On Apr 3, 9:04 pm, Larry Dighera wrote:
As I recall, several years ago the FAA changed their policy, and removed the controller from culpability in the event the pilot's read-back was incorrect. There was no change in policy. |
On Fri, 4 Apr 2008 08:38:52 -0700 (PDT), "Steven P. McNicoll"
wrote: On Apr 3, 9:04 pm, Larry Dighera wrote: As I recall, several years ago the FAA changed their policy, and removed the controller from culpability in the event the pilot's read-back was incorrect. There was no change in policy. So it seems. The FAA issued an interpretive rule: http://www.aopa.org/whatsnew/regulat...retiverule.pdf Federal Register / Vol. 64, No. 62 / Thursday, April 1, 1999 DEPARTMENT OF TRANSPORTATION Federal Aviation Administration 14 CFR Part 91 Pilot Responsibility for Compliance With Air Traffic Control Clearances and Instructions SUMMARY: Pilots operating in areas in which air traffic control is exercised are required by regulation to comply with the clearances and instructions of air traffic controllers except in very narrow circumstances. The FAA has consistently construed and enforced this requirement as ascribing to pilots a high level of responsibility to monitor air traffic control communications attentively. Under normal circumstances, the FAA has expected pilots to understand and to comply with clearly transmitted and reasonably phrased clearances and instructions that govern their operations. Nevertheless, a series of recent National Transportation Safety Board (NTSB) enforcement decisions has raised a question regarding the regulatory responsibility of pilots to hear and to comply with air traffic control clearances and instructions. This interpretive rule confirms the FAA’s historical construction of its regulations that require compliance with air traffic control clearances and instructions. |
Larry Dighera writes:
So it seems. The FAA issued an interpretive rule: http://www.aopa.org/whatsnew/regulat...retiverule.pdf Federal Register / Vol. 64, No. 62 / Thursday, April 1, 1999 DEPARTMENT OF TRANSPORTATION Federal Aviation Administration 14 CFR Part 91 Pilot Responsibility for Compliance With Air Traffic Control Clearances and Instructions SUMMARY: Pilots operating in areas in which air traffic control is exercised are required by regulation to comply with the clearances and instructions of air traffic controllers except in very narrow circumstances. The FAA has consistently construed and enforced this requirement as ascribing to pilots a high level of responsibility to monitor air traffic control communications attentively. Under normal circumstances, the FAA has expected pilots to understand and to comply with clearly transmitted and reasonably phrased clearances and instructions that govern their operations. Nevertheless, a series of recent National Transportation Safety Board (NTSB) enforcement decisions has raised a question regarding the regulatory responsibility of pilots to hear and to comply with air traffic control clearances and instructions. This interpretive rule confirms the FAA’s historical construction of its regulations that require compliance with air traffic control clearances and instructions. That just reasserts the need for pilots to obey ATC (exclusive of emergencies, which is not stated here but is in the regulations). However, it doesn't say anything about readback. If the pilot reads back instructions, and the readback is incorrect, and ATC says nothing, how is the pilot to possibly know that he is doing the wrong thing? Simple noise on the radio could cause him to hear something incorrectly, no matter how "attentive" he might be. |
![]() "Mxsmanic" wrote in message ... RubberWatch writes: I am a student pilot. I was out flying solo today and was instructed by ATC to fly a heading of 210. I thought he said 110 and I flew on that heading. Did you read back the heading? If you read back 110 and he said nothing, you're okay, since he should have corrected you. Bull****, he's okay anyway. STFU, you're wrong as usual. |
Maxwell writes:
Bull****, he's okay anyway. He's more okay with a readback. Readbacks are good. |
On 2008-04-03 19:11:38 -0700, "Maxwell" luv2^fly99@cox.^net said:
"Mxsmanic" wrote in message ... RubberWatch writes: I am a student pilot. I was out flying solo today and was instructed by ATC to fly a heading of 210. I thought he said 110 and I flew on that heading. Did you read back the heading? If you read back 110 and he said nothing, you're okay, since he should have corrected you. Bull****, he's okay anyway. STFU, you're wrong as usual. Anthony forgets that people don't die in simulators. They do die in real airplanes, though, and the FAA has held that a pilot who reads back an erroneous clearance is still required to fly the one given him by ATC, even if ATC doesn't correct him. But even if Anthony was correct from a legal standpoint, flying a misunderstood heading can easily kill you. Then it doesn't matter who was right -- you are the one who is dead. -- Waddling Eagle World Famous Flight Instructor |
![]() "C J Campbell" wrote in message news:2008040405554543658-christophercampbell@hotmailcom... On 2008-04-03 19:11:38 -0700, "Maxwell" luv2^fly99@cox.^net said: "Mxsmanic" wrote in message ... RubberWatch writes: I am a student pilot. I was out flying solo today and was instructed by ATC to fly a heading of 210. I thought he said 110 and I flew on that heading. Did you read back the heading? If you read back 110 and he said nothing, you're okay, since he should have corrected you. Bull****, he's okay anyway. STFU, you're wrong as usual. Anthony forgets that people don't die in simulators. They do die in real airplanes, though, and the FAA has held that a pilot who reads back an erroneous clearance is still required to fly the one given him by ATC, even if ATC doesn't correct him. But even if Anthony was correct from a legal standpoint, flying a misunderstood heading can easily kill you. Then it doesn't matter who was right -- you are the one who is dead. -- Waddling Eagle World Famous Flight Instructor Difference between ATC and pilot. When a pilot makes a mistake the pilot dies. When ATC makes a mistake the pilot dies. Happy landings, |
Private wrote:
"C J Campbell" wrote in message news:2008040405554543658-christophercampbell@hotmailcom... On 2008-04-03 19:11:38 -0700, "Maxwell" luv2^fly99@cox.^net said: "Mxsmanic" wrote in message ... RubberWatch writes: I am a student pilot. I was out flying solo today and was instructed by ATC to fly a heading of 210. I thought he said 110 and I flew on that heading. Did you read back the heading? If you read back 110 and he said nothing, you're okay, since he should have corrected you. Bull****, he's okay anyway. STFU, you're wrong as usual. Anthony forgets that people don't die in simulators. They do die in real airplanes, though, and the FAA has held that a pilot who reads back an erroneous clearance is still required to fly the one given him by ATC, even if ATC doesn't correct him. But even if Anthony was correct from a legal standpoint, flying a misunderstood heading can easily kill you. Then it doesn't matter who was right -- you are the one who is dead. -- Waddling Eagle World Famous Flight Instructor Difference between ATC and pilot. When a pilot makes a mistake the pilot dies. When ATC makes a mistake the pilot dies. Happy landings, .........and this is a VERY good reason for pilots NEVER get into a "who's right and who's wrong with ATC mental attitude, but rather to do everything in their power to keep communication with ATC simple, accurate, and above all, HELPFUL to ATC in aiding them in protecting the pilot's safety. -- Dudley Henriques |
Again...thanks everyone for your helpful advice....i just keep
laughing at the snide snips and jokes about simulators and differences between atc and pilots... ![]() |
![]() "Private" wrote in message ... Difference between ATC and pilot. When a pilot makes a mistake the pilot dies. When ATC makes a mistake the pilot dies. Happy landings, Excepting ATC Peter Nielsen who was murdered for his mistake... |
Confused re transponders and ADS-B | Andrew Gideon | Piloting | 6 | June 27th 06 01:49 AM |
Another ADIZ violation? | Dan Foster | Piloting | 5 | January 4th 06 02:25 AM |
Confused about great circle navigation | xerj | Piloting | 7 | July 10th 04 05:38 PM |
No wonder I'm confused:) | John0714 | Soaring | 0 | May 1st 04 07:02 PM |
