ELT normally uses an externally mounted antenna. But in composite
planes it may be advantageous to use a ducky. 1. On crash the external antenna may be destroyed - brushing against trees, whatever. An attached ducky on the ELT will likely stay on. 2. A ducky radiates nearly isotropically - i.e. near equal in all directions. If the standard externally mounted ELT antenna survives the crash, a half wave or a quarter wave radiation pattern is mostly perpendicular to the antenna - in normal situations that would be horizontal. But on the ground after the crash, horizontal directions are often obscured by terrain - one reason why HAMs use VHF repeaters - and the signal is weak above where the search planes are. This is where the ducky may have an advantage and will send signals in all non- obscured directions equally. Note that a plane crash does not guarantee any orientation of the plane/antenna or after crash worthiness of the antenna. Even if Fosett's ELT worked its antenna may have radiated horizontally against mountain obscurations or was broken off. You can get a 121.5MHZ tuned ducky (low SWR) for only $16 bucks from http://www.smileyantenna.com/ I don't work for them. |
Transponder Antenna Ground Planes | Ken Kochanski (KK) | Soaring | 6 | April 6th 07 08:13 PM |
antenna ground planes | [email protected] | Home Built | 12 | November 4th 05 11:30 PM |
Metallic paint and composite antenna signal strength | firstflight | Home Built | 23 | July 26th 05 09:10 PM |
Six-Place Composite? | Marco Leon | Piloting | 24 | January 23rd 05 03:18 PM |
Composite workshop | Marske Flying Wings | Restoration | 0 | January 26th 04 12:03 AM |
