![]() "Cub Driver" wrote in message ... This is wonderful. Can either of you or anybody point me to more information about this service? I realize there are only 12 issues of Geographic a year, but it would help if I could narrow it down. I've read about the same technique being used in Oz for back country mail. |
![]() "B2431" wrote in message ... It amazes me I can't remember 24 hours ago yet I can remember 35 years ago. Yet the rest of us are amazed when you make up things from 35 years ago, Dan. |
![]() "Hobo" wrote in message ... Has there ever been an aircraft with a gun permanently aligned off-center? I don't mean swivel mounted, but permanently fixed at a point other than straight ahead. Yes Wouldn't a gun pointed at a downward angle make ground attack easier? Possibly but the most obvious examples had the guns pointed UP at around 30 degrees. German nightfighters in WW2 would position themselves below and behind their target and fire at bombers silouhetted against the dark sky. Keith |
The F-14 was tilted up about 3 degrees IIRC. Allowed you to track with less
lead and closure and perhaps less likelihood of hitting the target. R / John "Hobo" wrote in message ... Has there ever been an aircraft with a gun permanently aligned off-center? I don't mean swivel mounted, but permanently fixed at a point other than straight ahead. Wouldn't a gun pointed at a downward angle make ground attack easier? |
![]() "Hobo" wrote in message ... Has there ever been an aircraft with a gun permanently aligned off-center? Yes, several going as far back at least as far as WWI. I'm afraid I'm brain locking on the designations though. In Vietnam B-57 had gun packs fitted that shot down at a very sharp angle- may even have been vertical- for night straffing the trail. I don't mean swivel mounted, but permanently fixed at a point other than straight ahead. Wouldn't a gun pointed at a downward angle make ground attack easier? I don't know why the idea keeps failing to catch on; it could be it's too single purpose for fighters or just not as easy to aim. |
be it's too single purpose for fighters or just not as easy to aim. I think the A-10's gun might be downward pointed a bit... but most fighters wouldn't use a downward-pointing one because it is unsuitable for a-a work. |
"Bob Martin" wrote in message ...
I don't know why the idea keeps failing to catch on; it could be it's too single purpose for fighters or just not as easy to aim. I think the A-10's gun might be downward pointed a bit... but most fighters wouldn't use a downward-pointing one because it is unsuitable for a-a work. The Hog's overall assembly is not on the jet's centerline, but it's arranged so that the firing barrel is centered up, probably perfectly squared, when it fires. Given the power of that particular weapon, I'd be a little surprised if the firing barrel was anything BUT perfectly square to the centerline (both X and Y axis). Of course, I also seem to recall that the shell basically traces a straight line from barrel to "effective range", and doesn't need drop factored in. |
Of course, I
also seem to recall that the shell basically traces a straight line from barrel to "effective range", and doesn't need drop factored in. Eh?... surely you're not saying that the rounds don't drop in flight?...I hope?... Well, I know the firing barrel is centered laterally, but I think the gun itself may be angled down a couple degrees (though still passing through the center of gravity of the aircraft, so as to not produce any pitching moment), though probably not more than 2 or 3. This would help with gun tracking and make strafing runs a little safer. As far as the "straight line" from the barrel... the muzzle velocity of the GAU-8/A is such that, although the bullets do drop in flight (to not do so would either imply lift being generated, or laws of physics being violated), the drop is considered negligible, and therefore the gunsight is a simple fixed reticle in the HUD. For example... at 4000 feet, the bullets will only drop about 10 feet--random dispersion will be greater than that. |
Aircraft Walkaround Center alive and well, new URL | Voigt Lander | Military Aviation | 7 | December 10th 03 04:16 PM |
Center vs. Approach Altitudes | Joseph D. Farrell | Instrument Flight Rules | 8 | October 21st 03 08:34 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Aircraft Walkaround Center update, new section | Robert Lundin | Military Aviation | 0 | August 30th 03 08:12 PM |
PACAF’s Hawaii air ops center sets new goals while adding 109 positions | Otis Willie | Military Aviation | 0 | August 20th 03 09:44 PM |
