#21
On Fri, 9 May 2008 17:26:18 -0500, "Viperdoc"
wrote in : Don't worry, it's just Larry being Chicken Little again, running around saying the sky is falling. So, when you're unable to address the issues raised, you dismiss the author? That's considerably easier than explaining how USAF UAV _training_ over populated areas is warranted. |
The sky is falling! Let's run around a scare everyone!
Larry Dighera wrote:
On Fri, 09 May 2008 22:35:05 GMT, wrote in : Larry Dighera wrote: On Fri, 09 May 2008 22:05:02 GMT, wrote in : In a war theater there is no need for those sorts of safeguards, so training operations employing hardware not designed for civil operation is inappropriate. So there should be training bombers and war bombers, training tanks and war tanks, training rifles and war rifles, training Humvees and war Humvees... No. If at all, there should be UAVs that are designed for domestic operations during peacetime, instead of hardware designed for use in war theaters being used domestically. And what precisely would be the difference between a "peacetime" UAV and a "war theater" UAV? I will go way out on a limb here and assume you know the military doesn't use live ordinance for training outside of ranges established for that purpose. -- Jim Pennino Remove .spam.sux to reply. |
On May 9, 6:09*pm, Larry Dighera wrote:
So, when you're unable to address the issues raised, you dismiss the author? *That's considerably easier than explaining how USAF UAV _training_ over populated areas is warranted. * Duck Season ! Wabbit Season ! Duck Season ! Wabbit Season ! Duck Season ! Wabbit Season ! Duck Season ! Wabbit Season ! |
On May 9, 6:23*pm, "Viperdoc"
The sky is falling! Let's run around a scare everyone! Here is what really scares me ; If we go and remove all the elements found to cause cancer in mice, someday we could be overrun by billions of robust healthy rodents ! F Baum |
![]() "Larry Dighera" wrote in message ... No. If at all, there should be UAVs that are designed for domestic operations during peacetime, instead of hardware designed for use in war theaters being used domestically. Why? And unless the military can show good cause to train over cities, their UAV training should be restricted to unpopulated areas. What's the mission of the UAV? |
![]() "Larry Dighera" wrote in message ... On Fri, 09 May 2008 21:05:04 GMT, wrote in : You are roughly 80 some years too late to "establish a precedent". Please provide objective evidence that the military has been operating UAVs over populated areas for 80 years. Why are you suddenly limiting the discussion to UAVs? Your original post starts out with these words: "Should military hardware be permitted to operate over the heads of citizens in the CONUS?" To me, that means ANY military hardware. That would effectively prevent the Military from using any airport that was not in the middle of some wasteland. So if that is NOT what you meant to say, here is your golden opportunity to issue a correction. Vaughn |
On Sat, 10 May 2008 12:54:19 GMT, "Vaughn Simon"
wrote in : "Larry Dighera" wrote in message .. . On Fri, 09 May 2008 21:05:04 GMT, wrote in : You are roughly 80 some years too late to "establish a precedent". Please provide objective evidence that the military has been operating UAVs over populated areas for 80 years. Why are you suddenly limiting the discussion to UAVs? Your original post starts out with these words: "Should military hardware be permitted to operate over the heads of citizens in the CONUS?" To me, that means ANY military hardware. That would effectively prevent the Military from using any airport that was not in the middle of some wasteland. So if that is NOT what you meant to say, here is your golden opportunity to issue a correction. Vaughn Your inference of my words is perfectly reasonable if the context of the article is disregarded. The subject was UAVs after all. |
#30
On Fri, 9 May 2008 19:02:06 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . The airlines and GA do not operate hardware DESIGNED FOR MILITARY USE over the heads of the US populous. So what? Are you saying hardware DESIGNED FOR MILITARY USE is more likely to fall out of the sky? I'm saying the design criteria for equipment used in the war theater is substantially different from that of equipment designed for use domestically. I presume the necessity to safeguard the public in domestic operations would not be nearly as paramount for war apparatus. Is there some specific reason the military MUST operate their UAV over populated areas? Any thinking human being would assume the mission called for it. Call me unimaginative, but I am unable to envision such a mission that would justify domestic operation. Are you able to provide an example or two of such missions? Why do you think the military operates their UAV over populated areas? Because it's convenient and expedient (if the hazards are disregarded). I believe permitting the military to establish a precedent of training over populated areas is not in the best interest of our citizens. I don't believe many citizens care what you believe. Perhaps that will change if/when a military UAV causes harm to one or two. Why do you find it necessary to defend the military over the best interests of the citizens of our noble nation? It isn't necessary. The situation is not as you see it. How do you see it? |
Piper J3 cub training in the Bay Area? | Little Endian | Piloting | 2 | September 24th 07 04:26 AM |
USS Eisenhower Training Exercise Comms | [email protected] | Naval Aviation | 1 | April 20th 06 12:14 PM |
Navy helo pilots plan tactical training in multi-phase exercise | Otis Willie | Naval Aviation | 7 | August 23rd 05 10:41 PM |
Flight over densely populated areas | JK | Home Built | 17 | March 29th 05 07:29 AM |
helo training in the PHL/NJ area? | Dave | Rotorcraft | 1 | April 27th 04 01:01 AM |
