#21
Newps wrote: I am not aware of any cable system that allows direct hookup of digital cable right to the back of the TV without first going thru a converter box. It's certainly possible but I think the hangup is a lack of a standard. So you're forced to run it thru the box first and the box simply converts it to channel 3 or 4 if you have an analog TV. Some cable companies do have some unencrypted digital cable channels, but apparently they can change that at will. from a FAQ at www.elgato.com 3) Unencrypted digital cable - ³Clear QAM" is similar to basic cable, but in digital form. The channels are not scrambled or blocked, but only a small number of channels are available for viewing. Some channels may be SDTV (standard), and some may be HDTV (high definition). Typically, networks like NBC or FOX will be present, along with public access, shopping, local, PBS, and perhaps some radio channels. 4) Encrypted digital cable - ³Digital Cable" is typically encrypted, or encoded so that you need a cable box (or CableCARD) to view it. If you have 500 digital cable channels that you receive with a cable box, then the majority of these channels will be encrypted. A Clear QAM tuner canıt receive encrypted digital cable; HDHomeRun canıt receive the majority of your digital cable channels. Therefore, HDHomeRun only receives a few cable channels, those that are Clear QAM (unencrypted). It cannot use a cable box, and it canıt receive most of your channels. The channels it can receive vary city by city, and some channels may be there one day, and gone in a few months. Essentially, your cable company reserves the right to encrypt and decrypt channels at will, but usually youıll see the networks, and some other content. That said, Clear QAM tuners can receive HDTV content, if available. For example, ABC may start airing HDTV content at 8PM nightly. That may be 720p or 1080i, depending on the channel. Clear QAM also sometimes offers more than one channel on the same frequency. In that case, EyeTV can open up all channels on the same frequency, at the same time (or any combination of channels on that frequency). If you use digital cable, please be aware of the strengths and limitations of Clear QAM tuners before purchasing HDHomeRun. You may want to contact your cable company, to find out if any of their channels are in Clear QAM format. You can also search the internet for such information - itıs common to find an article or message board post from people in your same city who are already using Clear QAM content. Unfortunately, no master list of Clear QAM service providers is available to Elgato. -- Bob Noel (goodness, please trim replies!!!) |
On Sun, 25 Nov 2007 05:50:19 -0500, "Morgans"
wrote: "Newps" wrote I am not aware of any cable system that allows direct hookup of digital cable right to the back of the TV without first going thru a converter box. It's certainly possible but I think the hangup is a lack of a standard. So you're forced to run it thru the box first and the box simply converts it to channel 3 or 4 if you have an analog TV. I'll have to tell Charter that they are doing their signal wrong, cause I can get channels till the cows come home with the cable going right into the back of my TV's. Comcast here has digital OTA through the cable without a converter box. I would only need a converter box for the pay channels, and that's not so much of a converter box as it is an access module to descramble the signals. |
On Sun, 25 Nov 2007 07:13:36 GMT, in rec.aviation.piloting, Marty Shapiro
wrote: (Scott) wrote in news:4748e56a.551894267@localhost: The sensible part of my mind wants to think that if DTV adoption is not high enough, the television advertising industry (which is the only bunch of folks with any real stake in this) will subsidize the devices to whatever degree necessary to retain their audience. The cynical part of me says that in that circumstance, the ad industry will cry and whine until the government pays to subsidize them. I wouldn't hold my breath. OTA (over-the-air)class A channels (high power) must switch to all digital on February 17, 2009. They do not have the option of continuing to broadcast in analag after that date. Most True, but consumers have the alternative to simply *not* upgrade their equipment. When analog broadcasts stop, people can choose to just turn the thing off and pick up a book instead. That's the sort of thing that advertisers don't want to see, and the only real reason that settop digital tuner equipment might be subsidized. Cable and satellite are not required to switch to digital. Since Some of them are already digital, some aren't -- it doesn't matter. An OTA DTV settop tuner is just catching up with what the cable and sat guys have been doing for years. Separate the tuner from the video and audio monitors, you gain a lot of flexibility in the system. -Scott |
wrote: "Newps" wrote I am not aware of any cable system that allows direct hookup of digital cable right to the back of the TV without first going thru a converter box. It's certainly possible but I think the hangup is a lack of a standard. So you're forced to run it thru the box first and the box simply converts it to channel 3 or 4 if you have an analog TV. I'll have to tell Charter that they are doing their signal wrong, cause I can get channels till the cows come home with the cable going right into the back of my TV's. Yup. So far around here Carter uses "at the pole" block filters. If you look up at the bottom of the connection "up there" you'll see one or more colored plugs. Roger (K8RI) |
"Roger (K8RI)" wrote Yup. So far around here Carter uses "at the pole" block filters. If you look up at the bottom of the connection "up there" you'll see one or more colored plugs. Charter around me is much more advanced. They send signals via fiber optics to powered boxes scattered around, that then feed about ten houses with coax cables. All of the premium packages are sent via the optics converters that then send the extra channels out each line. That also enables them to offer cable internet services. They can add channels as you order them, and are speaking to them on the phone. It's kinda neat. :-) -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| FAA ADS-B Out NPRM needs to be drastically changed | Ron Lee[_2_] | Piloting | 14 | October 9th 07 09:23 PM |
| nprm for private aviation | [email protected] | Piloting | 4 | September 11th 07 08:14 PM |
| DC ADIZ NPRM | Blueskies | Piloting | 3 | August 17th 05 05:22 PM |
| DC ADIZ NPRM | Blueskies | Home Built | 0 | August 16th 05 12:41 AM |
| NPRM proposing to update the AC 43.13 2A - | [email protected] | Home Built | 0 | January 3rd 05 04:56 PM |
