Bonanza (A36) Approach Speeds
Old December 17th 07, 11:20 PM posted to rec.aviation.piloting
F. Baum
Default Bonanza (A36) Approach Speeds
On Dec 17, 3:04 pm, john smith wrote:
They do say that *most* Bo pilots land far too fast. With 10 hours of
class room (ground school) they drilled into us we would NOT be
landing too fast.:-)) You should have heard the complaints when we
were informed we'd be calculating the approach and departure speeds
(for VFR) based on aircraft weights and flying those within a couple
MPH/knots.
What does that tell you about the quality of instruction prior to the
ABS course?
Or they have read too much of Collins bad advise
Old December 18th 07, 12:12 AM posted to rec.aviation.piloting
On Dec 17, 6:01 pm, Newps wrote:
On Dec 17, 3:05 pm, Newps wrote:
BUT -- 70 KIAS is not a power -off landing speed. There's insufficient
energy to flare, so a bit of power is required to arrest the descent.
What? Did the tail fall off? I have plenty of elevator at 70 kts, no
power and a forward CG in a 35 Bo.
I fly a 1947 Model 35 as well.
Not the same airplane as an A36, the topic of this thread.
Doesn't matter.
Care to elaborate?
The A36 and Straight 35 are exactly the same, except for the different
wings, different weights, different powerplants, different CGs,
different loading envelopes, different gear, different prop governors,
different empennage, and a few thousand other minor differences.
I guess that doesn't matter?
Dan
Dan
Old December 18th 07, 10:53 AM posted to rec.aviation.piloting
Doesn't matter.
Care to elaborate?
wings,
Wings are the same.
different weights,
The 36 weighs 31 pounds more than the same year model 35.
Same powerplant as mine.
different CGs,
Yes and it is beneficial.
different gear,
Same gear, just heavier duty than the straight 35, exactly the same as mine.
Irrelevant.
Duh.
No, it doesn't change the fact that at 70 knots you are not out of
elevator. I land at less than that speed, power off and it flares just
fine.
Please re-read the thread an you will see I am referring to a 1947
Model 35, which is significantly different in every respect I
mentioned.
I have not found that the A36 has enough energy left to flare and
arrest the descent at 70 KIAS.
Dan
Old December 18th 07, 01:06 PM posted to rec.aviation.piloting
Jim Macklin
A36 GW on same wing as 33 or 35, is 200 pounds greater.
"Newps" wrote in message
insufficient
| Doesn't matter.
| Care to elaborate?
| wings,
| Wings are the same.
| different weights,
| different CGs,
| different gear,
mine.
| Irrelevant.
| Duh.
| fine.
Old December 18th 07, 01:09 PM posted to rec.aviation.piloting
Jim Macklin
The CG range on the A36 is very different from the 33/35 models. Without
passengers in the middle or rear, the CG is further fwd and the force
required to flare is greater.
insufficient
descent.
no
| Doesn't matter.
| Care to elaborate?
| wings,
| Wings are the same.
| different weights,
| different CGs,
| different gear,
mine.
| Irrelevant.
| Duh.
| fine.
| mentioned.
| Dan
Old December 18th 07, 04:18 PM posted to rec.aviation.piloting
Newps
It can be.
Old December 18th 07, 04:19 PM posted to rec.aviation.piloting
Newps
The CG range is a little larger on the 36 but otherwise similar. With
pax only in front of the 35 the CG is near forward limit, same as the 36.
  #29
Old December 18th 07, 09:49 PM posted to rec.aviation.piloting
Roger (K8RI)
It's not an elevator authority issue, but rather one of energy.
Book figures for the 33 are ~ 80 knots (varies a bit from year to
year) for a no power landing. It's 78 (90 MPH) for mine. Normal is 70
(80 MPH) minus one mph for each 100# under gross. The POH states the
power off landing is faster as there is not enough energy to safely
flare at the normal power on landing speed.
Depending on the year the 36 is slightly longer than the 35/33 to a
fair amount longer (18" IIRC). CG covers a much wider range on the 36.
As I recall the wing is the same with some minor differences in the
tips, stall strips, and rivet patterns (flush and round head). OTOH
they are not interchangeable. Early 33s had a number of variations in
the tank arrangement(s). I've had mechanics swear the aux tanks on
mine were after market as they are forward of the spar, but it came
from the factory that way.
The early 35s are considerably lighter than later 33s and 36s.
Later 36s are heavy.
Roger (K8RI)
  #30
Old December 18th 07, 09:53 PM posted to rec.aviation.piloting
Roger (K8RI)
On Mon, 17 Dec 2007 06:02:38 -0800 (PST), "
105 is what they had me flying the ILS in the Deb/F33 at Columbus.
As the foggles/break out did not come off until the MM (200 feet) the
reconfiguration was rather short and quick.
So you broke out at minimums and then configured for landing ? If I
were you I would find a different instructor next year.
Was this during the ABS Bonanza training??
Yup
Does seem like stuffing 10 lbs into a 5 lb bag...
It really isn't all that bad.
It'd be really easy if the trim weren't hidden under the instrument
panel requiring the pilot to lean over to adjust. OTOH it's *coarse*
and takes little movement of the trim wheel. They fixed that around
CD-60 or so.
Roger (K8RI)
Dan
F-18 Approach and touchdown speeds on runways? Paul Michael Brown Naval Aviation 5 August 25th 04 04:56 PM
Approach speeds for ILS C J Campbell Instrument Flight Rules 73 March 2nd 04 11:20 PM
Approach speeds for ILS C J Campbell Piloting 71 March 2nd 04 11:20 PM
LSA Approach speeds Ace Pilot Home Built 0 February 3rd 04 05:38 PM
Approach speeds for ILS G.R. Patterson III Piloting 0 January 22nd 04 10:13 PM
