO. Turbo diesel auto engines get around 50mpg compared to equivalent gasoline engines that get around 30mpg. That's apples to apples for you. Diesel is more efficient. Higher compression buns more of the fuel and captures more of the thermal expansion in the form of mechanical piston energy. Basic physics. |
On Oct 6, 6:26 am, kontiki wrote:
How much better fuel economy and efficiency would result if modern internal combustion designs were made easily available to the GA fleet (versus diesel engines) ? These new diesel engines employ the latest of modern technology in terms of materials and design, where our old Lycomings and Continentals are basically 75 year old technology. Not a fair (or even logical) comparison IMHO. If you have seen the BSFC numbers of the latest and greatest automobile gasoline engines, they're really not better than a IO-520. Why? because it's a lot easier to optimize a gasoline engine for fuel efficiency when it's operated at a narrow RPM range with little power variation. Automobile engines achieve good fuel efficiency through electronic engine control only because it's much harder to gain good efficiency across a much wider RPM range and throttle setting. From a thermo efficiency point of view, the gasoline aircraft engines designed in the 50s are very good, if they're leaned properly (which can be easily done with good fuel injection and EGT instrumentation), I doubt they can get much better in fuel efficiency regardless of what electronic you put on them. Diesel engine has better BSFC because they have fundamentally better thermo efficiency, not because they have fancy electronics. |
"Larry Dighera" wrote in message ... CESSNA TO OFFER DIESEL SKYHAWK (http://www.avweb.com/eletter/archive...ll.html#196294) Cessna will offer the 172S Skyhawk with a Thielert turbo diesel engine with deliveries to start in mid-2008. In an announcement at AOPA Expo in Hartford, Conn., Cessna officials said the decision to offer the diesel came after extensive market surveys and flight testing. "The Skyhawk is already the best-selling, most-flown airplane ever with more than 43,000 delivered and this option further expands the market due to the worldwide availability of Jet A fuel," said John Doman, Cessna vice president of propeller aircraft sales. Cessna will install the engines at its Independence, Kan., factory under the supplementary type certificate already held by Thielert. Yup, gotta pay for the new improved NAS. JetA power GA aircraft are going to pay more taxes per gallon than the 100LL drivers, so UnkaSam wants more JetA sales... |
On Sat, 06 Oct 2007 20:03:28 +0000, Blueskies wrote:
Yup, gotta pay for the new improved NAS. JetA power GA aircraft are going to pay more taxes per gallon than the 100LL drivers, so UnkaSam wants more JetA sales... The salespeople at AOPA were really cagey WRT the Diesel 172. As best several of us can figure, this is for the overseas market. The salesperson did mention, for example, that 100LL was not to be found in South Africa. I've no idea whether or not this is true, but it seems to indicate the target market at which this is aimed. - Andrew |
In the short-term, my Cessna 172E has an AutoGas STC and runs just fine
on the stuff. In the long term, I will turn into a dinosaur, fail my medical, be unable to afford a $100k LSA, and just rock in my chair all day. ;^) Al 1964 Skyhawk |
| Thread Tools | |
| Display Modes | |
| 100/130 avgas | Roy Smith | General Aviation | 1 | December 24th 06 10:17 AM |
| Old AvGas | gwengler | Piloting | 2 | December 16th 06 02:07 PM |
| Survival and Demise Kit; Contest Points | Jim Culp | Soaring | 1 | June 21st 04 05:35 AM |
| The demise of the Sea Harrier | Henry J Cobb | Naval Aviation | 39 | April 25th 04 08:27 PM |
| Here's to Arafat's Speedy Demise | robert arndt | Military Aviation | 0 | September 12th 03 08:45 AM |
