Aero News has a story today about Indus Aviation flying a diesel
Thorpedo burning only three gallons of Jet-A per hour. It uses a WAM-120 turbocharged three-cylinder diesel engine generating 120 horsepower. One drawback of the engine - the installed weight is 279 pounds. But on the plus side it uses a mechanical control unit rather than electronic. The "projected" TBO is 3000 hours. Phil |
On Apr 13, 2:10*pm, Bertie the Bunyip wrote:
Phil J wrote in news:748b4d47-77dc-49a8-8252- : Aero News has a story today about Indus Aviation flying a diesel Thorpedo burning only three gallons of Jet-A per hour. *It uses a WAM-120 turbocharged three-cylinder diesel engine generating 120 horsepower. *One drawback of the engine - the installed weight is 279 pounds. *But on the plus side it uses a mechanical control unit rather than electronic. *The "projected" TBO is 3000 hours. Phil Last I heard of that one it was more like 4-5 GPH. That might be an Imperial measurement. Bertie Indus claimed three gallons per hour for a flight from Dallas, Texas to Lakeland, Florida. I would guess that they throttled back to the leanest possible cruise. In an EAA news article they are claiming 3.5 to 4 gallons per hour ( http://www.eaa.org/news/2008/2008-04-12_indus.asp ). Phil |
On Apr 13, 4:13 pm, Phil J wrote:
Indus claimed three gallons per hour for a flight from Dallas, Texas to Lakeland, Florida. I would guess that they throttled back to the leanest possible cruise. No doubt that 3gph figure must be an economic cruise power setting, likely below 50% power. BTW on a diesel, the combustion is well lean of stoichiometric even at the max rated power. The air intake is not throttle and the "throttle" control in a diesel engine is the fuel flow control. There's no such thing as lean of peak or best power mixture :-) You reduce the fuel flow and the engine produces less power. You increase the fuel flow and the engine produces more power - until you reach the soot limit or other thermo/mechanical limit for the particular engine and that's the max rated power. |
On Apr 13, 6:21*pm, M wrote:
On Apr 13, 4:13 pm, Phil J wrote: Indus claimed three gallons per hour for a flight from Dallas, Texas to Lakeland, Florida. *I would guess that they throttled back to the leanest possible cruise. No doubt that 3gph figure must be an economic cruise power setting, likely below 50% power. BTW on a diesel, the combustion is well lean of stoichiometric even at the max rated power. *The air intake is not throttle and the "throttle" control in a diesel engine is the fuel flow control. There's no such thing as lean of peak or best power mixture :-) *You reduce the fuel flow and the engine produces less power. *You increase the fuel flow and the engine produces more power - until you reach the soot limit or other thermo/mechanical limit for the particular engine and that's the max rated power. See this is what I like about this newsgroup. I am always learning something new. I've never had direct experience with a diesel engine, although I suspect that there are going to be more of them in cars as American fuel prices rise. Phil |
Phil J wrote:
On Apr 13, 6:21?pm, M wrote: On Apr 13, 4:13 pm, Phil J wrote: Indus claimed three gallons per hour for a flight from Dallas, Texas to Lakeland, Florida. ?I would guess that they throttled back to the leanest possible cruise. No doubt that 3gph figure must be an economic cruise power setting, likely below 50% power. BTW on a diesel, the combustion is well lean of stoichiometric even at the max rated power. ?The air intake is not throttle and the "throttle" control in a diesel engine is the fuel flow control. There's no such thing as lean of peak or best power mixture :-) ?You reduce the fuel flow and the engine produces less power. ?You increase the fuel flow and the engine produces more power - until you reach the soot limit or other thermo/mechanical limit for the particular engine and that's the max rated power. See this is what I like about this newsgroup. I am always learning something new. I've never had direct experience with a diesel engine, although I suspect that there are going to be more of them in cars as American fuel prices rise. Diesel used to be cheaper then gasoline and people started buying diesel cars. Diesel now costs about the same as gasoline and people have stopped buying diesel cars. Unless the price of diesel drops significantly with respect to gasoline, there is no reason to think diesel cars will make a comeback. -- Jim Pennino Remove .spam.sux to reply. |
Hmmm, My BS meter is twitching...This is a BSFC of ~0.142
The very best diesel BSFC is the huge japanese engines used in container ships at roughly 0.30... denny |
On Apr 13, 12:29 pm, Denny wrote:
Hmmm, My BS meter is twitching...This is a BSFC of ~0.142 The very best diesel BSFC is the huge japanese engines used in container ships at roughly 0.30... denny How did you get SFC of 0.142? That 3gph might be based on say 50% power (60HP is plenty for cruise flight on a LSA on a local sight-seeing trip). That'll make SFC: 3 * 6.8 / 60 = 0.34 lb-hr/HP. That's quite doable on a diesel. |
![]() The very best diesel BSFC is the huge japanese engines used in container ships at roughly 0.30... BTW, SFC 0.30 is achievable on mid-size ship diesel. The largest ship diesel engines can do 0.28 lb-hr/HP or less: http://people.bath.ac.uk/ccsshb/12cyl/ |
Denny wrote in news:b71e5ad0-64ee-483e-8102-
: Hmmm, My BS meter is twitching...This is a BSFC of ~0.142 The very best diesel BSFC is the huge japanese engines used in container ships at roughly 0.30... denny Well, here they're saying somethign quite different http://www.wilksch.com/wam-120.html The 3 GPH might not have been at econ cruise, but it was probably at max endurance, i.e., just enough to keep them aloft. Bertie |
C-172 $20 / hour! C-210 $30 / hour! I found my new job... | Ricky | Piloting | 9 | February 14th 08 02:01 PM |
1800 Gallons of De-icing fluid... | Jay Honeck | Piloting | 30 | January 20th 07 03:39 PM |
Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Aviation Marketplace | 1 | February 14th 05 06:36 PM |
Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Piloting | 0 | February 12th 05 07:53 PM |
Turn & Bank Indicator and 2 gallons of poyester resin | [email protected] | Instrument Flight Rules | 0 | February 12th 05 07:52 PM |
