#21
On Mar 9, 8:38 pm, Bertie the Bunyip wrote:
Dan wrote : On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? There's nothing to kick. It has a Brake pedal out of a 39 nash on the floor and that's it. Bertie holy cow... so you expect to side load? |
On Mar 9, 8:46 pm, Bertie the Bunyip wrote:
so you expect to side load? Yep, the gear was well able for it. A lot of people land everything like this. Bertie Very true... |
Dan wrote in news:a4415af9-1a64-432d-9961-7ac8559a56a4
@m3g2000hsc.googlegroups.com: On Mar 9, 8:46 pm, Bertie the Bunyip wrote: so you expect to side load? Yep, the gear was well able for it. A lot of people land everything like this. Bertie Very true... I even saw an ex-super cub to be landed in a farily stif crosswind like this. One can only wonder. |
Dan wrote:
On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? Aside: Maybe the Lufthansa FO learned in an Ercoupe? Dan Bertie called it right in his answer to this. It was the weirdest feeling trust me. You eventually got used to it, but there really was nothing under the panel on the floor except that stupid little brake pedal. Some say they got some comfort out of pressing down on that brake pedal during the last few feet in the flare. You crabbed it into the wind and flew it onto the ground sometimes looking at the side of the runway :-)) It kicked itself out ok. The gear was good and tough. You land the F16 the same way BTW. You can't put a wing down in the Viper and landing it in the crab is regular procedure. I never got used to crab landings in the high performance airplanes that I flew. I always had a tendency to want to lower that windward wing, usually doing that just a bit anyway to ease the touchdown as much as possible. Of course aircraft like the Viper have a rudder to help a bit with that. :-)) -- Dudley Henriques |
On Mar 9, 9:04 pm, Dudley Henriques wrote:
Dan wrote: On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? Aside: Maybe the Lufthansa FO learned in an Ercoupe? Dan Bertie called it right in his answer to this. It was the weirdest feeling trust me. You eventually got used to it, but there really was nothing under the panel on the floor except that stupid little brake pedal. Some say they got some comfort out of pressing down on that brake pedal during the last few feet in the flare. You crabbed it into the wind and flew it onto the ground sometimes looking at the side of the runway :-)) It kicked itself out ok. The gear was good and tough. You land the F16 the same way BTW. You can't put a wing down in the Viper and landing it in the crab is regular procedure. I never got used to crab landings in the high performance airplanes that I flew. I always had a tendency to want to lower that windward wing, usually doing that just a bit anyway to ease the touchdown as much as possible. Of course aircraft like the Viper have a rudder to help a bit with that. :-)) -- Dudley Henriques I'd imagine it was a sudden twist once the mains hit! I remember watching B-52s land -- there was no way to do a wing low in a Buff -- the wings were already hanging down even with the belly! Looking back on the weather they used to fly in, they had brass ones, those guys... Dan |
Dan wrote:
On Mar 9, 9:04 pm, Dudley Henriques wrote: Dan wrote: On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? Aside: Maybe the Lufthansa FO learned in an Ercoupe? Dan Bertie called it right in his answer to this. It was the weirdest feeling trust me. You eventually got used to it, but there really was nothing under the panel on the floor except that stupid little brake pedal. Some say they got some comfort out of pressing down on that brake pedal during the last few feet in the flare. You crabbed it into the wind and flew it onto the ground sometimes looking at the side of the runway :-)) It kicked itself out ok. The gear was good and tough. You land the F16 the same way BTW. You can't put a wing down in the Viper and landing it in the crab is regular procedure. I never got used to crab landings in the high performance airplanes that I flew. I always had a tendency to want to lower that windward wing, usually doing that just a bit anyway to ease the touchdown as much as possible. Of course aircraft like the Viper have a rudder to help a bit with that. :-)) -- Dudley Henriques I'd imagine it was a sudden twist once the mains hit! I remember watching B-52s land -- there was no way to do a wing low in a Buff -- the wings were already hanging down even with the belly! Looking back on the weather they used to fly in, they had brass ones, those guys... Dan The Buff has an ace in the hole. It has a crosswind gear that can be set to align with the runway while the fuselage stays canted into the wind. Watching one of those beasts land is a hoot :-) -- Dudley Henriques |
Dan wrote:
On Mar 9, 9:04 pm, Dudley Henriques wrote: Dan wrote: On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? Aside: Maybe the Lufthansa FO learned in an Ercoupe? Dan Bertie called it right in his answer to this. It was the weirdest feeling trust me. You eventually got used to it, but there really was nothing under the panel on the floor except that stupid little brake pedal. Some say they got some comfort out of pressing down on that brake pedal during the last few feet in the flare. You crabbed it into the wind and flew it onto the ground sometimes looking at the side of the runway :-)) It kicked itself out ok. The gear was good and tough. You land the F16 the same way BTW. You can't put a wing down in the Viper and landing it in the crab is regular procedure. I never got used to crab landings in the high performance airplanes that I flew. I always had a tendency to want to lower that windward wing, usually doing that just a bit anyway to ease the touchdown as much as possible. Of course aircraft like the Viper have a rudder to help a bit with that. :-)) -- Dudley Henriques I'd imagine it was a sudden twist once the mains hit! I remember watching B-52s land -- there was no way to do a wing low in a Buff -- the wings were already hanging down even with the belly! Looking back on the weather they used to fly in, they had brass ones, those guys... And gear that could be turned to align with the direction of travel... Matt |
#29
![]() "Bertie the Bunyip" wrote in message ... Dan wrote in : On Mar 9, 8:23 pm, Dudley Henriques wrote: I've flown the Ercoupe. Not much to it really. It was fun running the side windows down and flying along with my arm out on the edge of the cockpit sort of like in a car. The landings were a bit different if you had any crosswind at all, but easily doable in the crab. Take off was the same. As soon as you broke ground, it weather vaned into the wind with aileron. Sort of a "spooky" little airplane but it flew quite well and was quite fast for its day. The one I flew didn't have the later rudder capability. Never flew the Alon. -- Dudley Henriques Are you supposed to kick out the crab or land crabbed? There's nothing to kick. It has a Brake pedal out of a 39 nash on the floor and that's it. Bertie One of my chapter members has been flying one forever, and looking in at that little square mushroom sticking in the middle of the left half of the floor is just a little unsettling. OTOH, watching the prop as he taxies past, with the strange angle at which the engine is mounted is at least as weird. It does handle uneven ground quite well though. Peter |
#30
Ercoupe Opinions | Doofus P. Leadbottom | Owning | 17 | August 24th 05 10:16 PM |
Jay Honeck Ercoupe on a roof | [email protected] | Piloting | 6 | July 13th 05 10:54 PM |
Jay Honeck-Ercoupe on a roof | [email protected] | Owning | 0 | July 11th 05 12:19 AM |
Around the Rim in an Ercoupe | Bob Fry | Piloting | 1 | April 30th 04 04:09 AM |
What do you think about ercoupe | ianf | Owning | 9 | August 27th 03 11:48 PM |
