I am still working on home remodel so it will be some time before the
airplane gets started. I am pretty darn convinced that I am going to do an all wood and fabric airplane. More than likely, the Fisher Tiger Moth. Anyway, I have come to the point in my home remodel that I am going to need an air compressor. But instead of just getting one that will do the job here, what might I need one for when it is airplane time? What size and compressor (one or two cylinder) should I look at? Any name brand preference? Thanks, Fred |
For sure you're going to want it for doping and painting. Might use
an air hammer to drive the occasional rivet, even in a woodie. (expensive tool to buy, but you could rent it. You could also use a ball peen.) Haven't read of folks using air-powered staplers or nailers; not sure if you could even get the teeny things we use in a form for a powered stapler. Somebody else might know. You might also use it for sandblasting steel parts prior to painting them. A dual-cylinder compressor refills the tank faster. So for high-volume operations it'll let you work more continuously. If your home project involves an air-gun nailer or sprayed-in insulation, that'll probably be the driving factor, rather than the airplane project. BTW - If you haven't already poured concrete, and you're going to buy battens, you might take extra care selecting the 2x12s at the lumberyard. They're often made from Douglas Fir - look for a stamp that says D FIR (not H FIR or HEM FIR). Weyrhauser(sp?) uses a triangle stamp with D FIR inside. With some careful picking, you might find a few boards with clear, tight grain in usable dimensions between the knots. (Be sure to knock ALL the concrete off before you take the saw to it, though!) "Frederick Wilson" wrote in message news:FmC9b.365132$Oz4.142857@rwcrnsc54... I am still working on home remodel so it will be some time before the airplane gets started. I am pretty darn convinced that I am going to do an all wood and fabric airplane. More than likely, the Fisher Tiger Moth. Anyway, I have come to the point in my home remodel that I am going to need an air compressor. But instead of just getting one that will do the job here, what might I need one for when it is airplane time? What size and compressor (one or two cylinder) should I look at? Any name brand preference? Thanks, Fred |
news:FmC9b.365132$Oz4.142857@rwcrnsc54... I am still working on home remodel so it will be some time before the airplane gets started. I am pretty darn convinced that I am going to do an all wood and fabric airplane. More than likely, the Fisher Tiger Moth. Anyway, I have come to the point in my home remodel that I am going to need an air compressor. But instead of just getting one that will do the job here, what might I need one for when it is airplane time? What size and compressor (one or two cylinder) should I look at? Any name brand preference? Whichever model you choose, be SURE to listen to it run before you plunk down your money. Some of the new compressors are loud enough to shred your neighbor's panties. Rich S. |
![]() "Rich S." wrote in message ... "Frederick Wilson" wrote in message news:FmC9b.365132$Oz4.142857@rwcrnsc54... I am still working on home remodel so it will be some time before the airplane gets started. I am pretty darn convinced that I am going to do an all wood and fabric airplane. More than likely, the Fisher Tiger Moth. Anyway, I have come to the point in my home remodel that I am going to need an air compressor. But instead of just getting one that will do the job here, what might I need one for when it is airplane time? What size and compressor (one or two cylinder) should I look at? Any name brand preference? Whichever model you choose, be SURE to listen to it run before you plunk down your money. Some of the new compressors are loud enough to shred your neighbor's panties. Rich S. Part of the things to consider is if you will use a lot of air tools, or go electric. For a wood airplane, I could see a bit of sanding, and spraying finish. A small 30 gal 3 HP compressor would not keep up with a air sander, or spray gun very well. I like air tools cause they are usually cheaper, lighter, and don't get hot under heavy usage. If you can swing it, get a big upright 5 HP , NOT oilless unit, and put it outside if you can. It saves the ears and the space in the shop. All it needs is a small lean-to roof. -- Jim in NC |
Jim,
I can see where that would be good, but it would be a bit hard lugging around that compressor to the different parts of the house for the remodel. ;-) I liked the pawn shop idea. I might be able to get something functional and cheap right now to figure out the features I want for the real one. It is starting to cool off here in Indiana so, I guess, the new two car garage/hanger/building shop is out for this year. Fred Speculating I wonder what the average time difference is between deciding to build an airplane and actually starting the project. Thanks for the input, Fred "Morgans" wrote in message ... "Rich S." wrote in message ... "Frederick Wilson" wrote in message news:FmC9b.365132$Oz4.142857@rwcrnsc54... I am still working on home remodel so it will be some time before the airplane gets started. I am pretty darn convinced that I am going to do an all wood and fabric airplane. More than likely, the Fisher Tiger Moth. Anyway, I have come to the point in my home remodel that I am going to need an air compressor. But instead of just getting one that will do the job here, what might I need one for when it is airplane time? What size and compressor (one or two cylinder) should I look at? Any name brand preference? Whichever model you choose, be SURE to listen to it run before you plunk down your money. Some of the new compressors are loud enough to shred your neighbor's panties. Rich S. Part of the things to consider is if you will use a lot of air tools, or go electric. For a wood airplane, I could see a bit of sanding, and spraying finish. A small 30 gal 3 HP compressor would not keep up with a air sander, or spray gun very well. I like air tools cause they are usually cheaper, lighter, and don't get hot under heavy usage. If you can swing it, get a big upright 5 HP , NOT oilless unit, and put it outside if you can. It saves the ears and the space in the shop. All it needs is a small lean-to roof. -- Jim in NC |
![]() "Frederick Wilson" wrote in message news:2uX9b.372665$Oz4.149020@rwcrnsc54... Jim, I can see where that would be good, but it would be a bit hard lugging around that compressor to the different parts of the house for the remodel. ;-) I liked the pawn shop idea. I might be able to get something functional and cheap right now to figure out the features I want for the real one. It is starting to cool off here in Indiana so, I guess, the new two car garage/hanger/building shop is out for this year. Fred Speculating I wonder what the average time difference is between deciding to build an airplane and actually starting the project. Thanks for the input, Fred Hose is cheap! ;-) -- Jim in NC |
Check out item 47065-2VGA at http://www.harborfreight.com/.
4-1/2 HP 21 GALLON CAST IRON VERTICAL COMPRESSOR Two Built-in Universal Quick Connect Couplers for Convenient Air Hose Connection Long-life oil lubricated compressor with precision machined cast iron sleeve Twin capacitor motor with thermal overload protection Wheel kit with 6'' wheels and ergonomic for smooth portability Oil level indicator window for easy maintenance Reduced vibration with rubber foot stabilizers 4-1/2 peak horsepower; 120 volt, 60Hz 125 PSI max; 4.4 CFM @ 90 PSI; 11.1 CFM @ 40 PSI Shipping weight: 152 lbs. $169.99 Rich S. |
![]() "Rich S." wrote in message ... 4-1/2 HP 21 GALLON CAST IRON VERTICAL COMPRESSOR 4-1/2 peak horsepower; 120 volt, 60Hz chuckle Wayne |
![]() "Rich S." wrote in message ... Check out item 47065-2VGA at http://www.harborfreight.com/. 4-1/2 HP 21 GALLON CAST IRON VERTICAL COMPRESSOR Two Built-in Universal Quick Connect Couplers for Convenient Air Hose Connection Long-life oil lubricated compressor with precision machined cast iron sleeve Twin capacitor motor with thermal overload protection Wheel kit with 6'' wheels and ergonomic for smooth portability Oil level indicator window for easy maintenance Reduced vibration with rubber foot stabilizers 4-1/2 peak horsepower; 120 volt, 60Hz 125 PSI max; 4.4 CFM @ 90 PSI; 11.1 CFM @ 40 PSI Shipping weight: 152 lbs. $169.99 Rich S. I dunno beans about air compressors, so maybe someone else can explain it to me: The usual wall circuit is 15 Amperes, times 120 volts peak is 1800 watts. 746 watts in a horsepower, so how do you get 4.5 HP out of a wall socket? Tim Ward |
Fred Speculating I wonder what the average time difference is between deciding to build an airplane and actually starting the project. Define "starting the project" :-) Corrie (owner of several sets of plans, a bunch of tools, and a small amount of wood) http://www.itasca.net/~corrie/homebuilt_plane_blog.htm |
