Isn't lift part of drag?
Old April 25th 08, 09:16 PM posted to rec.aviation.piloting
Robert M. Gary
Default Isn't lift part of drag?
On Apr 25, 12:47*pm, "Peter Dohm" wrote:
There are a lot of trade offs,
Not always. There is no trade off between a model-T and a modern car.
Technology innovation allows for increased efficiency that does not
necessarily require any trade-off other than the RND time required to
develop.
-Robert
Old April 25th 08, 09:43 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Peter Dohm" wrote in
news:5d0da5e0-2006-442e-8e74-
On Apr 25, 10:55 am, "Robert M. Gary" wrote:
On Apr 25, 5:23 am, es330td wrote:
Fortune magazine online has a photo essay about their new 787. On
one
page,
http://money.cnn.com/galleries/2008/.../gallery.boein
g_dream..., they make this statement:
The Dreamliner's wingspan is 197 feet, or about 25% longer than a
similar-sized plane, which increases lift and reduces drag.
I thought that lift, in addition to causing a net upward force on
the wing, also contributes to the drag force on the wing as well.
If this is the case then increasing lift should also increase
drag. Did I misunderstand?
It could be more efficient. The Mooney wing produces more lift for
the amount of drag than a Cessna wing.
-Robert
From the original statement, it seems clear that they're
referring to the increase in efficiency that come from aspect ratio.
I wonder, now, if that increased span was made possible with the use
of composites instead of aluminum? Longer wings flex more, and
aluminum fatigues faster, I think, than composite construction. And
carbon or aramid fibers are stronger per unit weight than aluminum.
Dan
There are a lot of trade offs, and the gate spacing might also be
larger at the airports that the Dreamliner is expected to serve.
Also, IIRC, a few years ago, Boeing talking about future aircraft with
folding wing tips to overcome some of the spacing problems at the
gates. I also agree with you, that advances in materials also play a
major role.
It's not going to be that big. The widebody Busses ( A 330 and 340) are
already massive with a much larger span than the 747 so it shouldn't be
an issue.
Bertie
wide wingspan and good lift to drag ratios Tony Piloting 6 March 13th 06 01:19 AM
8 Percent More Lift and 32 Percent Less Drag Larry Dighera Piloting 9 September 7th 05 12:02 AM
about lift and drag coefficient for cessna C-160 Grandss Piloting 9 August 15th 05 06:15 PM
Lift-to-Drag Ratio? Toks Desalu Home Built 6 November 23rd 03 10:53 PM
Drag - Anti/Drag Wires log Home Built 3 August 28th 03 07:06 AM
