Cessna 172R from Telluride to Aspen
Old May 10th 08, 05:55 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Cessna 172R from Telluride to Aspen
"Viperdoc" wrote in
What altitude, what route, what was the weather and DA, weight and
balance? How can you expect an answer without at least this
information as a minimum?
He he!
Has he ever gotten an answer?
Bertie
Old May 10th 08, 06:12 PM posted to rec.aviation.piloting
Mxsmanic
Viperdoc writes:
What altitude, what route, what was the weather and DA, weight and balance?
A very gradual climb from the airport elevation to 12500. The route was
ETL.MTJ.RIL.DBL, flown VFR. Weather was approximately (two hours have now
elapsed)
KTEX 101610Z AUTO 27009KT 10SM SCT025 SCT035 BKN060 03/M01 A3019 RMK AO2
KASE 101614Z 34006G14KT 7SM BKN017 BKN035 M01/M04 A3014 RMK AO2 SNE05 P0000
KRIL 101553Z AUTO VRB04KT 10SM FEW050 08/M01 A3013 RMK AO2 SLP179 T00781011
TSNO
KASE had 1SM and blowing snow and fog at the time of my flight.
Aircraft weight was 2426 lbs with 336 lbs of fuel.
How can you expect an answer without at least this information as a minimum?
Gross discrepancies between what is required and what the aircraft can do
would not require that level of detail, but since you've asked for it, I've
provided it.
Old May 10th 08, 06:15 PM posted to rec.aviation.piloting
Mxsmanic wrote in
Viperdoc writes:
balance?
was ETL.MTJ.RIL.DBL, flown VFR. Weather was approximately (two hours
have now elapsed)
AO2 KASE 101614Z 34006G14KT 7SM BKN017 BKN035 M01/M04 A3014 RMK AO2
SNE05 P0000 KRIL 101553Z AUTO VRB04KT 10SM FEW050 08/M01 A3013 RMK AO2
SLP179 T00781011 TSNO
minimum?
do would not require that level of detail, but since you've asked for
it, I've provided it.
You had blowing snow in your cold water apartment?
Bertie
Old May 10th 08, 09:31 PM posted to rec.aviation.piloting
Viperdoc
You didn't include the area forecast and any sigmets or airmets. What is the
climb rate in a 172 for the given W/B at the temperature and altitude you
mentioned?
Uncontrolled Engine Compartment Fire Possible for Cessna 172R, 172S, 182T, T182T, 206H, and T206H Models Larry Dighera Piloting 0 April 19th 07 04:31 PM
'99-'00 172R vs 172SP: R is good? or the weak little brother? XrayYankee Owning 9 May 1st 06 06:07 AM
C-172R to SP upgrade Greg Farris Owning 5 May 6th 05 10:17 AM
172P vs 172R for instrument platform..... Jonathan Instrument Flight Rules 6 July 22nd 04 01:52 AM
FS: 1997 Cessna 172R Alan Adamson Aviation Marketplace 1 June 1st 04 12:57 PM
