flaps again
Old January 2nd 08, 01:04 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
Default flaps again
Hilton wrote:
Dudley wrote:
No flap landings should be handled by instructors as simply another
procedure to be learned. There's nothing earth shattering about a no flap
landing, BUT and this is a BIG BUT HERE......there are aspects of a no
flap landing that are very different from a landing using "flaps as
required", so all CFI's should demonstrate no flap landings and go over
the aspects of no flap landings with every student.
I don't treat this situation as an emergency; simply something the student
must be completely familiar with before solo.
I was in the pattern at night with a student in a C172 at RHV and we had a
total electrical failure. No lights, no flaps, ... I had him hold a
flashlight at the ASI and call out airspeeds, I then did a glassy water
landing - worked perfectly!
Hilton
I can't resist this so forgive me :-))
......and all this after staying at a Hilton and not a Holiday Inn
Express last night? :-))))))))))))))))))))))))
Dudley Henriques
Old January 2nd 08, 02:01 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Roy Smith
Default flaps again
I'm confused -- if he was your student, why did you do the landing? Seems
like a perfect opportunity for a "learning experience".
Old January 2nd 08, 02:02 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Rich Ahrens[_2_]
Default flaps again
I had a complete electrical failure in a C177RG at night on the way from
Duluth to Minneapolis back in 2003. Not wanting to fly into either the
Class B or the Mode C veil without radio contact, I elected to put down
at an uncontrolled field north of the Cities. A buddy was flying a 182
on the same trip a mile or so ahead of me, so I got him on my handheld
and told him the plan. He went in ahead of me, assuring the
pilot-controlled runway lights got turned on and handling any radio
comms that might be needed if any other traffic showed up, while I
circled to make sure I got the gear down. Took a bit of pumping to get
it locked - it was reassuring that the tiny amount of remaining power
was enough to get a green light when it locked. So then it was just a
matter of landing NORDO, no lights, no flaps, in the dark. What fun! I
was sure glad I had practiced all of those, albeit not all at once.
My buddy was waiting on the ramp and said the only thing he saw as I
came in was the runway edge lights blinking out as I rolled past them.
Old January 2nd 08, 04:56 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
DaveB
Default flaps again
On Tue, 01 Jan 2008 10:02:47 -0400, Dave
OK, so I am missing something..
In large , more complex aircraft, I can see the difficulty landing
without flaps.
But in a 172 or a Warrior?
.....with sufficient runway, and in strong winds, I sometimes prefer
no flaps.
My Warrior POH indicates flaps are to be used as needed, no flap
landings are not indicated as requiring an emergency procedure...
In training aircraft?
Dave
I was thinking the same thing, in a PA28-140 anyway,was like a 50-50
with me
Daveb
Old January 2nd 08, 11:35 PM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
Michael[_1_]
Default flaps again
On Dec 30 2007, 9:06*pm, "Kobra" wrote:
First, as a reminder, some may recall that I had unwittingly landed one day
in Williamsburg, VA without the flaps. *I didn't notice they had not
deployed until my next pre-flight when I found them INOP. *They I remembered
out fast I came over the fence and controlling the airspeed was more
difficult then ever before. *I took a lot of heat from other pilots that
basicly said, "How in the world could any pilot worth a darn EVER not
realize that their flaps didn't come out! *THAT would NEVER happen to ME!!"
This is going to be long and rambling, so bear with me.
Those are the same pilots who believe they can never land gear up.
Actually, there are pilots who will certainly never land gear up.
They are the ones who only fly fixed gear airplanes. And then there
are the ones who believe they can't groundloop. The only ones who are
right about this are the ones who don't fly taildraggers. Accidents
can happen to all of us, because none of us are perfect.
The situation is actually very similar when it comes to inadvertent
flaps-up and gear-up landings. Gear and flaps both have aerodynamic
effects when extended/retracted. A very refined airplane (think later-
model Bonanza) will have minimal (if any) trim change with extension/
retraction (this is nice because it reduces pilot workload on
approach), but with most planes you will notice a trim change. And no
matter what, there will be changes in the aural/visual/tactile cues
(the plane will sound different, something will look different, and it
will feel different) as well as a change in power required to maintain
a given speed and glideslope. And yet, year in and year out, pilots
manage to land gear up. I'm sure they land flaps up even more often,
but mostly that doesn't cause any damage so nobody talks about it.
Which brings us to the one (and only) difference between landing flaps
up and gear up. Gear up is expensive, every time. Flaps up is
actually more likely to be fatal (as in, you get too slow in a turn)
but most of the time it costs nothing at all except some extra runway,
which is free. That's it. That's why we hammer on gear up
procedurally and mostly ignore flaps up. Thing is, nobody is perfect
procedurally. I note by your signature that you are flying a
retract. Realize that since your cues for handling are not so well
developed, you are at greater risk than someone whose feel for the
plane is better for gearing it up. However, it's probably nothing
more than being low time, so don't worry about it, it will come.
To understand why you landed flaps up without realizing it, look into
inadvertent gear up landings.
There are two extremes in the pilot population. On one extreme are
those who are 'aware' of everything that goes on around them. On the
other extreme are those who are 'procedural' - they will go through
the motions as they did in training and not notice that things are not
really working out. Of course those are extremes; most pilots fall
somewhere in the middle.
As an instructor, it's pretty easy to tell what sort of pilot you are
dealing with. Whenever I check someone out in a retract with
electrically powered gear, I will always pull the gear circuit breaker
when he's not looking. Sometimes hilarity ensues - as when I have to
call a go-around or missed approach. Sometimes the student catches me
at it.
In an ideal world, the pilot who is 'aware' will realize the gear
isn't coming down because the plane won't slow down/get down, or he
has to pull the power too far back, or it's too 'pitchy' or whatnot.
I've seen that happen quite a bit. That's how the students have
caught me. They would realize something was wrong, then realize what
it probably was, and THEN check the gear indicator. I've also had it
happen to me a couple of times (realize I have 1300+ hours in
retracts). For whatever reason (I got distracted by traffic, for
example), in my normal flying I've forgotten to put the gear down
where I normally do. I always figured it out on final because the
plane did not behave the way it was supposed to - I was pulling the
power too far back and not slowing down properly. THEN I checked the
lever and indicator.
Now ideally a 'procedural' pilot will also catch this. A GUMPS check,
a 'three green on final' check, something. I suppose it must happen
sometimes, but I've never seen it. Never have I seen a student catch
the problem procedurally. I have seen a student say three green when
the lights were most emphatically not green. I've seen a student say
"three green and one in the mirror" when there was nothing but closed
gear doors in the mirror and no green lights at all. I find it very
unfortunate that the FAA forbids doing this (pulling breakers) on
checkrides, thus assuring that most CFI's won't do this with their
students.
One of the things that insurance companies look for when you step into
a retract is total time. A guy with 1000 total hours, all of them in
fixed gear airplanes, will have relatively little problem getting
insured in something like a Bonanza. A guy with 100 total hours may
find himself uninsurable at any price - and having 10 of those hours
in an Arrow won't likely make any difference. That's because
insurance companies know the score - hours don't guarantee that a
pilot will become aware of his aircraft and environment, but lack of
hours nearly guarantees that he won't.
Then it hit me...how in the world could he have flaps 30 with 16 or 17
inches of MP at our decent rate and be out of the white arc. *That is not
possible. *I looked over my right shoulder and saw the reason...the flaps
were fully retracted.
See, this is what I am talking about. First, you figured out that
something was wrong (awareness). THEN you checked procedurally.
That's how I've always seen it happen - never the other way around.
So why did you figure it out this time but not when it happened to
you? One, you had it happen to you before so you were more primed for
it. Some say experience is what lets you recognize the mistake the
second time you make it. Two, you were not flying the plane so you
had more mental 'cycles' left over for thinking. One of the things
that happens as you get more hours is that more things become
automatic, and you find easier, less workload-intesive ways to do
things - which frees up cycles. That's where awareness comes from -
having spare cycles to think about stuff.
So when do you have spare cycles? Well, you usually have some in
cruise. Once you get used to noticing stuff in cruise (even a 50 hour
pilot has enough cycles left over in cruise to notice stuff) you get
in the habit of doing it all the time.
One of the reasons I am so down on these programs that take you from
zero time to CFI/CFII/MEI in 300 hours is because they don't give you
near enough opportunity to just be with the airplane - to just fly
somewhere. Instead, you are always cramming new procedures, new
checklists, new this, new that - and all of it procedurally (because
it's the only way to do it in so few hours). You still make mistakes
and forget stuff, of course - but you don't really learn from them.
It's all seen as failure to follow the correct procedure - and of
course it is, but you have to realize that everyone is going to do
that sometimes, and the more procedures and checklists you run, the
more likely you are to miss some item. The solution is not more
checklists and procedures - what is needed is to develop what we used
to call in skydiving instruction 'air awareness' - and what might best
be called situational awareness. But that's going to take time, and
it requires unstructured time. Ever wonder why you could get every
fixed wing certificate and rating by 250 hours (less if Part 141) but
the ATP requires 1500 and IFR PIC under Part 135 requires 1200? Well,
that's the logic, and it's somewhat sound.
Now of course awareness is not perfect either (which is why I don't
advocate throwing away checklists) and with enough distraction anyone
can miss anything. When I was doing recurrent training and flying a
single engine partial panel ILS with some other failures and twists
thrown in, I forgot to put the gear down (I caught it when I pulled
the power back to land and the gear horn went off - and the instructor
called the go around at that point). One time on a partial panel
single engine circling NDB, I forgot to put down the flaps (the
instructor just let me do it - there was enough runway). With enough
other stuff being abnormal, one more abnormal may not show up. This
is where a checklist may really save you (or not - if it gets that
busy, you may not have the time for it).
I kind-of feel vindicated that another pilot had the same mild distractions
in the pattern, was setting his flaps as always and never noticed at each of
three changes that no flaps what-so-ever were being provided.
Some level of distraction will be enough for anyone some of the time.
I've managed to set up a 15000+ hour ATP that way while doing his
recurrent training. On the other hand, mild distractions in the
pattern ought not to be enough that you don't notice that the flaps
have failed to work. It indicates that you need to get more in tune
with your airplane. So go fly some more. Not train, fly. Go
somewhere. Enjoy the sight, sound, and feel of flying. Become one
with the airplane. Yeah, I know, it sounds more mystical that
practical, but trust me. This will work itself out.
Michael
Old January 3rd 08, 02:49 AM posted to rec.aviation.owning,rec.aviation.piloting,rec.aviation.student
Michael Ash
Default flaps again
Thank you for an excellent post. Since getting my PPL this past spring
I've occasionally felt like some of my subsequent flying time was wasted
compared to before. In training I was always learning something new. And
truly, even after I passed the checkride, I think I've done a good job of
expanding my limits without becoming reckless, and I've definitely learned
a lot since then. But sometimes when I was up there just having a little
fun I'd think somewhere in the back of my head that maybe I could be doing
more, pushing more, learning more.
You've made me realize that this time is still valuable and still makes me
a better pilot even if I'm not consciously pushing my limits. I never
hesitated about going up and just having some fun but it's good to realize
that it's still valuable experience. Thanks!
Michael Ash
Rogue Amoeba Software
Old January 3rd 08, 05:15 AM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
Default flaps again
Unless you are landing on a minimal runway, as we often do
out here in the Canadian west. An inadvertent flaps-up landing can get
really messy at the far end, depending on the obstacles that might be
there. Tall grass, not so bad. Fence, gonna scratch the airplane some.
Trees, not good. Big trees, bad. Mud, gonna get the top of the
airplane really dirty and dented. Big rocks, very bad. Lots of scrap
metal and maybe scrap people. Water, well...I hope you survive long
enough to get out of the airplane.
So pay attention to what the airplane is telling you.
Dan
Old January 3rd 08, 09:16 AM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
Ken S. Tucker
Default flaps again
there.
Not really, you just need to learn how to land better,
making use of flare and ground effect.
Landing with zero flaps, needs a tricky extended flare
and once the tires are on the runway, keep the nose up,
with pitch control to the elevator, that way the entire
main wing operates as an air brake.
Be very gentle on wheel braking control because that
will lower the nose, and you want the nose as high
as possible, while rolling.
Once the nose falls, it's hard to get it up because of
the relation of the CM to the wheel contact point on
the ground. At a high AOA, the CM is pretty close
to the vertical location of the wheel contact point,
and the elevator is effective.
The key is to understand the wheel contact point in
relation to the CM. Most A/C with tricycle gear are
designed to keep the weight on the mains and keep
the forward lightly loaded.
Ken
Old January 5th 08, 04:32 AM posted to rec.aviation.owning, rec.aviation.piloting, rec.aviation.student
Bertie the Bunyip
Default flaps again
up and gear up. *Gear up is expensive, every time. *Flaps up is
which is free. *That's it.
* * * * *Unless you are landing on a minimal runway, as we often do
there.
Ken
Good grief.
Bertie
flaps again Kobra Piloting 107 January 5th 08 04:31 PM
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
flaps Kobra[_4_] Owning 85 July 16th 07 06:16 PM
Cowl Flaps N114RW Home Built 0 June 27th 07 09:25 PM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
