#21
"KeithK" wrote in message ... In article , (Kevin Brooks) wrote: I believe what he was referring to is the fact that red, green, and blue are *the* primary colors. Er, isn't that red, green, and yellow? Actually, red, green blue are "the primary colors of light" but red, yellow and blue serve the same purpose for pigments. The red, green blue thing originates in the human eye. In a "normal, healthy eye" there are four types of receptors: one type is most sensitive in the red region of the spectrum, one in the green, one in the blue and one (that provides night vision) is sensitive across a the great swath of the visible spectrum up into the ultra violet. None of the types have exactly sharp cut offs in sensitivity and in fact the color cells have a good deal of over lap in their sensitivities. It's because of this over lap that mixing the "primary colors" fools the eye into seeing the infinite colors and shades that lie between. |
"BUFDRVR" wrote in message ... Green + Red = Blue??? Mind boggles. hmm, doesn't it? Green is yellow + blue |
"Tarver Engineering" wrote in message
... "BUFDRVR" wrote in message ... Green + Red = Blue??? Mind boggles. hmm, doesn't it? Green is yellow + blue Go back to sleep, John ![]() John |
"John Mullen" wrote in message ... "Tarver Engineering" wrote in message ... "BUFDRVR" wrote in message ... Green + Red = Blue??? Mind boggles. hmm, doesn't it? Green is yellow + blue Go back to sleep, John Actually, we make NVG repeaters for Aussie rotary wings. There is quite a bit of extra effort required for the timing of the lighting circuit and filtering; even with HP NVG green LED arrays. Red is bad, green is good, but not just any green. |
Regnirps wrote: (Kevin Brooks) wrote: If you're dealing with paint it would be red, blue and yellow (or Cyan, Magenta and Yellow) RGB corresponds to the color detectors in the retina. With paint, as in having it mixed at the hardware store, one uses a bunch of colors, like 10 or 12 to form a polygon in the color space and give a much larger pallet of colors. Just RGB or CMY gives a triangle and leaves out a lot of the perceivable colors. See any chromaticity diagram (which is three dimmensional and usually shown as two with shading for the third). Which is why painting is an art. However, pretty much every ink-jet printer uses CMY + black. Higher quality ink-jet printers use about six different colours. It is possible to "see" colors that do not exist in the electromagnetic spectrum, like brown. Yes, brown isn't spectral colour. Likewise, the orange from red+yellow is a product of the brain and retina as opposed to an orange spectral line from a sodium lamp. They look the same to us but a simple filter will show the difference. Sure, a combination of two primaries can lead to the same sensation as a specific spectral colour. So, what and NVG will react to can be auite different from what the eye alone will react to. Most of modern color/brain theory comes from work by Land who found ways to "fool" the brain into seeing full color with just two colors in the projection. Photographers talk about addititive and subtractive colors depending on whether a process uses primary dyes or filtering gels. But we are not dealing with paint (for which the proper selection is the latter, IIRC). BRBR -- Charlie Springer The Feynmann is of course a very good reference. We're making the same point here. Different primaries can be used in different combinations to produce the same colour sensation on your retina. Regards, Ralph Savelsberg |
"BUFDRVR" wrote in message ... The green plus red is blue boggles my mind. Still, I wouldn't call myself a colour spectrum expert, but I'll give it a try: The NVGs are most sensitive to light at the low frequency/ long wavelength end of the visual spectrum, i.e. the red end of the spectrum (and unlike the human eye even is sensitive to somewhat lower frequencies in the IR range). Green is associated with higher frequencies/smaller wavelengths than red. A red light of a certain intensity produces a far stronger response in the NVG than a green light of similar intensity would, since green lies further away from the wavelength range to which the NVGs are most susceptible. Pretty straightforward. As for the blue, this is associated with even higher frequencies/smaller wavelengths than the green, so it should be even less visible, which gives no explanation whatsoever for why green would work better than blue, unless with blue the worry would be that you wouldn't bee able to see that at all, while wearing your NVGs. Wow, this thread has gotten good, imagine that I'm actually learning here. Unfortunately, I obviously misunderstood the NVG experts words, I thought he said blue light was closer to the red spectrum than green, but if you're correct (as well as another poster who posted the exact frequencies for each color...impressive), I must have misunderstood. Anyway, he was correct, my blue indiglo watch washed out my NVG's, if only slightly, while the green light of similar intensity did not. Green light is the best way to blind NVGs, as that is the light they are most sensitive to. Quite a bit of care is required to produce the correct frequency of green light, for an NVG display to be readily readable. |
I hope you mean red. With NVGs on, I can see a glow from a red light turned on *behind me*. No matter how bright a green light is, it will not wash out NVGs anymore than red light. BUFDRVR "Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips everyone on Bear Creek" |
#29
BUFDRVR wrote:
Green light is the best way to blind NVGs I hope you mean red. With NVGs on, I can see a glow from a red light turned on *behind me*. No matter how bright a green light is, it will not wash out NVGs anymore than red light. nope, that's Tarver for ya.... forged in the "D-U-M-B" position. redc1c4, ask him about the "strakes" on the F/A 22. %-) -- "Enlisted men are stupid, but extremely cunning and sly, and bear considerable watching." Army Officer's Guide |
| Thread Tools | |
| Display Modes | |
| An odd clearance...can anyone explain? | Andrew Gideon | Instrument Flight Rules | 32 | September 18th 04 10:35 PM |
| RV-7a baggage area | David Smith | Home Built | 32 | December 15th 03 05:08 AM |
| TEC, can anyone use small words and explain this to me? | Snowbird | Instrument Flight Rules | 11 | November 16th 03 06:51 PM |
| Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 03:33 AM |
| Honor to those who came forward | ArtKramr | Military Aviation | 51 | July 8th 03 12:19 AM |
