"Guy Alcala" wrote in message
. .. "Paul J. Adam" wrote: In message m, David E. Powell writes Third. did the F-102 have a gun or just internal missiles in a weapon bay? Falcon missiles (six IIRC) in the bay, plus 24 x 2.75" rockets (launch tubes in the bay doors). From memory there were twelve tubes each with two rockets nose-to-tail: this was sometimes downloaded to twelve, and F-102s in Vietnam did some very light ground attack (using their IR sensor to find targets like campfires and the rockets to engage). My recollections may be at variance with the facts, so check before using ![]() Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. *There was a massive "Was GENIE a rocket or a missile" debate on another group, which I won't get into here. I think the verdict was a rocket, which it was, guided missile or not. Unguided (and hence unjammable, but demanding to use correctly) OK.... Jack Broughton was less than confident about the Genie's accuracy. He compared firing one to tying a piece of string around your finger and the other end around the trigger of a shotgun. When you wanted to fire the shotgun, you threw it away from you and it fired when the string pulled taught, with the accuracy you'd expect under such conditions. He goes on (I've left his spelling unchanged): "Two specific cases made me a non-Geenie [sic] fan. The first Geenie that was test-fired from an F-106 came right back up, blew the nose off the aircraft, and killed the pilot. Years later I got a chance to go to Tyndal [sic] with my F-106 squadron. ADC had saved their resources too well and wound up with a large number of Geenies that only had a few days to go before they would run out of shelf life and have to be destroyed. The plan was to fire as many of them as fast as we could, so for a week straight we saturated the Gulf of Mexico with every Geenie that we could get to accept the firing signal and leave our aircraft. They took off in all directions, but very seldom towards the target drones. One particular Geenie turned hard left as I fired and I watched it do lazy concentric barrel rolls as it headed straight down to my left. I knew that if it was for real the boom only had to be close, but suppose straight down and to the left was the area I was supposed to be defending? Well, the other theory of the times was that we would be intercepting all the invading bombers way up north someplace, where I wouldn't know anybody living off to my lower left." Over tundra or ocean would have been the ideal use considered, I guess.... [quoted from "Going Downtown", by Jack Broughton] Guy |
In message m, David
E. Powell writes Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. No, it sucked really badly (less than 5% Pk in Vietnam, although against fighters at low level with some hostile factors) but it was a low priority for replacement or enhancement. -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
"Paul J. Adam" wrote in message
... In message m, David E. Powell writes Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. No, it sucked really badly (less than 5% Pk in Vietnam, although against fighters at low level with some hostile factors) but it was a low priority for replacement or enhancement. Whoa - Considering how long they served I would have thought the opposite. Maybe it was felt they had better odds against bombers. Or there was some sort of upgrade by the '80s. Considering alot of ANG fighters that escorted bombers up and down the seacost in the Cold War carried them. I wonder if GWB ever flew with the nuclear version....? DEP Maybe that's why the F-106 got a cannon.... -- When you have to kill a man, it costs nothing to be polite. W S Churchill Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk |
"Paul J. Adam" wrote in message ... In message m, David E. Powell writes Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. No, it sucked really badly (less than 5% Pk in Vietnam, although against fighters at low level with some hostile factors) but it was a low priority for replacement or enhancement. The real deal is that most F-106s were decoys, by the mid 1970s. |
"Paul J. Adam" writes: In message m, David E. Powell writes Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. No, it sucked really badly (less than 5% Pk in Vietnam, although against fighters at low level with some hostile factors) but it was a low priority for replacement or enhancement. As an anti-fighter weapon, it suffered from 2 serious flaws: It had an extremely long initialtion time - the delay between when you decide to fire the missile, and the missile has to be woken up, (The batteries started, gyros brought up to speed, the seeker receiver warmed up & tuned, for a radar missile, or, in the case of an IR Falcon, cooled for more sensitivity, and then the missile is "briefed", if you will, by the Fire COntrol System on the airplane, so that the seeker is looking at the right target, and the range & velocity gates are set correctly. With a Falcon, as I understand it, this could take 5-10 seconds, which is a danged long time, in a dogfight. But, then, a MiG-17 pulling 8Gs on the deck is a different matter than an Mya-4 pulling 2 Gs at 36,000'. The second problem was that the Falcons never got a Proximity Fuze. Prox Fuzes are just about the most difficult systems that a missile will have - they have to take into account the shape of the fragment pattern of the warhead, and the velocity that the fragmants will have. A simple "Closest Approach" fuze will inievietably fire late. It's much more difficult for a missile than for an artillery shell, becasue the missile has to deal with a larger variety of closing velocities adn aspect angles. Almost all Falcons had to actually hit the target to detonate the warhead. That's perhaps, not unrealistic when you're firing a salvo of them at a big bomber-sized target, but it's very unlikely that it will be successful against a maneuvering fighter. (Secret Analysts Trick - When somebody boasts that they've invented a "Hittile", a missile so accurate that it doesn't need a Proximity Fuze, that menasn that they couldn't get one to work, and thas are trying to make a feature out of a bug.) -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
I seem to recall that one method of employing the 2.75 rocket against a
bomber entailed a 'beam' attack where the heading crossing angle (between the interceptor and target) was somewhere in the vicinity of 135 degrees. IIRC the combination of short range and high closure caused for a VERY interesting time in 'getting out of the way' of the debris (assuming you hit anything; and if you didn't not running into the side of the target) Mark "David E. Powell" wrote in message s.com... "Guy Alcala" wrote in message . .. "Paul J. Adam" wrote: In message m, David E. Powell writes Third. did the F-102 have a gun or just internal missiles in a weapon bay? Falcon missiles (six IIRC) in the bay, plus 24 x 2.75" rockets (launch tubes in the bay doors). From memory there were twelve tubes each with two rockets nose-to-tail: this was sometimes downloaded to twelve, and F-102s in Vietnam did some very light ground attack (using their IR sensor to find targets like campfires and the rockets to engage). My recollections may be at variance with the facts, so check before using ![]() Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. |
Question on the F-102: When the pilot went to fire missiles, he presumably had to open the missile-bay doors. Could this be done at supersonic speeds, or what speed did he have to slow to? all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
"David E. Powell" wrote in message ws.com...
"Guy Alcala" wrote in message . .. "Paul J. Adam" wrote: In message m, David E. Powell writes Third. did the F-102 have a gun or just internal missiles in a weapon bay? Falcon missiles (six IIRC) in the bay, plus 24 x 2.75" rockets (launch tubes in the bay doors). From memory there were twelve tubes each with two rockets nose-to-tail: this was sometimes downloaded to twelve, and F-102s in Vietnam did some very light ground attack (using their IR sensor to find targets like campfires and the rockets to engage). My recollections may be at variance with the facts, so check before using ![]() Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. The Northrop Scorpion was the F-89; the F-94 was the Lockheed Starfire. Both carried 2.75 inch unguided rockets: the Scorpion in wingtip pods that also carried jet fuel, and the Starfire in the aircraft's nose and in small pods halfway out on the wings. Peter Wezeman anti-social Darwinist Suddenly, Jacques found himself looking down the barrel of George's Hyper-Power. |
"peter wezeman" wrote in message m... "David E. Powell" wrote in message ws.com... "Guy Alcala" wrote in message . .. "Paul J. Adam" wrote: In message m, David E. Powell writes Third. did the F-102 have a gun or just internal missiles in a weapon bay? Falcon missiles (six IIRC) in the bay, plus 24 x 2.75" rockets (launch tubes in the bay doors). From memory there were twelve tubes each with two rockets nose-to-tail: this was sometimes downloaded to twelve, and F-102s in Vietnam did some very light ground attack (using their IR sensor to find targets like campfires and the rockets to engage). My recollections may be at variance with the facts, so check before using ![]() Thanks! I hadn't known about the 2.75 rockets, sounds like the F-94 Scorpion. The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. The Northrop Scorpion was the F-89; the F-94 was the Lockheed Starfire. Both carried 2.75 inch unguided rockets: the Scorpion in wingtip pods that also carried jet fuel, and the Starfire in the aircraft's nose and in small pods halfway out on the wings. if you will check, the 89 carried various armament, depending on the model, including .50 cal, AIM 4s and 2.75s and the Genie Rocket(AIR2A). |
On Sat, 14 Feb 2004 18:11:59 GMT, "David E. Powell"
wrote: The Falcon must have been a decent missile, the -106s and other fighters used them into the 80s and early 90s. The book "Sidewinder" is rather scathing about "competition" from the Falcon development team. An interesting contrast. http://www.amazon.com/exec/obidos/ASIN/1557509514/codesmiths It's an excellent read BTW - especially if you're a project manager in any sort of technology company. |
| Thread Tools | |
| Display Modes | |
| Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 01:38 AM |
| Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 10:38 PM |
| bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 05:26 PM |
| us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 05:24 AM |
| D.C. Air Guard Unit Flies New 737s | Otis Willie | Military Aviation | 0 | January 15th 04 12:12 AM |
