"Maxwell" luv2^fly99@cox.^net wrote in
: "Bertie the Bunyip" wrote in message .. . You couldn't stop if your life depended on it, could you Squirty ****drip? Squirt, squirt. You betcha.. Bertie |
Mxsmanic wrote:
When do you use boost pumps on small GA aircraft? The purpose of a fuel boost pump is to assure adequate fuel flow in all flight conditions, especially in a nose high attitude when the tanks are nearly empty; where the height difference between the fuel level and the engine pump is considerable. Another vulnerability is on hot days when vapor lock in hot spots nearer the engine is possible. It probably is discovered by the test pilot in the ceritifcation process that fuel starvation occurred in some situations. Thereafter, the manufacturer of that aircraft is obliged to install one in the aircraft, likely in a low and cold spot such as under the cabin, then certify that it solves these problems, then tell in the flight manual how and when to apply it. The pilot is obliged to comply. The most applicable condition is that it should be used on every takeoff until flight climb is stabilized.... Angelo campanella |
On May 12, 7:28 am, Angelo Campanella wrote:
Mxsmanic wrote: When do you use boost pumps on small GA aircraft? The purpose of a fuel boost pump is to assure adequate fuel flow in all flight conditions, especially in a nose high attitude when the tanks are nearly empty; where the height difference between the fuel level and the engine pump is considerable. Another vulnerability is on hot days when vapor lock in hot spots nearer the engine is possible. It probably is discovered by the test pilot in the ceritifcation process that fuel starvation occurred in some situations. Thereafter, the manufacturer of that aircraft is obliged to install one in the aircraft, likely in a low and cold spot such as under the cabin, then certify that it solves these problems, then tell in the flight manual how and when to apply it. The pilot is obliged to comply. The most applicable condition is that it should be used on every takeoff until flight climb is stabilized.... Angelo campanella Boost pumps are often used even on high-wing airplanes if the engine also has a mechanical fuel pump. Some systems don't have enough flow capacity via gravity alone and need the pump, and any pump needs a backup. Low-wing airplanes having fuel in the wings need a pump, of course, to lift the fuel, and that's where vapor-lock becomes a hazard, when the fuel is being pulled from the engine end of the system. A good boost pump system there has the boost in the tank itself, so the fuel is pushed all the way. Pressure on the fuel raises its boiling point and vapor lock disappears. Dan |
Angelo Campanella writes:
The purpose of a fuel boost pump is to assure adequate fuel flow in all flight conditions, especially in a nose high attitude when the tanks are nearly empty; where the height difference between the fuel level and the engine pump is considerable. Another vulnerability is on hot days when vapor lock in hot spots nearer the engine is possible. It probably is discovered by the test pilot in the ceritifcation process that fuel starvation occurred in some situations. Thereafter, the manufacturer of that aircraft is obliged to install one in the aircraft, likely in a low and cold spot such as under the cabin, then certify that it solves these problems, then tell in the flight manual how and when to apply it. The pilot is obliged to comply. The most applicable condition is that it should be used on every takeoff until flight climb is stabilized.... OK, thanks. Given the advantages that you cite, why wouldn't one leave the boost pump on all the time? |
On May 12, 9:12 am, Mxsmanic wrote:
OK, thanks. Given the advantages that you cite, why wouldn't one leave the boost pump on all the time? Because it will wear out for no good reason and maybe not work when you need it. If you have altitude and the engine-driven pump fails, you cant turn on the boost without losing much altitude. Most boost pumps are electric, either motor driven or some sort of solenoid- piston arrangement. The motor has brushes and bearings that wear out much faster than a mechanical engine-driven pump, and the solenoid affair has a switch that burns out. There are some electronically- driven pulsation pumps, but they, too, suffer from heat and wear. The boost need only be on if the main pump fails, or if you are taking off or landing where a loss of power, even for a few seconds, would be disastrous. Dan |
![]() wrote in message ... On May 12, 9:12 am, Mxsmanic wrote: OK, thanks. Given the advantages that you cite, why wouldn't one leave the boost pump on all the time? Because it will wear out for no good reason and maybe not work when you need it. If you have altitude and the engine-driven pump fails, you cant turn on the boost without losing much altitude. Most boost pumps are electric, either motor driven or some sort of solenoid- piston arrangement. The motor has brushes and bearings that wear out much faster than a mechanical engine-driven pump, and the solenoid affair has a switch that burns out. There are some electronically- driven pulsation pumps, but they, too, suffer from heat and wear. The boost need only be on if the main pump fails, or if you are taking off or landing where a loss of power, even for a few seconds, would be disastrous. Dan You're feeding a troll. |
: wrote in message news:213d884c-ad6d-4e57-bc15-46e4c76b8ae8 @w5g2000prd.googlegroups.com.. . On May 12, 9:12 am, Mxsmanic wrote: OK, thanks. Given the advantages that you cite, why wouldn't one leave the boost pump on all the time? Because it will wear out for no good reason and maybe not work when you need it. If you have altitude and the engine-driven pump fails, you cant turn on the boost without losing much altitude. Most boost pumps are electric, either motor driven or some sort of solenoid- piston arrangement. The motor has brushes and bearings that wear out much faster than a mechanical engine-driven pump, and the solenoid affair has a switch that burns out. There are some electronically- driven pulsation pumps, but they, too, suffer from heat and wear. The boost need only be on if the main pump fails, or if you are taking off or landing where a loss of power, even for a few seconds, would be disastrous. Dan You're feeding a troll. No, actually, you are, fjukktard. But since you're a k00k, you'll neve see it! God I love k00ks. |
Boost control for turbonormalizing. | [email protected] | Home Built | 3 | October 12th 06 04:06 AM |
Soundwaves Boost Wing Lift | [email protected] | Home Built | 30 | September 5th 05 10:21 PM |
how to boost vhf scanner | NW_PILOT | Piloting | 5 | January 9th 05 10:27 AM |
Weldon boost pump | keepitrunning | Home Built | 2 | January 6th 05 07:52 PM |
Boost phase interceptor. . . | Scott Ferrin | Military Aviation | 4 | December 5th 03 10:36 AM |
