On Nov 22, 9:04 am, C J Campbell
wrote: On 2007-11-21 20:25:12 -0800, Newps said: A woman I work with is very good friends with the pilot of the aircraft that ended up in the water. What basically happened is that the 182 ran over this aircraft, tearing the vertical tail off the aircraft. He said next thing I know I am spinning. Every rotation of the spin makes a bigger and bigger arc in the sky due to his inputs. Finally he can basically get it right side up and with power and aileron he stalls it into the water. Plane floats a while before sinking. After he gets his wife out of the plane he notices missing tail. Both spend minimal time at hospital. Meanwhile 182 jockey is all over the news saying..."That other aircraft came out of nowhere." NTSB will most likely fault both pilots for not seeing and avoiding. Yeah, we wouldn't want the NTSB faulting the real culprit there, would we? This area has been a chamber of horrors for a long time. Near misses are very common there. The FAA has so balkanized the airspace that air safety has been severely compromised, just as the AOPA predicted when the current airspace arrangement was proposed decades ago. What you have is a bunch of airplanes traveling a narrow corridor through a bunch of class D airspace areas while remaining under a low class B ceiling. Sure, you could call up Tacoma Narrows, and McChord, or SeaTac, or Boeing Field, or Fort Lewis, or Renton, and transit their airspace, but doing so requires you to be constantly looking up the proper radio frequency from a whole list of different ATC frequencies and figuring out which one is appropriate to use for your location and direction of flight, all the while trying to fly the airplane and see and avoid other aircraft. Some pilots have made little lists of all the frequencies needed in the area, but these lists always seem to be missing one critical frequency or another. So everyone drops down to 1000' and tries to navigate a narrow corridor that runs through a maze of radio towers and along the freeway, trying to get from one side of Seattle to the other without talking to anybody. Aggravating the situation is that all these towers are busy and they do not necessarily reply very quickly to aircraft trying to contact them, so trying to avoid the crowded I-5 corridor quickly becomes an exercise in frustration. It is not at all uncommon for SeaTac to make you wait 20 minutes or more before transiting the class B airspace. I have seen aircraft circling over Vashon Island for ten minutes or more as they wait for Boeing Field to respond to their calls -- another good place for mid-airs while everyone waits their turn. Aircraft transiting Tacoma Narrows' airspace are usually restricted to 1500 feet, just 200 feet above the traffic pattern, and they often have to switch frequencies between SeaTac, McChord, Seattle Approach, and Tacoma Tower. It is not always clear who you are supposed to be talking to, either. You might be in Tacoma's airspace, but they might have you call SeaTac or Approach, claiming that they have some sort of LOA giving them control of their airspace, or vice versa. So the FAA has basically created a huge wall, 40 miles long and 10,000 feet high, that is inaccessible to GA, but the wall has a tiny hole in it. And then they wonder why there are so many incidents there at that hole. It is like cramming a sixteen lane freeway down to a single lane and then blaming "bad drivers" for all the accidents and congestion there. But then again, Washington's Department of Transportation is entirely capable of pulling stunts like that, so maybe they are not so different from the FAA after all. The FAA's attempts to make us safe have ended up endangering thousands of people every day. So, yeah, blame the pilots. -- Waddling Eagle World Famous Flight Instructor Ronnie sad the PATCO controls "quit" in the 1980's....hmmm |
Tacoma, WA - Narrows airport might be closing | [email protected] | Piloting | 0 | May 19th 07 01:05 AM |
Indiana National Guard pilot killed in midair collision | Otis Willie | Military Aviation | 0 | June 17th 04 08:08 PM |
Georgetown, TX - MIDAIR Collision | Nasir | Piloting | 49 | May 19th 04 02:36 AM |
F-15 Midair Collision Video | Jay Honeck | Piloting | 0 | March 20th 04 11:42 PM |
4 dead at Turf in midair | Stewart Kissel | Soaring | 2 | December 29th 03 02:31 AM |
