#21
![]() wrote in message ... Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. :-) I am feeling profound today... How do they get a cab? Tom C |
On Feb 7, 6:00*am, Mxsmanic wrote:
writes: And to answer your next post before you post it: What molecules? http://en.wikipedia.org/wiki/Outer_space "While not being an actual perfect vacuum, outer space contains such sparse matter that it can be effectively thought of as one. The pressure of interstellar space is on the order of 10 pPa (1×10-11 Pa)." So, no molecules. *And no friction. Even if you don't wish to consider the hard vacuum of space as perfect, with a pressure that is 10,000,000,000,000,000 times lower than that of Earth at sea level, the friction should be also that much lower, and thus the speed of a taxi should be trillions of times faster. *The speed of light is only fifteen million times faster than a 40-knot taxi, so nearly the speed of light might well be achieved long before any residual friction could have any effect. The resistance is a function of the density of gas molecules not pressure density is related to pressure by D=PM/RT M=molecular wt P=pressure R=gas constant T=temperature ( absolute ) ie the lower the temperature the higher the density so what is the temperature in interestella space? Resistance is also a function of the velocity squared. think about how bit a number is c sqaured. Terry PPL Downunder |
![]() "Mxsmanic" wrote : Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. The corollary to that would logically be that any object entering the atmosphere from outer space would instantly decelerate to zero speed. From this logically follows that any meteorites that succeed through the atmosphere and hit Earth have an initial velocity faster than the speed of light. I think the meaning of logic got slighty warped as Mx's spacecraft passed the most recent black hole. ;-) |
On Feb 6, 11:51*am, Mxsmanic wrote:
writes: Molecules There aren't any molecules in space. *It's a hard vacuum. A hard vacuum has lots of molecules. If you start going very fast, they are going to hit you pretty hard. There is no such thing as truly empty space... |
On Feb 6, 12:02*pm, Mxsmanic wrote:
Robert M. Gary writes: On Feb 6, 9:24*am, Mxsmanic wrote: writes: Fixed-wing aircraft taxi because their wheels reduce friction as they move forward on the ground. So, logically, spacecraft in the frictionless environment of outer space should immediately accelerate to the speed of light. No, it still takes energy to accelerate a mass, even in a frictionless environment. But the original post said that aircraft taxi because their wheels reduce friction. *No mention of energy or force. *So if the statement is true, movement results from a lack of friction alone, so zero friction should produce infinite speed (or lightspeed if one allows the speed of light as an absolute upper limit). However, space (especially near space) is not frictionless. Nor does friction produce acceleration. *QED. Your post about airplanes flying stated that it was because of the wings, no mention of energy or force, moron! |
Tina writes:
Gee, where would the energy come from to cause the acceleration? Exactly. |
terry writes:
The resistance is a function of the density of gas molecules not pressure density is related to pressure by D=PM/RT M=molecular wt P=pressure R=gas constant T=temperature ( absolute ) ie the lower the temperature the higher the density so what is the temperature in interestella space? The classic gas laws only work when a volume of gas is contained. |
#29
On Feb 6, 2:22*pm, Benjamin Dover wrote:
wrote in news:f5468d8b-0d97-452a-babc- : *There is no such thing as truly empty space... Sure there is. *It is located between Mxsmanic's ears. I stand corrected... |
#30
yrb-49-taxi.jpg | [email protected] | Aviation Photos | 2 | September 25th 07 09:50 PM |
Hanoi Taxi | john smith | Piloting | 0 | April 27th 06 03:48 AM |
License To Taxi? | SteveT | Piloting | 29 | October 16th 05 04:57 PM |
Leaning for taxi | Jim Rosinski | Piloting | 28 | September 12th 04 03:53 AM |
taxi in reverse? | [email protected] | Owning | 20 | February 21st 04 12:26 AM |
