#21
"Ken S. Tucker" wrote in
: Hi Barney - not :-) - Rubble. On Apr 3, 9:00 am, "Barney Rubble" wrote: That's the best advice. I once got into the start of a graveyard spiral on a VERY turbulent day when I took my eye off the ball for a split second to tune the radio. When i glanced back I noticed the plane was 90 degrees off heading and the VSI was pegged downwards. It happened in less than 2 seconds, I kid you not. Instinct took over and I levelled the wings and got the altitude back on track before the controller even noticed. Boy did I get the cold chills. I was single pilot in heavy IMC with the rian beating on the windshield, moderate turb PIREPS all around and minimums below. Not a goot time to let things slide. I was back on alt and heading before the controller even noticed.... I'm pleased I practiced UA and smooth control of the plane. - Barney That's damn interesting. Consider a vortex, we see them as tornadoes when they actually mature and touch down to the ground. But suppose only 1 in a hundred, actually become mature tornadoes and the rest exist in bad weather, inside clouds that Barney may have encountered. There is a lot of different kinds of turbulence, that could appear in seconds as one flys into a vortex. I've seen plenty of photo's of little titties on the bottom of storm clouds, (I think they are usually Nimbo Stratus, but not always), that dissipated. That gives me an idea for a new instrument, something like a "stall buzzer". If a delta attitude occurs, that is NOT a result of an control input, then that would warn of either a weather or structural anomally. Fortunately for Barney it was a weather anomally. Don't quite know how to build it yet but that's just application of ingenuity. Regards Ken S. Tucker Good lord, is there nothing you know something about~? Bertie |
john smith schrieb:
I've seen plenty of photo's of little titties on the bottom of storm clouds, (I think they are usually Nimbo Stratus, but not always), that dissipated. Cumulo Mamatus Close. Mammatus or mamma is not a cloud, but a special form of the cloud base. It mostly appears on CBs, but can also appear with any other cloud form. And yes, it's called mammatus because it resembles mammae, making it one of the most erotic cloud forms. So a cumulonimbus mammatus is a cumulonimbus with that special cloud base. |
One of the most erotic cloud forms? Can't beat the Cirrus of the Year in the centerfold of this month's Sensual Meteorology, for my money. Never made it out of the airport bathroom... On Thu, 03 Apr 2008 21:48:01 +0200, Stefan wrote: john smith schrieb: I've seen plenty of photo's of little titties on the bottom of storm clouds, (I think they are usually Nimbo Stratus, but not always), that dissipated. Cumulo Mamatus Close. Mammatus or mamma is not a cloud, but a special form of the cloud base. It mostly appears on CBs, but can also appear with any other cloud form. And yes, it's called mammatus because it resembles mammae, making it one of the most erotic cloud forms. So a cumulonimbus mammatus is a cumulonimbus with that special cloud base. |
On Apr 3, 11:48 am, Stefan wrote:
john smith schrieb: I've seen plenty of photo's of little titties on the bottom of storm clouds, (I think they are usually Nimbo Stratus, but not always), that dissipated. Cumulo Mamatus Close. Mammatus or mamma is not a cloud, but a special form of the cloud base. It mostly appears on CBs, but can also appear with any other cloud form. And yes, it's called mammatus because it resembles mammae, making it one of the most erotic cloud forms. So a cumulonimbus mammatus is a cumulonimbus with that special cloud base. http://en.wikipedia.org/wiki/Mammatus_cloud Thanks for the input. Ken |
On Apr 3, 1:00 pm, "Barney Rubble" wrote:
That's the best advice. I once got into the start of a graveyard spiral on a VERY turbulent day when I took my eye off the ball for a split second to tune the radio. When i glanced back I noticed the plane was 90 degrees off heading and the VSI was pegged downwards. It happened in less than 2 seconds, I kid you not. Instinct took over and I levelled the wings and got the altitude back on track before the controller even noticed. Boy did I get the cold chills. I was single pilot in heavy IMC with the rian beating on the windshield, moderate turb PIREPS all around and minimums below. Not a goot time to let things slide. I was back on alt and heading before the controller even noticed.... I'm pleased I practiced UA and smooth control of the plane. - Barney Though I have a reputation as a Luddite, I will chime in that an autopilot is the best friend a Single Pilot flying IFR can possess. Even if you hand fly most of the time, it helps plenty to hand over the straight and level chore for a moment to fetch a chart or write down a frequency (which hardly ever matches what you're expecting based on the charts). Dan Mc |
: On Apr 3, 11:48 am, Stefan wrote: john smith schrieb: I've seen plenty of photo's of little titties on the bottom of storm clouds, (I think they are usually Nimbo Stratus, but not always), that dissipated. Cumulo Mamatus Close. Mammatus or mamma is not a cloud, but a special form of the cloud base. It mostly appears on CBs, but can also appear with any other cloud form. And yes, it's called mammatus because it resembles mammae, making it one of the most erotic cloud forms. So a cumulonimbus mammatus is a cumulonimbus with that special cloud base. http://en.wikipedia.org/wiki/Mammatus_cloud Thanks for the input. Like you;'d know what to do with it,. k00k. Bertie |
"Eamon McKinley" wrote in message
... Hello everyone, I'm about a week away from taking my instrument checkride, but I'm lacking in one area I thought would be a breeze. ... So, d00d, how did it go? -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
| Thread Tools | |
| Display Modes | |
| Unusual Attitude training flight | Jeff[_1_] | Piloting | 6 | September 24th 07 06:26 PM |
| OT...Flight Sim 2004 Advice sought... | Joe Friday | Aviation Photos | 10 | December 26th 06 08:18 PM |
| attitude?? | houstondan | Piloting | 2 | March 19th 05 04:43 AM |
| Attitude Gyro | Paul | Restoration | 0 | July 22nd 04 06:05 AM |
