#21
![]() "Bertie the Bunyip" wrote In fact, I've heard the opposite, that the Jabirus seldom make it past 500 hours and often a lot less before needing a rebuild.. Yeah, I've heard that is about right for the early ones. The scuttlebutt is that they learned some lessons, and redesigned some things, and that their power and reliability is now much, much improved. -- Jim in NC |
"Morgans" wrote in
: "Bertie the Bunyip" wrote In fact, I've heard the opposite, that the Jabirus seldom make it past 500 hours and often a lot less before needing a rebuild.. Yeah, I've heard that is about right for the early ones. The scuttlebutt is that they learned some lessons, and redesigned some things, and that their power and reliability is now much, much improved. Well, they'r nice looking little thnkgs and the power to weight is really impressive! I hope they do establish themselves There's a big market for them... Bertie |
You need to do some reading over in rec.aviation.homebuilt. *A guy over
there will tell you that a VW can not do that many HP continuous, and for good reason, I think. Try this link, http://bobhooversblog.blogspot.com and read "The Christmas Engine" (I think that is the name of the article) -- Jim in NC Well, I didn't say it could. I've read that too, and I don't doubt it. |
there will tell you that a VW can not do that many HP continuous, and for good reason, I think. Try this link, http://bobhooversblog.blogspot.com and read "The Christmas Engine" (I think that is the name of the article) -- Jim in NC Well, there's always a guy somewhere on the internet that will tell you something for free. I don't like articles about car engines that try to draw analogies to sex. That doesn't tell you jack-all from a technical standpoint. Absolutely worth zero except yah, if you build an engine yourself you can expect to maintain it yourself, and you'll have to put in a lot of hours -- it's like changing diapers. Not quite the same, in my view. I like working on engines but surely did not like changing diapers. If you're the builder, and you're the one who does the maintenance on the engine, you're going to be working on it regardless of what kind it is. Technical matters demand a technical approach, not weak analogies. The kind of technical writing on the internet that I respect is the kind of stuff William Wynn puts out about Corvairs, for instance. |
Engine" (I think that is the name of the article) -- Jim in NC Okay, found the Christmas Engine. Much better! |
![]() Yes, but show me a standard VW head that does not melt down at more than an honest 50 HP continuous, and I'll change my tune. *I don't think I'll have to buy a new songbook anytime soon! *They just can not get rid of any more waste heat than that. -- Jim in NC Hoover write's about thrust being more important that HP. That jibes with other stuff I've read. The christmas engine blog sounds like he's doing all this direct drive? Can you really get max HP out of an automobile engine at lower RPMs required for a prop not to spin too fast? Don't you pretty much have to have a PSRU to match max auto engine HP to sub-sonic prop RPM? Well, okay this should be asked over on homebuilts. Anyway the OP was all about having fun in low n slow. I think these guys are outrageously low n slow. |
![]() wrote Hoover write's about thrust being more important that HP. That jibes with other stuff I've read. The christmas engine blog sounds like he's doing all this direct drive? Since HP (and therefore heat) is the limiting factor with VW, you can easily hit the maximum thermal HP and still keep the engine at low prop RPM's. No need to rev fast with a PSRU and be limited to part throttle to keep it cool. It would just mean more weight to haul around. Can you really get max HP out of an automobile engine at lower RPMs required for a prop not to spin too fast? Don't you pretty much have to have a PSRU to match max auto engine HP to sub-sonic prop RPM? No, if you go direct drive with most auto engines, you are being satisfied with lower HP levels than would be possible with a reduction unit. It still would be a sizeable amount of HP, but less HP per pound than airplane engines, since auto engine blocks are usually so massive. You look at an engine torque and HP graph produced from a dyno, and where the torque curve crosses the HP curve is usually close to the ideal speed to run the engine for maximum power and thrust. At those RPM's at wide open throttle, the HP per weight is in line with conventional airplane engines, and probably a little better. Many times, you will see people run a little lower RPM than that intersection, for noise, fuel economy, and for engine longetivity. Well, okay this should be asked over on homebuilts. Anyway the OP was all about having fun in low n slow. I think these guys are outrageously low n slow. Yep. If you want to learn more, there are many people over there that know their stuff, and still quite a few that are anti auto engine maniacs. Like always, you sort through it and use what you can. -- Jim in NC |
![]() "Bertie the Bunyip" wrote Well, they'r nice looking little thnkgs and the power to weight is really impressive! I hope they do establish themselves There's a big market for them... Yep. I hope the world beats a path to their doors. Have you seen the 8 cylinder that they are about to put out? Can you imagine how that thing must sound? Sweet! I'll bet it is smooth, too. -- Jim in NC |
#29
"Morgans" wrote in
: "Bertie the Bunyip" wrote Well, they'r nice looking little thnkgs and the power to weight is really impressive! I hope they do establish themselves There's a big market for them... Yep. I hope the world beats a path to their doors. Have you seen the 8 cylinder that they are about to put out? Well, pics of it in SA or kitplanes or something. Can you imagine how that thing must sound? Sweet! I'll bet it is smooth, too. It's nice to see the future is being assured somehow! I was looking at one of the Aussie Rotecs. Still might, but there's a new Czech radial that also looks interesting. OTOH I might just keeep the old radial! Bertie |
#30
![]() Yeah, an automotive conversion really doesn;t appeal to me for a lot of reasons. Some VW designs are realyl fun though! And breaths there a pilot with a soul so dead as to not turn and look at a nice model A poswered Piet? ------------------------------------------------------------------------ There are any number of modern industrial engines, some weighing less than the Model A, that produce an honest 65 to 85 hp at 1800 to 2200 rpm. -R.S.Hoover |
STOL Plans | M. | Home Built | 52 | August 4th 06 06:47 AM |
Zenith STOL 801 | R.W. Behan | Home Built | 2 | May 24th 06 02:34 PM |
BD-4. wings on a V-6 STOL? | Jim Rodgers | Home Built | 5 | August 31st 05 09:59 PM |
WTB Cessna 150/150 STOL | brewmaster1 | Aviation Marketplace | 0 | March 21st 05 02:30 AM |
206 STOL | DeltaDeltaDelta | Piloting | 11 | December 20th 03 09:39 PM |
