I have a couple of times and couldn't see a thing, I could only verify
by feel and tugging on the flaperons. I often see owners with inspection mirrors peeking inside. If I remember correctly, the connection is somewhere behind the spar, is there a trick to seeing it? No trick, seriously: You just reach in and hook them up by feel - one hand on the connector, and other hand on the control (stick or dive brake) to move to the right position to snap in place. Verify the ball is in the socket, then screw the safety all the way on. THEN: Look through the opening and you can see all 4 connections, directly and on the mirrors installed by LS behind them. Sleeves are color coded to show if they are not correctly hooked up. No additional inspection mirrors needed, since they are already installed in the ship! I really fail to see how it could be any easier - except of course, automatic hookups a la LS6-c... Beyond that, the fact that I know two very experienced long term LS6 owners who managed to screw up that connection is the main reason I shy away from them... In the above sentence, replace LS6 with just about any glider, including those with automatic hookups, and it will still be true. Anything mechanical can fail or be mishandled... Anyway, I hope you like your ship, cuz I love mine! Kirk |
![]() You just reach in and hook them up by feel - one hand on the connector, and other hand on the control (stick or dive brake) to move to the right position to snap in place. Verify the ball is in the socket, Right, that's what I do on my 6b. then screw the safety all the way on. Before I do that, I try to pull the connections apart (thanks to Dave Nadler for that suggestion). THEN: Look through the opening and you can see all 4 connections, directly and on the mirrors installed by LS behind them. Sleeves are color coded to show if they are not correctly hooked up. Tony V. LS6-b "6N" |
There are plenty of very good gliders that don't have
self-connecting controls, don't let that put you off buying them; unless you think you are the sort of idiot that will take-off without having the connections checked. At 02:48 02 November 2007, Waduino wrote: What's the solution to this question? What's a good first glider for someone transitioning from a CS77 and wanting the following: - automatic hookups - easy to rig - flaps - well behaved in terms of stall/spin, and - climbs well in weak conditions and runs reasonably well in average east coast conditions Budget? Say 20-60k US, depending whether I go alone or with 1 or 2 partners. Thanks. Wad. |
![]() Unfortunately relying on being less of an idiot than others does not always seem to work as a safety approach. :-( So personally I had automatic control hookups on my requirement list in my early glider purchase decisions. On the other hand what is it with people still not doing positive control checks. On any glider manual or automatic hookup (and I am aware of incidents with failure of automatic hookups). I threatened not to run one guys wing earlier this season because he had not done a positive check and instead was standing around chatting to people waiting for a tow - and he was about to tow a matter of a few hundred feet from where somebody had been killed a few years ago from guess what... not having controls connected. Sigh. Darryl On Nov 2, 5:39 pm, Mark Dickson wrote: There are plenty of very good gliders that don't have self-connecting controls, don't let that put you off buying them; unless you think you are the sort of idiot that will take-off without having the connections checked. At 02:48 02 November 2007, Waduino wrote: What's the solution to this question? What's a good first glider for someone transitioning from a CS77 and wanting the following: - automatic hookups - easy to rig - flaps - well behaved in terms of stall/spin, and - climbs well in weak conditions and runs reasonably well in average east coast conditions Budget? Say 20-60k US, depending whether I go alone or with 1 or 2 partners. Thanks. Wad. |
Wad,
I'm surprised nobody's mentioned the LS8. I don't know market value on this ship right now, but I would imagine a used "straight 8", i.e., 15m wingspan only and not the 15/18m version, might be had for $60k. Well, maybe not. These are still competitive ships. Damned good ones, too. They have automatic connections, assemble very easily, and go VERY WELL. Wings seem a bit heavy (I'm the guy out on the tips, so I know the wings are heavier than ASW-20C, Discus CS, ASW-24, Standard Cirrus, LS1-f, and Libelle 301. These are the other ships at my club that I get to help assemble.) But the LS8 goes together so quickly that I don't have to hold them very long. So, I would definitely add the LS8 to your list. Ray Lovinggood Carrboro, North Carolina, USA LS1-d |
rlovinggood wrote:
So, I would definitely add the LS8 to your list. Given that "flaps" were his second priority after "easy to rig", that could be fixed with a hack saw and a bit of time... |
On Nov 2, 10:23 pm, Marc Ramsey wrote:
rlovinggood wrote: So, I would definitely add the LS8 to your list. Given that "flaps" were his second priority after "easy to rig", that could be fixed with a hack saw and a bit of time... Marc, Yes, yes, yes. He did mention flaps, but as UH mentioned, on the East Coast, Standard Class ships do quite well and go "almost" as fast (sometimes faster?) than the flapped variety. Do you really need a hacksaw, or can you just add a "dummy" lever on the left side of the cockpit, in order to give the left hand something to do during flight? Ray Lovinggood Carrboro, North Carolina, USA LS1-d |
rlovinggood wrote:
Yes, yes, yes. He did mention flaps, but as UH mentioned, on the East Coast, Standard Class ships do quite well and go "almost" as fast (sometimes faster?) than the flapped variety. Do you really need a hacksaw, or can you just add a "dummy" lever on the left side of the cockpit, in order to give the left hand something to do during flight? I think you and UH see flaps as just a go fast option, for a lot of us, flaps are for going slow when we're trying to land in little dinky fields... Marc |
On Nov 2, 10:05 pm, Marc Ramsey wrote:
rlovinggood wrote: Yes, yes, yes. He did mention flaps, but as UH mentioned, on the East Coast, Standard Class ships do quite well and go "almost" as fast (sometimes faster?) than the flapped variety. Do you really need a hacksaw, or can you just add a "dummy" lever on the left side of the cockpit, in order to give the left hand something to do during flight? I think you and UH see flaps as just a go fast option, for a lot of us, flaps are for going slow when we're trying to land in little dinky fields... Marc 20 and 24 are still wood gliders : look inside SZD-55 has automatic hookups, no wood, big tanks for ridge, light wings for assy, Look at last Sunday OLC 1010 km from Mifflin. RW |
On Nov 1, 10:44 pm, Waduino wrote:
What's the solution to this question? What's a good first glider for someone transitioning from a CS77 and wanting the following: - automatic hookups - easy to rig - flaps - well behaved in terms of stall/spin, and - climbs well in weak conditions and runs reasonably well in average east coast conditions Budget? Say 20-60k US, depending whether I go alone or with 1 or 2 partners. Thanks. Wad. L/D =$/Distance. Tthat's what you are looking for?. SZD55 kicks any asses |
