Class B airspace notation
Old December 17th 07, 05:09 AM posted to rec.aviation.piloting
Airbus
Default Class B airspace notation
In article , says...
BillJ wrote:
I thought I understood everything that could be on a sectional, but
before a trip to New York City airspace, I studied the sectional and
terminal area charts a little extra carefully. Just southwest of Newark
(EWR) (and also other places) there is a notation such as 70/+12 in blue
for the floor and ceiling of class B airspace. What does the "+" mean? I
went to the aeronautical chart users guide which has lots of symbols but
not this. They do mention a "-" means up to but not including in one
example not having to do with floor and ceilings, but what could does
this mean for a floor? AGL?
It means exactly the same as the "-" does for a ceiling; the airspace
includes all altitudes above (but not including) 1200 MSL, and up to (and
including) 7000 MSL.
In theory, it means you are legal to fly at 1199 feet talking to nobody
while ATC runs a heavy jet 1 foot above your head at 1200. In practice, it
means if you want to go below the CBAS, do it at 1100.
"Upward from above" is the term used on the TAC.
In other words, (IIUC) it means you can operate at 1200 feet talkiing to
nobody, while ATC runs a heavy jet 1 foot over your head at 1201, where CBAS
begins . . .
Old December 17th 07, 06:07 AM posted to rec.aviation.piloting
Mxsmanic
Nomen Nescio writes:
Because you're a dip****
Nope, that's not the reason.
Old December 17th 07, 06:12 AM posted to rec.aviation.piloting
Mxsmanic
Airbus writes:
Trying to read between the lines of this incredibly weird post, it would appear
the writer is suffering from the illusion that "fractional" airspace altitudes
in a given segment are indicated both for the charted (Class B) airspace and
for the underlying (Class E). Readers should be advised of the fact that this
expert, offering his "presumptions" may never have seen a sectional chart, and
certainly has never studied the subject - does not know how to read the chart.
Okay ... so explain why the charts include + and - for altitude limits on
airspaces?
I already know the answer, since I looked it up ages ago, and I've given it,
but I'll try again:
If you see, say, 50/SFC for a Class C, and 80/50+ for a Class B above it, it
means that the Class C extends from the surface to 5000 feet inclusive, and
the Class B extends from 5001 feet to 8000 feet inclusive.
Without a plus or minus sign, there is an ambiguous margin of 100 feet between
the airspaces. For example 50/SFC for the Class C and 80/51 for the Class B
means that the area between 5001 feet and 5099 feet inclusive is in neither
airspace. Since this could cause problems if someone were to actually try to
fly through this thin slice of air, calling it uncontrolled, the + and - are
used to make it clear that the two airspaces touch each other, with no space
between.
Old December 17th 07, 06:17 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Airbus writes:
would appear the writer is suffering from the illusion that
"fractional" airspace altitudes in a given segment are indicated both
for the charted (Class B) airspace and for the underlying (Class E).
Readers should be advised of the fact that this expert, offering his
"presumptions" may never have seen a sectional chart, and certainly
on airspaces?
Doesn't matter, you don't use airspace.
Bertie
Old December 17th 07, 06:18 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Yes, it is.
Bertie
Old December 17th 07, 07:14 AM posted to rec.aviation.piloting
WingFlaps[_2_]
On Dec 17, 2:27 pm, Mxsmanic wrote:
writes:
What is the practical difference between "above, but not
including" (e.g., +12) and "above and including" (e.g., 12)?
I think it serves when you have two airspaces with no margin between them.
For exampple, one is 12/SFC, the other is 70/12+. So at 1200 feet you're in
one airspace, and at 1201 feet, you're in the other. If they were specified
as 11/SFC and 70/12, the space between 1101 feet and 1199 feet inclusive would
be outside either airspace.
You need to understand the vertical relationship between airspaces.
Have a look at a sectional and think about it. Why would you choose to
fly on the vertical limit between to airspsaces anyway?
Cheers
  #29
Old December 17th 07, 11:37 AM posted to rec.aviation.piloting
Steven P. McNicoll
"Airbus" wrote in message
CBAS
begins . . .
A bit more than a foot would be required. An altitude assigned by ATC
cannot be lower than the MVA.
  #30
Old December 17th 07, 01:41 PM posted to rec.aviation.piloting
writes:
There are certainly reasons to want to fly at a +X altitude rather
than 100' lower. For example, if you're under a low Class B shelf, you
might want to be as high as possible as a precaution in case there's
an engine failure; 100' higher might give you 1000' further to glide.
But not every +X floor adjoins a designated X ceiling below. For
instance, consider the +05, +08, +11, and +12 Class B segments around
EWR on the NY TAC (see skyvector.com). What's the point of the + for
those segment floors? A +11 lets you fly at 1100', as opposed to 1099'
without the +. But letting you fly one foot higher is of no value,
since that's much less than the accuracy with which you can control or
even measure your altitude. So why do they bother having the + there?
Windows into the Class A airspace [email protected] Soaring 6 August 11th 07 10:32 AM
Class F Airspace in Germany Guy Corbett Soaring 4 May 9th 07 09:25 AM
Class A airspace flying_monkey Soaring 66 October 22nd 06 03:38 PM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 02:53 PM
vfr corridors through class B airspace [email protected] Instrument Flight Rules 26 November 2nd 03 11:28 PM
