Lancair crash at SnF
Old April 24th 08, 07:49 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Lancair crash at SnF
Buttman wrote in news:fuqg20$hee$2
@registered.motzarella.org:
On Thu, 24 Apr 2008 17:05:06 +0200, Stefan sayeth:
Brian schrieb:
Your right in that many aircraft it is possible. But the problem is
it
isn't possible for many pilots when the engine quits. It is not a
maneuver that is routinly practiced.
Now this problem could be solved.
You're suggesting instructors practice engine failures with their
students on takeoff? Oh boy, better hope Dudly doesn't see this...
Good god you're a moron.
No wonder flying skills are going down the toilet.
Bertie
Old April 24th 08, 09:15 PM posted to rec.aviation.piloting
WingFlaps
On Apr 25, 2:06*am, Shirl wrote:
Shirl wrote:
A Lancair crashed just moments after takeoff here in Mesa, Arizona,
today, too. Plane was headed for California. There was smoke trailing
from the plane on takeoff and controllers cleared them to turn back
around and land. They tried -- they made the left turn but crashed into
the orange orchard. Three fatalities, all in their late 20s. Sympathies
and prayers to the families.
WingFlaps wrote:
When will pilots learn to stop trying to do the impossible turn... and
go for a straight ahead landing on soemthing horizontal?
In this case, straight ahead would have been into a shopping center,
buildings, houses, etc. *Having been through an engine failure, I try
not to second guess, but he *may* have thought he had a better chance to
at least turn away from all that.
I had a look on Google earth and there seem to be many fields around
the airport what shopping center are you talking about?
Cheers
Old April 24th 08, 10:17 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
On Apr 25, 3:12*am, Dylan Smith wrote:
On 2008-04-24, Brian wrote:
Depends on what you mean by "the impossible turn". If you mean turning back
at 200 AGL, yeah, that one's pretty much impossible. If you mean 600 AGL,
it's pretty much possible in the average aircraft. (Hell, that's pattern
altitude at EFD!) The line lies somewhere in between.
It is statements like this that get pilots killed.
It's statements like 'never turn, always land straight ahead' that also
gets pilots killed. There are plenty of airfields where going straight
ahead is quite possibly the worst option, and the best survivability
options are at least a 120 degree turn away from whatever point you're
at when at 600' AGL.
The only thing you can do is use the best judgement at the time. You get
one chance - it may be wrong. Sometimes, trying to turn back might be
wrong. Sometimes doing anything *other* than trying to turn back might
be wrong.
In gliders, every glider pilot is taught "the impossible turnback" from
200 feet (which, in the typical low performance training glider, is
about equal to turning back at 600 feet in a C172).
It's the L/D that makes it much harder in a typical powered plane.
This means that all manouvers lose energy much faster. The turn back
needs at least 2 turns as well as acceleration if there is any wind.
You will note that nearly all the accidents are stall spins -a moments
thought about the situation will make you realize why this is. The
turns are made tight because there is not enough height/time for a
lazy turn.
Let's work some real numbers for a 172 at 500'. Say climb was a Vx 59
knots. The plane must first be accelerated to 65 for best glide. The
pilot carries out some trouble checks say 10s. Calls on the radio =10
s and plans his return. Note that 20s have probably elapsed. The plane
has already travelled ~0.4 miles and at a 10:1 glide ratio has lost
200' (assuming he did get it to best glide in the first place). Can
he make 2 turns and land back -no way!
Ah you say, I'm a much better pilot, I would loose not more than 10
seconds in starting my turn back., trimming etc.
But how much does the turn back cost? Assuming you keep to 45 degrees
of bank to stay _above_ stall (the stall is now damn close -better
hope there's no significant wind) the turns are still going to cost
you 35 seconds. 45 seconds lost = 450 feet! Now we add in the energy
losses from having to accelerate with the wind and to glide speed.
It's still an impossible turn. Try to tighten that turn more and you
have to dive to accelerate to avoid the stall and what does that do to
your energy management and turn radius?
Now what safety margin is appropriate for you and you PAX? Say 100%
in that case, unless you've climbed to 1000' don't even think about
turning back but practice spotting good landing sites.
I've also heard a lot of BS in this thread about not having good
palces to put the plane. There is nearly always somewhere flat to put
the plane within 90 degrees of the runway centerline -even a road.
Malls have big parking lots! Put it down flat in landing config and
you will probably survive, stall spin and you'll DIE along with your
PAX. A good pilot looks at the airport environs in a strange airport
and may ask about options at the runway end for this emergency.
Cheers
Old April 24th 08, 10:20 PM posted to rec.aviation.piloting
WingFlaps
On Apr 25, 6:24*am, Andy Hawkins wrote:
Hi,
Brian schrieb:
Your right in that many aircraft it is possible. But the problem is it
EFATO practice is normal during the PPL in the UK (simulated, obviously).
The instructor chops the throttle and you pick a landing sight and get set
up for it in much the same way as you would a PFL.
You do have a bit of warning when he announces 'fanstop' over the radio
though!
The call here is "simulated failure, call climbing"
Cheers
Old April 24th 08, 11:08 PM posted to rec.aviation.piloting,rec.aviation.student
Shirl
I don't know about where you live, but malls here have lots of light
poles, concrete islands, park-and-rest benches and ... and ... vehicles
everywhere. And having gone through it once, I'm no longer fooled by
what *looks* "flat" at 500, or even 50 feet.
Old April 24th 08, 11:13 PM posted to rec.aviation.piloting
Shirl
They took off 22L. I'm talking about the new Walmart shopping center.
Witnesses said had he not turned, that's where he would have gone. That
area *had* many fields that have recently been developed/built-up very
recently. I don't know how old the Google Earth photo is. I'll go have a
look.
Old April 24th 08, 11:16 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
Now we add in the energy losses from having to
Arrrgh! Not the old "turn into downwind" legend again! Better work out
your understanding of physics before publicly reasoning about turns.
There is nearly always somewhere flat to put the plane
The operative word in this sentence is "nearly".
Old April 24th 08, 11:40 PM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
Try reading the statement again, here it is:
"Now we add in the energy losses from having to accelerate with the
wind and to glide speed."
Now perhaps you would like to revise some physics and try to critcise
it for us?
I await your stumbling analysis of my words with mild amusement.
Cheers
  #29
Old April 24th 08, 11:48 PM posted to rec.aviation.piloting,rec.aviation.student
Stefan
it for us?
It's the "having to accelerate with the wind" part which is complete BS
unless I completely misunderstand what you are trying to say.
  #30
Old April 25th 08, 12:00 AM posted to rec.aviation.piloting,rec.aviation.student
WingFlaps
it for us?
The latter I think. The imposed accelerations associated with the
change in direction (from upwind to downwind) require control inputs
that add drag and increased energy loss (from drag).
To summarise your missed point, the pilot control inputs cost energy
that is not factored into simple glide/time analysis.
Cheers
lancair crash scapoose, OR gatt Piloting 10 October 26th 06 03:34 PM
Lancair IV Dico Reyers Owning 6 October 19th 04 11:47 PM
Lancair 320 ram air? ROBIN FLY Home Built 17 January 7th 04 11:54 PM
Lancair 320/360 kit wanted!!! Erik W Owning 0 October 3rd 03 10:17 PM
Lancair IVP Peter Gottlieb Home Built 2 August 22nd 03 03:51 AM
