Vince wrote:
Also under consideration is a redesign of the V-22’s nose to accommodate a chin gun, Birkholz said. “It’s all do-able,” he said. “It’s just expensive.” http://www.nationaldefensemagazine.o.../V-22_Aims.htm it wasn't doable you can hang it on the belly at the center of lift, that is where they put the cargo hook http://www.defenseindustrydaily.com/...ng_M777_lg.jpg Delete the hook. Any mission that the V-22 can use the hook for the H-53 series can do better. For any mission that doesn't include a sling load the V-22 flies faster, higher and further. -HJC |
On Oct 16, 7:35 pm, Vince wrote:
David Lesher wrote: Mike writes: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. Strange no one is discussing how much such weighs; in an airframe already short of payload... and balance its a side to side prop-rotor configuration hang a thousand pounds on the chin and see what happens There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) Wonder what they will hang on there? A .50 or twin .50 could work. 7.62 minigun? Vince- |
David E. Powell wrote:
On Oct 16, 7:35 pm, Vince wrote: David Lesher wrote: Mike writes: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. Strange no one is discussing how much such weighs; in an airframe already short of payload... and balance its a side to side prop-rotor configuration hang a thousand pounds on the chin and see what happens There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) IIRC that was the weight of the 30 mm turret + ammo + structural reinforcement and all control equipment Vince |
Vince wrote:
David E. Powell wrote: On Oct 16, 7:35 pm, Vince wrote: David Lesher wrote: Mike writes: Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. Strange no one is discussing how much such weighs; in an airframe already short of payload... and balance its a side to side prop-rotor configuration hang a thousand pounds on the chin and see what happens There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) IIRC that was the weight of the 30 mm turret + ammo + structural reinforcement and all control equipment Vince Just have the Marines go retro to WW1 and fire their pistols out the cockpits... :-\ |
In message om, David
E. Powell writes There could weight to play with in the tail, or a way to counterbalance by moving some equipment inside. They modified the B-17 OK, but they had a lot more relative weight to play with. There's the problem: the more weight you hang on the airframe, the less payload you have (which is the point of a transport helicopter). Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including ammo.) When you put it in a remotely-operated weapon station, the weight goes right up. "The basic Mini-Gun is 0.80 m long and weighs 18.8 kg. A typical pintle installation with one gun and 5,000 rounds of ammunition weighs about 500 kg", to quote Jane's Air-Launched Weapons on the GAU-2A/M134 7.62 mm Mini-Gun and Armament System - that's for a manually pointed mount. Wonder what they will hang on there? A .50 or twin .50 could work. 7.62 minigun? 7.62 is okay for suppressive fire against infantry, but if the V-22 is supposed to be doing any sort of self-escort then it really needs more range and hitting power (it may have enemy helicopters to cope with, and certainly wants to engage light vehicles). Something like a M3M .50" would be a decent compromise between terminal effect and weight. Don't forget the sighting system, too - if the V-22s are going in at night then you need to match the sight to the weapon and its range (so you can identify targets in time to effectively engage them). As with most engineering problems, it's not that the problem is insoluble... just that it ends up more expensive in time, money and capability than it first looks. -- The nation that makes a great distinction between its scholars and its warriors, will have its thinking done by cowards and its fighting done by fools. -Thucydides pauldotjdotadam[at]googlemail{dot}.com |
On Oct 21, 7:47 am, "Paul J. Adam" wrote:
7.62 is okay for suppressive fire against infantry, but if the V-22 is supposed to be doing any sort of self-escort then it really needs more range and hitting power (it may have enemy helicopters to cope with, and certainly wants to engage light vehicles). Something like a M3M .50" would be a decent compromise between terminal effect and weight. The once suggested system was the GDAS GAU-19 3 barrel .50 cal gattling gun. Weighing 456 lbs. http://www.dtic.mil/ndia/2002gun/depasqual.pdf BB I guess everybody has some mountain to climb. It's just fate whether you live in Kansas or Tibet... |
On 2007-10-21 07:47:55 -0700, "Paul J. Adam" said:
Don't forget the sighting system, too - if the V-22s are going in at night then you need to match the sight to the weapon and its range (so you can identify targets in time to effectively engage them). Actually, it seems to me that the V-22 could have a real advantage in this respect. Contemporary remotely-targeted gun systems can slew, aim and burst-fire far, far faster than a single gunner can provide it with targets. And the heavy part of the system is the gun, ammo and physical aiming hardware, not the targeting vision systems and associated avionics. So why not take a COTS gun, add another 6 vision/targeting channels and let the troopies in the back pick out bogies for the gun to shred? A full-360 ventral TV/IR vision system wouldn't add much weight, and the individual soldier aiming apparatus need not be more than a headset LCD sight and a joystick plugged into the targetting data bus. Assign one of the senior NCO's to monitor all the troopie targeting pippers with an override switch in order to prevent friendly-fire mistakes or ammo wastage. Expense might be a prohibitive factor, but probably not weight. Do wonders for the morale of the ground pounders making the assault, though. ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
On Oct 16, 6:51 am, Mike wrote:
Osprey may get turret-mounted machine gun http://www.marinecorpstimes.com/ Posted : Thursday Oct 11, 2007 15:11:37 EDT Air Force and Marine Corps V-22 Ospreys may get a turret-mounted machine gun, fulfilling a long-sought requirement for a forward-firing defensive weapon and making it unique among today's U.S. transport aircraft. There's little agreement on when such a gun might arrive, but at least one major defense company is spending its own money to compete for the job. A nose gun was considered early in the tilt-rotor's two-decade gestation but was branded too costly, Air Force requirements officials said. The fiscal 2008 supplemental request includes $82 million for research, development and testing of an "all-quadrant," or 360-degree, defensive weapon to augment the ramp-mounted 7.62mm machine gun the Marines use for now. Navy program spokesman James Darcy said there is no timetable for finding such a gun, and the search will be bound by finances and the plodding acquisition process. "SOCom is looking at a faster turnaround," Darcy said. "But Air Force Special Operations Command is flying a different mission than the Marine Corps." The squadron of 10 Marine-owned Ospreys now in Iraq will be used largely to transport troops, equipment and supplies. The Air Force, which handles the tilt-rotor program for U.S. Special Operations Command, is buying the plane for long-range special ops missions. While the Air Force's CV-22s are not slated to hit the desert until 2009, the service's Chief of Staff Gen. T. Michael Moseley is considering deploying his aircraft earlier. In September, SOCom announced the search for an "interim all-quadrant defensive weapon system" for its CV-22 tilt-rotors, with the intention of flight-testing such a weapon within 120 days of the contract award. "We both have a requirement for some sort of defensive weapon system," said Air Force Lt Col. Chet Treloar, deputy director for mobility and special operations requirements. But for the most part, those requirements are intentionally vague, he said, leaving the door open for industry to be as innovative as possible. It is not even specified whether the system should be fully integrated into the aircraft in the future or if a drop-in solution is the best plan. "There are advantages and disadvantages to total, permanent integration," said Air Force Maj. Rob Pittman of the Air Force acquisition office. "The quick-and-dirty solution that gets the job done might be the answer." Pittman, Treloar and Darcy said the requirements are joint Marine-Air Force requirements and the expectation is that everyone will get the same weapon. But they added that nothing has been decided except the requirements. "There's no competition yet and there's been no selection yet," Darcy said. "It's possible that the solution may be different" for different versions of the V-22, Pittman said. "But we push for as much commonality as possible." "I don't think we're there yet" as to what the final solution will be, Treloar said. "But the Air Force and the Navy and the Marine Corps are committed to keeping the troops safe. They want to deploy this aircraft tin a way that is as safe and effective as possible." BAE jumping the gun Meanwhile, BAE Systems has been spending its own money to develop the Remote Guardian System, a turreted, remote-operated, retractable weapon that could be fielded in the third quarter of 2008 and fitted aboard the V-22 and other aircraft, said Clark B. Freise, vice president and general manager of defense avionics for BAE. "We've been investing for two years and created our own program to develop the capability," Freise said. While Freise would not say how much BAE has spent or how much it would charge per weapon, he did say the price would be low enough to appeal to the Pentagon and high enough to recoup its investment. "We spent a lot of money on it," he said. "We found a hole in their protection, we're covering it for now, and we'll get it back. We'd rather not say how much we've invested. We have shared with the Marine Corps what we think it will cost to go into production, and it is significantly lower than other solutions." So far, the Remote Guardian has been tested only while mounted on a Humvee, but Freise said it has fired various U.S. weapons and is currently cleared to handle 300 knots and four times the force of gravity. Guns can include a 7.62mm Gatling gun, a .50-caliber machine gun and more, he said. He said it has an easily upgradeable sensor suite. A concern with any 360-degree system, especially a remote-firing one, is taking a shot at your own propeller or landing gear. According to BAE, that is not a risk with Remote Guardian. "The gun will never, ever point at a part of the aircraft. We integrated the safety keys into the design from the very beginning," Freise said. Who the hell do they think they have to fight off, Me-109s? |
![]() Who the hell do they think they have to fight off, Me-109s? Good question.... I think its a comfort peice more than anything. It's the job of gunships and AV8b's to clear the LZ prior to a V22 landing. |
Trying to make a flying SUV into a fluky gunship seems like a bad idea.
It's hard enough flying the thing, so whos going to be playing with a gun? |
Desktop Wallpaper - "Osprey Out for a spin". | T. & D. Gregor, Sr. | Simulators | 0 | August 31st 07 02:48 PM |
"Seeking Foreign Buyers For Osprey" | Mike[_7_] | Naval Aviation | 72 | July 4th 07 05:26 AM |
Desktop Wallpaper - "A covey of Osprey". | T. & D. Gregor, Sr. | Simulators | 0 | June 1st 07 08:41 PM |
"Marine Corps Grounds V-22 Osprey Aircraft" | Mike[_1_] | Naval Aviation | 0 | February 18th 07 03:40 PM |
V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 03:44 PM |
