Our Macauley prop was last overhauled (new blades) in 1991. It was
re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. It's still in spec, doesn't leak, works fine. Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of this thing. When the heck do you replace a prop? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay Honeck wrote:
Our Macauley prop was last overhauled (new blades) in 1991. It was re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. It's still in spec, doesn't leak, works fine. Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of this thing. When the heck do you replace a prop? When it's age makes you nervous. Happy Flying! Scott Skylane |
I would only replace a prop if it suffered damage or failed to meet
the specifications. The prop on my plane (C-182) was overhauled in 1980 and again in 1996 - my mechanic recommended it due to "Time in Service" - meaning calendar years since last O/H. The prop shop said it was in better shape than most of the ones they see. This prop, also a McCauley, has been basically trouble free. An overhaul is a lot less expensive than replacement. If that would buy you peace of mind, go for it! David Johnson |
Dave wrote:
I would only replace a prop if it suffered damage or failed to meet the specifications. The prop on my plane (C-182) was overhauled in 1980 and again in 1996 - my mechanic recommended it due to "Time in Service" - meaning calendar years since last O/H. The prop shop said it was in better shape than most of the ones they see. This prop, also a McCauley, has been basically trouble free. An overhaul is a lot less expensive than replacement. If that would buy you peace of mind, go for it! David Johnson Jay's prop is a constant speed prop, which means it is the internal stuff (wear and corrosion) he's got to worry about. If allowed to go too far, it could mean a small problem becomes an unrepairable prop. Also, internal corrosion can lead to a blade separation. Jay, the prop manufacturers state a 5 or 6 year TBO. You are 3x that. I think it is time. |
![]() Ray Andraka wrote: Dave wrote: I would only replace a prop if it suffered damage or failed to meet the specifications. The prop on my plane (C-182) was overhauled in 1980 and again in 1996 - my mechanic recommended it due to "Time in Service" - meaning calendar years since last O/H. The prop shop said it was in better shape than most of the ones they see. This prop, also a McCauley, has been basically trouble free. An overhaul is a lot less expensive than replacement. If that would buy you peace of mind, go for it! David Johnson Jay's prop is a constant speed prop, which means it is the internal stuff (wear and corrosion) he's got to worry about. If allowed to go too far, it could mean a small problem becomes an unrepairable prop. Also, internal corrosion can lead to a blade separation. Jay, the prop manufacturers state a 5 or 6 year TBO. You are 3x that. I think it is time. Props should last a good long time. Time doesn't hurt metal. I've got a 50 year old prop on my bonanza and it is still well within specifications and most of all safe. I'd hate to say it, but overhauling a propeller is one of the worst things to do for the longevity of a prop. It's best to have it serviced at timely intervals. Every time a prop is overhauled the blades are re-profiled and become smaller until they won't meet specifications. Prop shops love this since they will soon sell you new blades. If you get the prop serviced, only the components that need attention will get attended to. Generally this is just a clean and an inspection and maybe just a dressing of the blades. |
On Feb 13, 7:38*pm, "Jay Honeck" wrote:
Our Macauley prop was last overhauled (new blades) in 1991. *It was re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. *It's still in spec, doesn't leak, works fine. * Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. *He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of this thing. When the manufactor gets the FAA to approve an AD requiring you replace it. Otherwise you can just replace parts (blades, hubs, etc). Most prop shops believe that the Hartzell thing is just the begining and that within the next 4 years the FAA will ensure that all props made before 2000 are out of service. The prop manufactors have been doing a lot of lobbying and want the pre-2000 props out of service for liability. -Robert |
On Feb 13, 10:45*pm, Clark wrote:
"Robert M. Gary" wrote in news:4303e288-e62a-4708-aee3- : On Feb 13, 7:38*pm, "Jay Honeck" wrote: Our Macauley prop was last overhauled (new blades) in 1991. *It was re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. *It's still in spec, doesn't leak , works fine. * Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. *He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of th is thing. When the manufactor gets the FAA to approve an AD requiring you replace it. Otherwise you can just replace parts (blades, hubs, etc). Most prop shops believe that the Hartzell thing is just the begining and that within the next 4 years the FAA will ensure that all props made before 2000 are out of service. The prop manufactors have been doing a lot of lobbying and want the pre-2000 props out of service for cash flow. -Robert I corrected the mis-spelling of cash flow as "liability." I'm sure you meant to spell it correctly and just wanted to be sure it was right. Or mabye we're 'posed to believe that a prop fatigues out just setting on the ramp or in a hangar. -- --- there should be a "sig" here- Hide quoted text - - Show quoted text - The scary part is the vast majority don't see this tactic as wrong... Downright fraud...... |
The only thing I can see as a concern is if there is corrosion happening
inside the hub or on the roots of the blade. I got rid of mine, very low time like yours but they were 1983 vintage. Here they are pulled apart every five years for inspection. If the prop concerns you, what about the age of the aircraft? ; ) John Jay Honeck wrote: Our Macauley prop was last overhauled (new blades) in 1991. It was re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. It's still in spec, doesn't leak, works fine. Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of this thing. When the heck do you replace a prop? |
On Feb 14, 7:19 am, The Visitor
wrote: The only thing I can see as a concern is if there is corrosion happening inside the hub or on the roots of the blade. I got rid of mine, very low time like yours but they were 1983 vintage. Here they are pulled apart every five years for inspection. If the prop concerns you, what about the age of the aircraft? ; ) John Jay Honeck wrote: Our Macauley prop was last overhauled (new blades) in 1991. It was re-sealed and checked by a prop shop in 1997. It has approximately 2400 hours on it. It's still in spec, doesn't leak, works fine. Our A&P owned a prop shop in the 1990s, and is very knowledgeable about these things -- but even he has no hard & fast rule of thumb for replacement of a prop. He's very much a "condition" guy (and it's apparently in good condition), but I'm getting nervous about the age of this thing. When the heck do you replace a prop? For you Americans, FAR 43.13 says this: (a) Each person performing maintenance, alteration, or preventive maintenance on an aircraft, engine, propeller, or appliance shall use the methods, techniques, and practices prescribed in the current manufacturer's maintenance manual or Instructions for Continued Airworthiness prepared by its manufacturer, or other methods, techniques, and practices acceptable to the Administrator, except as noted in §43.16. He shall use the tools, equipment, and test apparatus necessary to assure completion of the work in accordance with accepted industry practices. If special equipment or test apparatus is recommended by the manufacturer involved, he must use that equipment or apparatus or its equivalent acceptable to the Administrator. For us Canucks, CAR 571.02 says something very similar: 571.02 (1) Subject to subsection (2), a person who performs maintenance or elementary work on an aeronautical product (b) equivalent to those specified by the manufacturer of that aeronautical product in the most recent maintenance manual or instructions for continued airworthiness; or (c) in accordance with recognized industry practices at the time the maintenance or elementary work is performed. The kicker comes in the phrases such as "shall use the methods, techniques, and practices prescribed in the current manufacturer's maintenance manual or Instructions for Continued Airworthiness prepared by its manufacturer" (US) or "shall use the most recent methods, techniques, practices, parts, materials, tools, equipment and test apparatuses that are (a) specified for the aeronautical product in the most recent maintenance manual or instructions for continued airworthiness developed by the manufacturer of that aeronautical product" (Canada). These refer to the entire maintenance manual for that product, and that manual usually has TBOs listed. For private aircraft, the government here doesn't get too worried about the six-year/2000 hour life specified for our McCauley props, but they sure hold us Commercial operators to it. If a manufacturer has published no spec, it's ten years, in Canada, between "corrosion inspections," which still means opening the prop. The prop is easily the most highly stressed part on the airplane, operating much closer to its limits of strength than the rest of the airframe might be. Corrosion in the hub, cracking, wear, or past overspeeding all contribute toward potential and lethal failure. Throwing a blade is not unheard of, and a lost blade usually means a lost engine and some serious CG issues immediately afterward. That said, prop failures make up a tiny minority of aircraft accidents, I think. Dan |
The Visitor wrote:
The only thing I can see as a concern is if there is corrosion happening inside the hub or on the roots of the blade. I got rid of mine, very low time like yours but they were 1983 vintage. Here they are pulled apart every five years for inspection. If the prop concerns you, what about the age of the aircraft? ; ) John The aircraft isn't getting subjected to the forces the prop hub gets subjected to. IIRC, the number I heard was something like 20 tons of force pulling out on the prop hub, and if you've ever seen a slow motion video of a spinning prop, you'd be amazed at how flexible those blades really are. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
IFR GPS replace DME / ADF? | [email protected] | Instrument Flight Rules | 21 | May 15th 06 03:13 PM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Military Aviation | 265 | March 7th 04 09:28 AM |
Why not use the F-22 to replace the F/A-18 and F-14? | Guy Alcala | Naval Aviation | 2 | February 22nd 04 06:22 AM |
Replace (Fix) ADF? | Tom Nery | Owning | 32 | November 3rd 03 03:30 PM |
