This information, taken from the Air Traffic Control Handbook, may be
useful: "3-1-3. USE OF ACTIVE RUNWAYS The local controller has primary responsibility for operations conducted on the active runway and must control the use of those runways. Positive coordination and control is required as follows: NOTE- Exceptions may be authorized only as provided in para 1-1-10, Constraints Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility Operation and Administration, Use of Active Runways, para 10-1-7, where justified by extraordinary circumstances at specific locations. REFERENCE- FAAO 7110.65, Constraints Governing Supplements and Procedural Deviations, Para 1-1-10. FAAO 7210.3, Use of Active Runways, Para 10-1-7. a. Ground control must obtain approval from local control before authorizing an aircraft or a vehicle to cross or use any portion of an active runway. The coordination shall include the point/intersection at the runway where the operation will occur. PHRASEOLOGY- CROSS (runway) AT (point/intersection). b. When the local controller authorizes another controller to cross an active runway, the local controller shall verbally specify the runway to be crossed and the point/intersection at the runway where the operation will occur preceded by the word "cross." PHRASEOLOGY- CROSS (runway) AT (point/intersection). c. The ground controller shall advise the local controller when the coordinated runway operation is complete. This may be accomplished verbally or through visual aids as specified by a facility directive. d. USA/USAF/USN NOT APPLICABLE. Authorization for aircraft/vehicles to taxi/proceed on or along an active runway, for purposes other than crossing, shall be provided via direct communications on the appropriate local control frequency. This authorization may be provided on the ground control frequency after coordination with local control is completed for those operations specifically described in a facility directive. NOTE- The USA, USAF, and USN establish local operating procedures in accordance with, respectively, USA, USAF, and USN directives. e. The local controller shall coordinate with the ground controller before using a runway not previously designated as active. REFERENCE- FAAO 7110.65, Coordination Between Local and Ground Controllers, Para 3-1-4. 3-1-4. COORDINATION BETWEEN LOCAL AND GROUND CONTROLLERS Local and ground controllers shall exchange information as necessary for the safe and efficient use of airport runways and movement areas. This may be accomplished via verbal means, flight progress strips, other written information, or automation displays. As a minimum, provide aircraft identification and applicable runway/intersection/taxiway information as follows: a. Ground control shall notify local control when a departing aircraft has been taxied to a runway other than one previously designated as active. REFERENCE- FAAO 7110.65, Use of Active Runways, Para 3-1-3. FAAO 7210.3, Selecting Active Runways, Para 10-1-6. {New-2007-17 b. revised August 30, 2007} b. Ground control must notify local control of any aircraft taxied to an intersection for takeoff. This notification may be accomplished by verbal means or by flight progress strips. REFERENCE- FAAO 7110.65, Wake Turbulence Separation for Intersection Departures, Para 3-9-7. c. When the runways in use for landing/departing aircraft are not visible from the tower or the aircraft using them are not visible on radar, advise the local/ground controller of the aircraft's location before releasing the aircraft to the other controller." Bob Gardner "TakeFlight" wrote in message ... Had a dual flight the other day at RDU (runway diagram link at bottom for reference). We requested runway 14 for departure, and ground told us "taxi to runway 14 via Juliet, Charlie, hold short of 23L" (we were departing from the general aviation ramp). So I taxied out, eventually holding short of 23L on Charlie. The instructor asked if I was going to switch to tower. I told him no, that we weren't at 14 yet. He insisted that since we were holding short of 23L that we needed to contact the tower to get across. I disagreed. So he called the tower and reported us as "holding short of 23L." After a landing aircraft rolled by, tower told us to taxi to 14 and cleared us for takeoff. In 18 years of flying, I've never run across this before. Is this something new, peculiar to RDU, or was he just mistaken? Whenever I've been in this situation before, ground always was the one to tell me to cross a runway and taxi on to my departing runway. Granted, it could be the same controller just on a different freq.... http://204.108.4.16/d-tpp/0802/00516AD.PDF |
On Mar 11, 2:03*pm, "Bob Gardner" wrote:
This information, taken from the Air Traffic Control Handbook, may be useful: Again, since it sounds like we're talking about a local procedure you'd have to get a copy of that. -Robert |
On Tue, 11 Mar 2008 15:31:50 -0700 (PDT), "Robert M. Gary"
wrote in : On Mar 11, 2:03*pm, "Bob Gardner" wrote: This information, taken from the Air Traffic Control Handbook, may be useful: Again, since it sounds like we're talking about a local procedure you'd have to get a copy of that. -Robert That would be useful information. Has anyone bothered to consult the references in this note: NOTE- Exceptions may be authorized only as provided in para 1-1-10, Constraints Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility Operation and Administration, Use of Active Runways, para 10-1-7, where justified by extraordinary circumstances at specific locations. |
I did, and found nothing on point except dealing with crossing the active
runway. In the OPs case, they were not crossing the active. Bob Gardner "Larry Dighera" wrote in message ... On Tue, 11 Mar 2008 15:31:50 -0700 (PDT), "Robert M. Gary" wrote in : On Mar 11, 2:03 pm, "Bob Gardner" wrote: This information, taken from the Air Traffic Control Handbook, may be useful: Again, since it sounds like we're talking about a local procedure you'd have to get a copy of that. -Robert That would be useful information. Has anyone bothered to consult the references in this note: NOTE- Exceptions may be authorized only as provided in para 1-1-10, Constraints Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility Operation and Administration, Use of Active Runways, para 10-1-7, where justified by extraordinary circumstances at specific locations. |
Bob Gardner wrote:
I did, and found nothing on point except dealing with crossing the active runway. In the OPs case, they were not crossing the active. They weren't crossing the runway they were going to depart on, but they were certainly crossing an active runway. Runway 14 is never used for landing (somebody told me it would scare the guys in the tower to have planes get that close to them.) Small planes are often sent to land on 32 as to avoid interfering with commercial traffic on the longer parallel runways. I remember the first time I was sent to take off on 14. I was like, "One Four? What the heck is One Four?" You'd also never be sent to depart from 32. Bob Gardner "Larry Dighera" wrote in message ... On Tue, 11 Mar 2008 15:31:50 -0700 (PDT), "Robert M. Gary" wrote in : On Mar 11, 2:03 pm, "Bob Gardner" wrote: This information, taken from the Air Traffic Control Handbook, may be useful: Again, since it sounds like we're talking about a local procedure you'd have to get a copy of that. -Robert That would be useful information. Has anyone bothered to consult the references in this note: NOTE- Exceptions may be authorized only as provided in para 1-1-10, Constraints Governing Supplements and Procedural Deviations, and FAAO 7210.3, Facility Operation and Administration, Use of Active Runways, para 10-1-7, where justified by extraordinary circumstances at specific locations. -- Don Poitras |
On Mar 11, 5:31*pm, "Robert M. Gary" wrote:
Again, since it sounds like we're talking about a local procedure you'd have to get a copy of that. There are no local procedures at RDU or ABQ that deviate from the national standards in this area. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
OSH question | Bill Chernoff | Home Built | 8 | November 20th 04 01:07 AM |
Serious question | BackToNormal | Military Aviation | 33 | November 3rd 03 06:47 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
