#21
![]() Gezellig wrote: Last Friday, I went up for an introductory flight lesson out of the San Carlos airport. WOW!!!!!! I have been dreaming about learning to fly since I was in my teens. All the time I was in the air the lines of that famous poem kept going through my head "Oh, I have slipped the surly bonds of Earth.........". When we landed (I didn't want to ever come down :-)) the instructor asked me if I thought I would be interested in flying and I told him that wild horses couldn't stop me now and proceeded to sign-up for two flight days the following week. I had my second flight day, this afternoon, practicing a variety of turns while maintaining (or making attempts to) altitude. One question I had for the instructors out there - what I seemed to find more awkward than anything was steering the nose wheel using my feet on the rudder pedals. The people in the control tower must have thought I looked like a wounded bird taxing out to hold position before takeoff. Is there some 'trick' to getting the hang of this, so often I would be tempted to reach up and turn the control yoke but resisted the temptation (due to its futility). Once again, thank you all for your posts on this newsgroup. I finally just made myself go out and start. I fly again, on Friday and will keep you posted. Meanwhile I am going to pour over some of the aviation training books to review some of the things I learned today. Just starting out, but I am so excited! My instructor made me put my left hand on my knee for the first lessons to get the hang of it. You will have to be carefull when you get into doing landings in gusty conditions, you might find yourself going back steering with your hands when under a bit of stress. James. |
On May 1, 11:08*am, Gezellig wrote:
Last Friday, I went up for an introductory flight lesson out of the San Carlos airport. *** Hey, congratulations on getting started! SQL is my home field too. If you're interested, peruse my avation page at http://www.tr2.com/jerry/aviation/index.html. Go about half way down and click on "My Flying Lesson Journals" and you can read about how I learned to fly right here. Well, mostly at PAO and SJC, but same area. - Jerry Kaidor |
On May 3, 2:49 pm, James wrote:
My instructor made me put my left hand on my knee for the first lessons to get the hang of it. You will have to be carefull when you get into doing landings in gusty conditions, you might find yourself going back steering with your hands when under a bit of stress. James. Seven Learning Factors taught to new instructors. The first one is Primacy, which says that first iimpressions are the strongest. The fist few taxis with the hand on the leg will establish a lifelong habit. We teach controls for wind right off. Student needs to get it right the first time. Wingflap's suggestion of putting pressure on both rudder pedals is another bad idea. Nervous students already stand on them, and they'll only put more pressure on them if told to do so. I see worn-out rudder control system parts from just that, since in most lightplanes that tension is transmitted down both cables to the rudder horn itself. Rudder hinges, clevis bolts and their holes, pulleys and cables, rudder bars and pedals, all wear much faster than usual if they're under constant tension. And the pushback on the seat wears all that stuff out, too. Takes time, but it does wear. And a tense pilot is a jerky, clumsy pilot. I often found my students bumping all over the place and noticed that they had the white-knuckle grip. Making them hold the yoke between a couple of fingers allowed the airplane to magically settle down and fly real smooth. Amazing. Dan |
On May 6, 4:54*am, wrote:
* * * * Wingflap's suggestion of putting pressure on both rudder pedals is another bad idea. Nervous students already stand on them, Not all nervous students stand on the pedals. Where do you get these ideas? Even today I still keep slight pressure on both pedals. Do you? Cheers |
![]() What the heck I'll through in my 2.5 cents worth. One thing my instructor taught me that pretty much cured the problem right aways was to basically have dancing feet. Keep those feet in constant but very small movements. Left, right, left, right not really pushing the rudders except when necessary, but small amounts to the direction you need to go. This way constant correction is easy and immediate. Just keep those feet moving lightly. Lou |
Lou formulated the question :
What the heck I'll through in my 2.5 cents worth. One thing my instructor taught me that pretty much cured the problem right aways was to basically have dancing feet. Keep those feet in constant but very small movements. Left, right, left, right not really pushing the rudders except when necessary, but small amounts to the direction you need to go. This way constant correction is easy and immediate. Just keep those feet moving lightly. Lou lol Agree with that, which I tried and it sure helped. |
Mark Hansen wrote on 5/2/2008 :
Hello, I just began flight training and had a similar problem with steering on the ground. My guy says left hand on your knee and right on the throttle. It is too easy to wind up going too fast, especially when you are new. (for me anyway) give it a little gas to move the plane then have your hand on the throttle to adjust speed. Just remember that while these are good tactics for getting used to controlling direction with the rudder pedals, you don't want to make this a permanent habit. You'll generally need one hand on the yoke/stick to apply proper control deflections for any cross winds that may be blowing across your taxi route. This will come a little later in your training. Best Regards, I tried the hand placements and they felt good for the first time or two. After that, It felt wrong because of what you said. Good advice from everyone. |
#29
#30
Morgans was thinking very hard :
"Gezellig" wrote WOW you guys are great, thanks for all the pointers, I learned sumpin from everyone. I'm chair sitting, sledding and reading all at once! Just remember that it steers backwards, as compared to a runner sled! g lol got it! |
Training | [email protected] | Instrument Flight Rules | 1 | August 12th 05 02:04 PM |
Training | [email protected] | Aviation Marketplace | 0 | August 11th 05 02:10 AM |
Training | Ruski | Soaring | 4 | August 1st 05 11:48 PM |
Training Q - Is this appropriate | Jules | Instrument Flight Rules | 1 | August 6th 04 05:57 AM |
Yak 52 Training | gpa | Aerobatics | 0 | November 10th 03 06:15 AM |
