Heathrow = Thrust Reversers deployed
Old January 20th 08, 02:49 PM posted to alt.disasters.aviation,rec.aviation.piloting
Mxsmanic
Default Heathrow = Thrust Reversers deployed
Eeyore writes:
Why just Boeing ?
Airbus made the FBW mistake almost from the beginning, years before Boeing.
They're not.
So, how many times have all mechanical throttle linkages broken on an
airliner?
Old January 20th 08, 03:50 PM posted to rec.aviation.piloting
Bertie the Bunyip[_22_]
Mxsmanic wrote in
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
airliner?
Several, moron.
In fact, I've had a double throttle jam!
Bertie
Old January 20th 08, 04:04 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
airliner?
Plenty, fjukkwit. I've had several double throttle jams myself, moron.
Bertie
Old January 20th 08, 04:39 PM posted to rec.aviation.piloting
Chris Rowland
Bertie the Bunyip wrote:
Mxsmanic wrote in
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
airliner?
Of course you have, flying your rubber band airplanes!
Say fjukkwit again, we can't get enough of your nonsense! Thank goodness
you are around to bless us.
Old January 20th 08, 04:47 PM posted to rec.aviation.piloting
Chris Rowland wrote in news:4793793D.C8EE11E6
@spamners.quit:
Mxsmanic wrote in
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
an
airliner?
moron.
goodness
My pleasure
Really.
Bertie
Old January 20th 08, 08:53 PM posted to alt.disasters.aviation,rec.aviation.piloting
Keith Willshaw
"Mxsmanic" wrote in message
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
airliner?
Mechanical throttle linkages went out with the DC3, all modern
aircraft since the 1950's have had electrical or electro-mechanical control
systems. Early engines so equipped include the Bristol Siddeley
Viper designed in 1953
While not used on commercial aircraft they have indeed caused failures
on GA aircraft, an airworthiness directive for the Pt-220C reads
Quote
Instances have been reported of throttle quadrants pulling off the fuselage
skin to which they were glued and nailed during manufacture. Both front and
rear cockpit throttle quadrants must therefore be inspected for looseness
immediately and if found loose must be repaired prior to the next flight
/Quote
Think about the problem of running a mechanical control system
to the engine hanging on a Boeing 707 pylon. In fact FADEC's
have contributed to the far greater reliability of modern engines.
Keith
Old January 20th 08, 09:05 PM posted to rec.aviation.piloting
"Keith Willshaw" wrote in
Eeyore writes:
Why just Boeing ?
Boeing.
They're not.
airliner?
control systems. Early engines so equipped include the Bristol
Siddeley Viper designed in 1953
The brits were the ony ones who did that.
Quote
fuselage skin to which they were glued and nailed during manufacture.
Both front and rear cockpit throttle quadrants must therefore be
inspected for looseness immediately and if found loose must be
repaired prior to the next flight /Quote
Actually, that is exaclty what they did have. Every boeing before this
one had a mechanical linkage up to the FCU. I'm absolutely sure about
this BTW.
Bertie
Old January 20th 08, 09:09 PM posted to alt.disasters.aviation,rec.aviation.piloting
Mxsmanic
Keith Willshaw writes:
systems.
How often have those completely failed?
on GA aircraft ...
GA aircraft are a different world.
  #29
Old January 20th 08, 09:21 PM posted to rec.aviation.piloting
Mxsmanic wrote in
control systems.
failures on GA aircraft ...
No they aren't.
Bertie
  #30
Old January 21st 08, 12:34 AM posted to alt.disasters.aviation,rec.aviation.piloting
Eeyore[_2_]
systems.
Have you ever driven a car whose accelerator, clutch or handbrake stopped working
Graham
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 1 January 19th 08 08:58 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 17 January 19th 08 08:57 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 3 January 19th 08 08:57 PM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 1 January 19th 08 06:35 AM
Heathrow = Thrust Reversers deployed Eeyore[_2_] Piloting 2 January 19th 08 06:33 AM
