Maybe I should have mentioned. I have mylars on all surfaces. I did
them last season using all the specified procedures; wax removal, scuffing/sanding, pressure applied with roller, sately tape, etc. They are well bonded and in perfect shape. The real question here is whether to remove the mylar on the elevator as a precaution. I also inspect them thoroughly every time I rig. |
![]() wrote in message ... .. The real question here is whether to remove the mylar on the elevator as a precaution. The answer is definitively no. |
Mylar seals for PIK20D | culverflyer | Soaring | 5 | May 19th 04 06:25 PM |
Mylar seals installation | John W | Soaring | 2 | May 5th 04 09:03 PM |
mylar seals wing to flap/ Aileron | culverflyer | Soaring | 2 | May 5th 04 02:52 PM |
ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 03:45 PM |
mylar seals | D.A.L | Soaring | 1 | February 23rd 04 07:15 PM |
