#21
Ed Rasimus wrote:
On Sun, 7 Dec 2003 16:56:41 +0000, "Paul J. Adam" wrote: In message , ArtKramr writes Let's take two planes going on low level support missions. They will have to fly through heavy ground fire including small arms fire. One plane is equipped with a radial engine,. let's say an R-2800. The other with a jet engine. Which plane would have a better chance of survival inder these conditions?. Opinions? My gut feeling is the jet, if only because it's faster and spends less time being shot at (and the higher deflection makes it harder to hit). Also, jet aircraft can be pretty tough; stories around about them surviving assorted insults (going as far as F-105s flying with destroyed engines, using the afterburner as a sort-of-ramjet) so the survivability between a jet and a radial recip isn't as pronounced. After all, either aircraft is equally at risk from hits to pilot, control surfaces, fuel tanks et cetera... superior survivability of the engine is a factor, but not the only one (vice the use of P-51s rather than P-47s in Korea) Seems to me that you need to define a lot of additional parameters before you can reduce the discussion to whether a radial is more survivable than a jet. If you say same speed, same profile, same airframe, same tactics, same thrust(power) to weight, same performance, then I'd go to the radial engine as being one that sustains a bit more insult. But, we've not added the factor (significant in my mind) about the volatility of AvGas over JP-4 (JP-8). Wet wing airplane taking a hit in the fuel tanks? Not pretty. Glad someone mentioned the fuel difference. Early on, the USN and RN blended AvGas with kerosene for jets on their carriers, as they still had a lot of piston a/c on board. The stowage requirements were very different; Kerosene fuel could go in unprotected fuel tanks just like ship fuel oil, while AvGas had to be carried in tanks inside the ship's armored box. The British were even more careful with AvGas than the US was -- they kept it inside the armored box in cylindrical tanks totally surrounded by water filled compartments. This restricted their AvGas stowage even more, which is one reason why the British carriers were unable to operate as many a/c as US ones did. It was also found that 62% of the single engined jet losses in Vietnam and the middle east were due to damage to the fuel system. Given the far greater likelihood that a hit in a fuel tank or line containing AvGas would cause a fire, it seems reasonably safe to assume that this was the cause of at least as high a percentage of piston-engined fighter losses in WW2, although no statistical data seems to have been gathered prior to Vietnam as to specific causes of loss. FWIE, the remaining causes of loss were pilot incapacitation, 18%, 10% to control damage, 7% to loss of engine power, and 3% to structural damage. So engine toughness per se was a relatively minor part of single-engined jet combat losses, at least in the 1960s. The use of AvGas made it difficult to radically increase the a/c fuel carried by the Essex class carriers postwar (to meet the needs of thirstier engines), owing to the fire danger and stowage requirements. The swirtch to a higher and higher percentage of jets meant they could carry more fuel just about anywhere, allowing over a 100% increase in a/c fuel carried, which was very necessary to handle the jets' greater thirst. But, if you let your jet go faster, pull more G, maneuver more aggressively, build a tactics package that suppresses the defenses, etc. then you come up with the undebatable conclusion that the jet does better. Have I ever mentioned that FAST is better? The early centrifugal jet engines like the Nene and Tay seem to have been quite damage tolerant (the early axials less so, but design has improved a lot since then). Hre's Gabby Gabreski on his first MiG kill, firing from dead six on a non-maneuvering target: "When the sight was squarely on his mid-section I fired a short burst of armor-piercing and incendiary from the six fifties. I could see strikes all over the lower section of the fuselage, I kept firing for a couple of seconds and was now directly astern, about 600 feet back. I centered the sight on his tailpipe next and gave him another burst. I saw strikes again, around the engines as well as the wings. Now he went into a slight dive and smoke began to stream back from the tailpipe. "I passed over him and broke off to the right and he started down and I kept him in view. He was losing altitude but much to my amazement, was still under control. I decided to make another pass from above right; my three Sabres were now strung out behind me. There was grey smoke from the MiG; he had decelerated. In a matter of seconds, I closed for another pass, coming in from astern, I got very close and gave him a good, long burst. This time pieces of his aircraft began to fly off. They might have been turbine blades from the engine and they passed me on the right. The canopy flew off. Then the pilot ejected. His parachute opened. We turned on course for home. "I was surprised to see how hard it was to bring down a jet, how much damage he absorbed before he finally went down. Later, of course, we got the bigger guns [Guy: 4 x 20mm M39] in the Sabres . . . these were fifty calibre shells. It took a lot of them to bring one down." [Quoted in "F-86 Sabre," by Maurice Allward] The six .50 cal. M3s in the Sabre fired about 50% faster than the WW2 era M2s in the P-47, and unlike the P-47 they were all mounted in the nose rather than the wings, so when you were on target, you were _really_ on target; no need to worry about convergence range. Elsewhere in the same book, Col. Eagleston (former 354th 'Pioneer Mustang' group leading ace, IIRR commanded either the 4th Group or Wing in Korea; I forget which, but both echelons existed) is mentioned as preparing a report stating that of every three MiGs hit by his Sabres, two had escaped, and that to destroy a MiG, an average of 1,024 rounds of .50 caliber had been fired. Russian MiG pilots had a high opionion of the damage tolerance of their MiG-15 engines (essentially reverse-engineered R-R Nenes), but had a lower opinion of the toughness of the Sabre's GE J47 axial engine. To be fair, their guns were a lot more powerful than the Sabre's .50s, so the comparison isn't exact. How well the MiG-15 would have held up under the fire of a 37mm and two 23mms is an interesting question. ISTR seeing navy stats that showed Navy and Marine Panthers suffered a lower loss rate than Corsairs and maybe ADs on ground attack missions; the Panther also used a license built Nene (J42), and later the larger but also centrifugal R-R Tay (J48). I don't know how the Banshee, which used a pair of axial engines IIRR, stacked up, but its involvement in Korea was limited. It's impossible to make such a comparison on the Air Force side of Korea, as the only piston fighter they used for ground attack was the Mustang, and there's absolutely no doubt that a jet is superior to a water-cooled engine in damage tolerance. I've got the USAF fighter statistical data for the Korean war, and the Mustang's loss rate is far higher than either of the two USAF jet fighters that were largely dedicated to ground attack. Here's the Korean War total combat sorties / losses credited to ground fire / % loss rate (credited) to ground fire per sortie for the F-51, F-80 (centrifugal) and F-84 (axial). I've left out the losses credited to aircraft and unknown causes: F-51: 62,607 / 172 / 0.27% F-80: 98,515 / 113 / 0.11% F-84: 86,408 / 122 / 0.14% The Republic F-84's higher loss rate compared to the F-80 may be due to a higher vulnerability of its J35 axial engine compared to the F-80's centrifugal J33, but it's also possible that other factors unrelated to the engine may be the cause. Early on the F-80 flew a fair number of A/A sorties, and while the F-84s of the 27th Fighter-Escort Wing also flew some, I suspect that the F-84 flew a higher percentage of its sorties air to ground. The F-84 also came into the war well after the F-80, so it may be that it was just facing stronger defenses, especially after the front line had stagnated. The type of ordnance employed may also have affected the time spent in threat zones, and thus loss rates -- the F-80 fired almost 4 times (80,935 vs. 22, 154) as many rockets as the F-84, while the latter dropped a considerably higher tonnage (55,987 vs. 41,593 tons) of bombs. I lack the data to reach any hard conclusions, but the F-84, being from the Republic 'Foundry, certainly had the reputation of being able to take more damage than its USAF fighter contemporaries. All in all, though, I'd say the jets have it hands down over pistons, air-cooled or otherwise, although control issues (loss of hydraulic fluid) for jets that lack manual reversion or FBW slightly skew things. Given the choice of doing Art's mission in a P-47/Corsair/Skyraider, or an A-10, I know which one I'd choose, but that's talking a 30 year technology difference. Guy |
Cub Driver wrote:
How and why I have flown military airplanes is none of your business. Sheez. We're supposed to sit here awestruck at the Fighter Pilot Fellowship, but we can't inquire as to how and why you flew military airplanes? Dudley, there is something fishy about you. all the best -- Dan Ford C'mon Dud, obfuscate, you know you're good (albeit kinda obvious) at it... -- -Gord. |
Ed Rasimus wrote in message . ..
On Sun, 7 Dec 2003 16:56:41 +0000, "Paul J. Adam" wrote: In message , ArtKramr writes Let's take two planes going on low level support missions. They will have to fly through heavy ground fire including small arms fire. One plane is equipped with a radial engine,. let's say an R-2800. The other with a jet engine. Which plane would have a better chance of survival inder these conditions?. Opinions? My gut feeling is the jet, if only because it's faster and spends less time being shot at (and the higher deflection makes it harder to hit). Also, jet aircraft can be pretty tough; stories around about them surviving assorted insults (going as far as F-105s flying with destroyed engines, using the afterburner as a sort-of-ramjet) so the survivability between a jet and a radial recip isn't as pronounced. After all, either aircraft is equally at risk from hits to pilot, control surfaces, fuel tanks et cetera... superior survivability of the engine is a factor, but not the only one (vice the use of P-51s rather than P-47s in Korea) Seems to me that you need to define a lot of additional parameters before you can reduce the discussion to whether a radial is more survivable than a jet. If you say same speed, same profile, same airframe, same tactics, same thrust(power) to weight, same performance, then I'd go to the radial engine as being one that sustains a bit more insult. But, we've not added the factor (significant in my mind) about the volatility of AvGas over JP-4 (JP-8). Wet wing airplane taking a hit in the fuel tanks? Not pretty. But, if you let your jet go faster, pull more G, maneuver more aggressively, build a tactics package that suppresses the defenses, etc. then you come up with the undebatable conclusion that the jet does better. Have I ever mentioned that FAST is better? I can feel a Lawndart versus Warthog debate comming on. Douglas Skyraiders seem to have fullfilled niche missions well into the Jet age. By the end of the second world war the Japanese (J7W1 Shinden), USA (Curtiss XP-55 Ascender) and Germans were all testing pusher piston engined aircraft that might have managed 500-520mph and likely 577mph with development. Here is one of the German projections: DO P.247 Max. Speed: 835 km/h (519 mph) http://www.luft46.com/dornier/dop247.html With transonic swept tip "scimatar" shaped propellors: Dornier Do P.252 Max. Speed 930 km/h 577 mph. http://www.luft46.com/dornier/dop252.html So Mach 0.88 was conceivable for a piston engined propellor aircraft with a modest amount of development no more than jet development. Mach 0.88 is Enough to take on early Sabres and Mig 15s! If it had not of been for the development of the Jet engine the two stroke super charged and turbo supercharged engine probably would have attracted development and replaced the petrol piston engine. This type of diesel (eg Napier Nomad) is lighter and more fuel efficient than a petrol engine and runs of diesel and jet fuel to boot. With effort some one could have fielded a Mach 0.88 gasoline or diesel fighter to take on Sabres, Meteors and Mig 15s during the Korean war on close to even terms and probably with a lot more range. The B47D with turbo-prop was once tested at 597mph. In general its was probably not worth diverting the engineering resources into becuase the only gain: fuel efficiency could be circumvented by just flying higher and the speed of sound was the ultimate limit. |
"Cub Driver" wrote in message ... How and why I have flown military airplanes is none of your business. Sheez. We're supposed to sit here awestruck at the Fighter Pilot Fellowship, but we can't inquire as to how and why you flew military airplanes? Dudley, there is something fishy about you. Strange! I don't remember even coming close to requiring you or anyone else on Usenet to be "awestruck" by either myself, my background, or the Fellowship. Perhaps you will be kind enough to provide an example of this........other than the simple fact that I use a tag line sig for the Fellowship. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
"B2431" wrote in message ... From: "Dudley Henriques" "Cub Driver" wrote in message Dudley, would you post a brief bio for us? I think I recall P-51s, but I don't have any notion of your career. When were you in the USAF/USAAF? For whom a commercial pilot? Where taught? I am a civilian pilot Ford, not military. Obviously you haven't yet done enough research. Lots of public record on this. How and why I have flown military airplanes is none of your business. Although I can't stop you from going down the road I believe you're thinking of going with this, I will tell you that I don't like this type of post . Do your own legwork Ford. There are many sources of public information on me, and what's not there, I have no desire to share with someone as obviously hostile to me as you are with this post. I sincerely hope I'm wrong in what I'm reading from your post here. If I am, please feel free to dig up and post anything you wish that's public information on me. If I'm not wrong, I feel compelled to advise you to be extremely careful where you go with this in a public forum. Your call ! Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt Dudley Henriques Am I missing something here? I see nothing "hostile" in the request. I also see nothing wrong with simply saying "I'd rather not say" as a response. Dan, U. S. Air Force, retired There's a history here Dan. I know several of the surviving AVG members personally. I reviewed Ford's book on the AVG after spending a day being briefed on it by a member of the Tigers who wasn't at all happy with his "research". Mr. Ford and I go back a few years, and have our "differences of opinion". Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
"B2431" wrote in message ... Am I missing something here? I see nothing "hostile" in the request. I also see nothing wrong with simply saying "I'd rather not say" as a response. Dan, U. S. Air Force, retired Just for general information; It's considered extremely bad manners to ask for, request, or demand personal background and/or qualifications of any individual on Usenet. These things can be offered in an atmosphere of friendship by someone voluntarily, but not asked for. When this is done, it's almost always done in an atmosphere of hostility. You really need go no further than Mr. Ford's remark, "Dudley, there is something fishy about you" to ascertain this. The inference is that if the person being "asked" to state these things doesn't respond to the poster's demand, that there is something to hide. The reality however, is that only idiots post these "requests", and only idiots allow themselves to be drawn into this scenario. These "requests" as you can see, attract the usual posters who either like or dislike either the poster or the person being "nailed". It's a losing proposition for everyone, and I have no intention of getting involved too deeply with it, as aside from a few people who have become good internet friends on the group through the years, I don't really give a rat's ass who on Usenet believes what about what . Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
Dudley Henriques wrote:
"B2431" wrote in message ... Am I missing something here? I see nothing "hostile" in the request. I also see nothing wrong with simply saying "I'd rather not say" as a response. Dan, U. S. Air Force, retired Just for general information; It's considered extremely bad manners to ask for, request, or demand personal background and/or qualifications of any individual on Usenet. These things can be offered in an atmosphere of friendship by someone voluntarily, but not asked for. When this is done, it's almost always done in an atmosphere of hostility. You really need go no further than Mr. Ford's remark, "Dudley, there is something fishy about you" to ascertain this. The inference is that if the person being "asked" to state these things doesn't respond to the poster's demand, that there is something to hide. The reality however, is that only idiots post these "requests", and only idiots allow themselves to be drawn into this scenario. These "requests" as you can see, attract the usual posters who either like or dislike either the poster or the person being "nailed". It's a losing proposition for everyone, and I have no intention of getting involved too deeply with it, as aside from a few people who have become good internet friends on the group through the years, I don't really give a rat's ass who on Usenet believes what about what . Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt I personally don't give a rat's ass what kind of fighter planes you may or may not have flown, or for whom, or with whom. The fact that you use that tag line infers that you've done something to feel entitled to call yourself one. The initial request seemed rather innocent to me, and I didn't detect any hostility in it. Unfortunately, you managed to overreact in your obviously defensive response to it and stirred up the **** storm that ensued. Personally, I think most of you one-fan fliers have been exposed to too many Gs in your flying careers, with the obvious damaging effect to your gray matter. But that's another argument for another time. (^-^))) George Z. C-45, C-46, C-47, C-53, C-54, EC-121, UC-78, T-6, B-25 and enjoyed every minute in every one of them, and apologize for none because that's what I was ordered to do and I did the best I could and am here to tell you about it. PS - Of course, if you never flew any kind of fighter plane for the military, then you are a phony and don't belong in this NG.....so, please tell me it isn't so, and let's move on to something else. |
#29
"George Z. Bush" wrote in message ... Dudley Henriques wrote: "B2431" wrote in message ... Am I missing something here? I see nothing "hostile" in the request. I also see nothing wrong with simply saying "I'd rather not say" as a response. Dan, U. S. Air Force, retired Just for general information; It's considered extremely bad manners to ask for, request, or demand personal background and/or qualifications of any individual on Usenet. These things can be offered in an atmosphere of friendship by someone voluntarily, but not asked for. When this is done, it's almost always done in an atmosphere of hostility. You really need go no further than Mr. Ford's remark, "Dudley, there is something fishy about you" to ascertain this. The inference is that if the person being "asked" to state these things doesn't respond to the poster's demand, that there is something to hide. The reality however, is that only idiots post these "requests", and only idiots allow themselves to be drawn into this scenario. These "requests" as you can see, attract the usual posters who either like or dislike either the poster or the person being "nailed". It's a losing proposition for everyone, and I have no intention of getting involved too deeply with it, as aside from a few people who have become good internet friends on the group through the years, I don't really give a rat's ass who on Usenet believes what about what . Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt I personally don't give a rat's ass what kind of fighter planes you may or may not have flown, or for whom, or with whom. The fact that you use that tag line infers that you've done something to feel entitled to call yourself one. The initial request seemed rather innocent to me, and I didn't detect any hostility in it. Unfortunately, you managed to overreact in your obviously defensive response to it and stirred up the **** storm that ensued. But that's another argument for another time. (^-^))) George Z. C-45, C-46, C-47, C-53, C-54, EC-121, UC-78, T-6, B-25 and enjoyed every minute in every one of them, and apologize for none because that's what I was ordered to do and I did the best I could and am here to tell you about it. PS - Of course, if you never flew any kind of fighter plane for the military, then you are a phony and don't belong in this NG.....so, please tell me it isn't so, and let's move on to something else. Well, I'll tell you this much. Yes I've flown fighters; not that it matters a hill of beans. The Fellowship was a very real organization , not that that matters much either, since it's not me who is making such a fuss about it ; so unless the tag line is saying something to you through mental telepathy that I wouldn't be saying myself......yes, let's indeed move on to something more intelligent shall we? Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
#30
It's considered extremely bad manners to ask for, request, or demand personal background and/or qualifications of any individual on Usenet. Sorry, I'd never heard of this rule! Must be an outgrowth of The New Yorker cartoon: "On the internet, nobody knows you're a dog." I was just curious, Dudley. Honest to God! I wanted to know about the Fighter Pilot Fellowship. Is Ed Rasimus a member? all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
| Thread Tools | |
| Display Modes | |
| USAFE commander: 86th Airlift Wing will divide for combat, support operations | Otis Willie | Military Aviation | 0 | November 28th 03 12:31 AM |
| Air Force combat search and rescue joins AFSOC team | Otis Willie | Military Aviation | 0 | September 30th 03 10:49 PM |
| Combat Related Special Compensation update for Sept. 8-12 | Otis Willie | Military Aviation | 0 | September 17th 03 04:38 AM |
| Harrier thrust vectoring in air-to-air combat? | Alexandre Le-Kouby | Military Aviation | 11 | September 3rd 03 02:47 AM |
| Team evaluates combat identification | Otis Willie | Military Aviation | 0 | August 18th 03 09:52 PM |
