Sky High Av gas **** you off?
Old June 2nd 08, 10:15 PM posted to rec.aviation.piloting
gatt[_5_]
Default Sky High Av gas **** you off?
Gig 601Xl Builder wrote:
It is only financially rewarding because it was made politically correct
to be an environmentalist.
Depends on where you live and the specific issues. There are more types
and degrees of environmentalists out here as there are states in the
union.
-c
Old June 2nd 08, 10:24 PM posted to rec.aviation.piloting
Larry Dighera
On Mon, 02 Jun 2008 20:15:02 GMT, wrote in
Larry Dighera wrote:
On average around the world, sunlight delivers a barrel of oil of
energy on every square meter of land every year. At $100 a barrel,
a 100m2 roof is receiving $10,000/yr of energy - a quarter of a
million dollars over 25 years. With photovoltaic systems we can
convert up to 20% of this raw energy directly into electricity.
Electricity has little to nothing to do with oil.
Perhaps not directly, but if the GM Volt* (and hybrid autos) is(are)
successful, the replacement of the current crop of gas guzzling SUVs
with alternatively powered automobiles could eventually impact oil
consumption in the US due, not only to their not using (as much)
petroleum, but also due to their increased efficiency (MPG). Add to
that the use of solar energy to fuel them, thus replacing/reducing the
current requirement for petroleum.
This is just apples and oranges arm waving.
You've got to look beyond the obvious to appreciate how solar power
can impact oil consumption. If hybrid automobiles provide higher MPG
ratings, and solar power spins electric meters backwards, I would
anticipate petroleum consumption to be reduced. Don't you agree?
The other minor problem no one cares to address is that contrary to
what most people think, peak electricity demand is typically after
sundown.
We are both California residents. As I recall, the rolling
blackouts** of the beginning of this century occurred during the day
primarily due to air conditioning loads. Are you able to cite any
statistics that support your assertion that "peak electricity demand
is typically after sundown?" I can see where illumination loads might
increase, but other loads should be significantly reduced at night,
IMO.
http://gm-volt.com/
Q: How many miles per gallon will the Chevy Volt get?
A: A bit of a trick question. For the first 40 miles it will get
infinite mpg, because no gas will be burned. When the generator
starts, the car will get an equivalent of 50 mpg thereafter. One
can calculate the average mpg per for any length drive starting
with a full battery: Total MPG = 50xM/(M-40)
Q: What is the cost of operation of the car
A: With current average U.S. electric rates of ~10 cents/kwh it
should cost 80 cents to drive for the first 40 miles, and then 50
mpg thereafter using gasoline (market rate).
** http://en.wikipedia.org/wiki/Rolling...out#California
Old June 2nd 08, 11:46 PM posted to rec.aviation.piloting
Gezellig
On Mon, 02 Jun 2008 16:56:59 -0400, SOS wrote:
Guess what? I don't give a ****
nEITHER DO i.
*plonk*
Old June 2nd 08, 11:55 PM posted to rec.aviation.piloting
But it could.
And if frogs had built in parachutes they could land softly instead of
banging their butts so hard when they land, but they don't.
Jim Pennino
Remove .spam.sux to reply.
Old June 3rd 08, 12:25 AM posted to rec.aviation.piloting
If and eventually are a long way away.
Roughly 40% of US vehicles are over 10 years old; factor that into
the projection of how long it will take before electric cars make
a difference in anything once they actually exist.
Once again, electricity has little to nothing to do with oil.
Spinning electric meters backwards won't reduce oil consumption.
sundown.
IMO.
Like I said, the reality is contrary to what most people think.
For about 9 months out of the year, peak electric demand occurs at
about 9PM and DST doesn't change that fact.
For about 3 months out of the year, i.e. the hot part, you get two
peaks, one at mid afternoon and another at about 9 PM.
Here's the current demand for California:
http://www.caiso.com/outlook/SystemStatus.html
Here's some historical data:
http://mail.specsol.com/~jimp/caiso.php
When the weather starts hitting around 80, the daytime hump picks
up.
When the weather starts hitting the 90's, the hump gets huge and
the blackouts occur.
This is consistant for all power producers in the first world and not
unique to either California or the United States.
So, how many solar plants can one put up before you have idle plants
for 8 to 9 months out of the year and where do you get power at night?
And once again, electricity has little to nothing to do with oil.
Jim Pennino
Perhaps. But with the current record market prices for crude oil, you
can bet photo voltaics will become a lot more popular and attractive
to the general public as solar electricity becomes more competitive
with coal/natural gas/oil. While that won't directly relieve the
financial burden on pilots, in the long run it could reduce our
nation's dependency on petroleum based energy. That's got to be a
good thing for US independence from the whims of foreign nations as
well as being more environmentally friendly.
Non sequitur.
Electricity doesn't compete with oil and one has nothing to do with
the other in the existing, real world.
Coal is not oil and US coal comes from the US.
Natural gas is not oil and US natural gas comes from the US and Canada.
Personally, I don't see the demand for energy slacking any time soon,
so I foresee a much longer investment cycle in the solar and wind
power marketplace.
Until the subsidies run out like last time.
Jim Pennino
Old June 3rd 08, 12:49 AM posted to rec.aviation.piloting
Steve Foley
I can use all of the above to heat my house. In the last 12 months, I spent
$2200 on natural gas. My sister-in-law heats with electricity.
For this purpose, they're interchangable.
I forget - Kalifornia isn't the real world.
  #29
Old June 3rd 08, 01:53 AM posted to rec.aviation.piloting
Larry Dighera
On Mon, 02 Jun 2008 23:25:03 GMT, wrote in
wrote in
To the extent solar energy is used to power automobiles, I would
expect it to displace gasoline.
Many thanks for that. Indeed it seems that a very significant
proportion of the energy consumed occurs in the evening as you stated.
up.
I see no reason for idle solar generating facilities located in the
Mojave Desert during any part of the year. However, it appears that
SoCal Edison prefers solar generation occur a little closer to where
its needed:
http://www.forbes.com/businesswire/f...7005373r1.html
Southern California Edison Launches Nation's Largest Solar Panel
Installation
03.27.08, 3:02 AM ET
Southern California Edison (SCE) today launched the nation's
largest solar cell installation, a project that will place 250
megawatts of advanced photovoltaic generating technology on 65
million square feet of roofs of Southern California commercial
buildings - enough power to serve approximately 162,000 homes.
"These are the kinds of big ideas we need to meet California's
long-term energy and climate change goals," said Governor
Schwarzenegger. "I urge others to follow in their footsteps. If
commercial buildings statewide partnered with utilities to put
this solar technology on their rooftops, it would set off a huge
wave of renewable energy growth."
"This project will turn two square miles of unused commercial
rooftops into advanced solar generating stations," said John E.
Bryson, Edison International chairman and CEO. "We hope to have
the first solar rooftops in service by August. The sunlight power
will be available to meet our largest challenge - peak load
demands on the hottest days."
SCE's renewable energy project was prompted by recent advances in
solar technology that reduce the cost of installed photovoltaic
gen...
The utility plans to begin installation work immediately on
commercial roofs in Southern California's Inland Empire, San
Bernardino and Riverside counties, the nation's fastest growing
urban region.
"These new solar stations, which we will be installing at a rate
of one megawatt a week, will provide a new source of clean energy,
directly in the fast-growing regions where we need it most," said
Bryson.
SCE sees numerous customer benefits from its new solar program,
among them locating the new generation in areas of growing
customer demand. And the clusters of solar modules SCE plans to
install will be connected directly to the nearest neighborhood
circuit, eliminating the need to build new transmission lines to
bring the power to customers. Additionally, solar units produce
the most power when customer usage is at its highest.
Wind, geothermal, hydro, and all the conventional sources, I suppose.
To the extent it can be made to replace petroleum products, I believe
it does.
  #30
Old June 3rd 08, 02:45 AM posted to rec.aviation.piloting
Yeah, so what?
Most building heat on the West side of the US is natural gas and has
been for about a half century.
You will be hard pressed to find any new construction (or within the
past couple of decades) that uses anything other than gas for building
heat in an area with a gas distribution system.
Using electricity for heat is a dumb idea unless you are getting
your power from the TVA for essentially nothing.
Jim Pennino
Fix the high cost [Was:] High Cost of Sportplanes Evan Carew Home Built 40 October 8th 05 04:05 AM
High Oil Pressure (was: Low oil pressure, high oil temp?) Thomas Ploch Owning 4 October 5th 04 04:34 AM
1972 piss test . . . so where was dubya ?? Transition Zone Military Aviation 8 September 23rd 04 04:48 AM
High And Low SelwayKid Piloting 5 July 18th 04 04:09 AM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
