![]() "WaltBJ" wrote in message om... Comments: 1) It is true that there is no theoretical limit to the size of a TNW. The practical limit is when the bomb vents to space rather than expanding across the surface of the earth. Big bombs are impractical since they blow the hell out of the hypocenter (spot directly under the bomb) but the radius of destruction increases as the cube root of the bomb's yield. One could take the same amount of critical material and make numerous smaller bombs and achieve a much greater area of destruction by carefully distributing them over the target zone. The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to the strategic balance was that it was undeliverable against the U.S. The weight of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum payload, and two and a half times its normal weapon load. Range of the Tu-95 was already marginal for attacking the U.S. even with a normal bomb load. Even worse, since the bomb's dimensions - 2 meters wide and 8 meters long - were larger than the bomb bay could accommodate part of the fuselage had to be cut away, and the bomb bay doors removed. The bomb was partially recessed in the plane, but not enclosed, with over half of it protruding in flight. A deployed version of a Tsar Bomba carrier would of course had a bulging bomb bay enclosure added, but this would have further reduced range from the drag. 2) I should think doctrine on the possible use of nuclear weapons took a serious hit when a real sober look was taken of the two nuclear accidents the USSR experienced - Chelyabinsk and Chernobyl. The USSR never ever achieved the capability to feed all its people from its own resources and what fallout from numerous nuclear weapons would do to the arable lands of the Ukraine really doesn't bear thinking about. The U.S. similarly vulnerable to this effect from the eastward fallout plumes of strikes on the Montana and Wyoming missile fields. In Stalin's day of course he would have grown radioactive wheat and fed it to the population. It would have saved them from starvation and immediate death, but given them a lifespan much reduced from normal. 3) FWIW I spent those Cold War years in Air Defense Command as an 86D, 102 and 104 pilot on active air defense alert, usually every third day, from 1954 through 1967, when I went to TAC and the F4. One got a real serious attitude about the Air Defense mission back then. And this would not have helped those Tu-95s at all. Carey Sublette |
"Carey Sublette" wrote:
:In Stalin's day of course he would have grown radioactive wheat and fed it :to the population. Note that this is what they are doing right now with produce from the Chernobyl area. :It would have saved them from starvation and immediate :death, but given them a lifespan much reduced from normal. People grossly overestimate the effects of radiation. Not so much reduced at all. A few years lower on average, at most. -- "Rule Number One for Slayers - Don't die." -- Buffy, the Vampire Slayer |
On Wed, 25 Feb 2004 14:23:54 GMT, Fred J. McCall
wrote: "Carey Sublette" wrote: :In Stalin's day of course he would have grown radioactive wheat and fed it :to the population. Note that this is what they are doing right now with produce from the Chernobyl area. :It would have saved them from starvation and immediate :death, but given them a lifespan much reduced from normal. People grossly overestimate the effects of radiation. Not so much reduced at all. A few years lower on average, at most. If you think of infant mortality (before 2) in the 30% range as normal life span, If you think of a fifteen year decline in life expectancy as a few years, If you think of . . . . Oh what's the point. Peter Skelton |
![]() "Fred J. McCall" wrote in message ... "Carey Sublette" wrote: :In Stalin's day of course he would have grown radioactive wheat and fed it :to the population. Note that this is what they are doing right now with produce from the Chernobyl area. :It would have saved them from starvation and immediate :death, but given them a lifespan much reduced from normal. People grossly overestimate the effects of radiation. Not so much reduced at all. A few years lower on average, at most. I believe you underestimate how radioactive the wheat would have been in fields downwind from a few hundred 400 kt ground bursts. This would be 1000-10,000 times more contaminated than any from Chernobyl. Of course, by mixing this with wheat grown elsewhere the individual exposure could be considerably reduced b distributing over a large population (Russia and Ukraine are doing this with Chernobyl wheat also). |
"Carey Sublette" writes:
The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to the strategic balance was that it was undeliverable against the U.S. The weight of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum payload, and two and a half times its normal weapon load. Range of the Tu-95 was already marginal for attacking the U.S. even with a normal bomb load. Even worse, since the bomb's dimensions - 2 meters wide and 8 meters long - were larger than the bomb bay could accommodate part of the fuselage had to be cut away, and the bomb bay doors removed. The bomb was partially recessed in the plane, but not enclosed, with over half of it protruding in flight. A deployed version of a Tsar Bomba carrier would of course had a bulging bomb bay enclosure added, but this would have further reduced range from the drag. Wouldn't a deployed Tsar Bomba carrier have been a militarized Proton, aka UR-500 aka 8K82? The space launch version uses only storable propellants, can put twenty tons into low orbit with the smallest fairing easily holding a 2 x 8 meter payload, and my references on the space launch side claim that it was developed with the ICBM role and the Tsar Bomba payload in mind from the start (1961). Which was a stupid idea from the start, and so never implemented, but rather less stupid than trying to send an overladen Bear across the arctic. -- *John Schilling * "Anything worth doing, * *Member:AIAA,NRA,ACLU,SAS,LP * is worth doing for money" * *Chief Scientist & General Partner * -13th Rule of Acquisition * *White Elephant Research, LLC * "There is no substitute * * for success" * *661-951-9107 or 661-275-6795 * -58th Rule of Acquisition * |
![]() "John Schilling" wrote in message ... "Carey Sublette" writes: The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to the strategic balance was that it was undeliverable against the U.S. The weight of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum payload, and two and a half times its normal weapon load. Range of the Tu-95 was already marginal for attacking the U.S. even with a normal bomb load. Even worse, since the bomb's dimensions - 2 meters wide and 8 meters long - were larger than the bomb bay could accommodate part of the fuselage had to be cut away, and the bomb bay doors removed. The bomb was partially recessed in the plane, but not enclosed, with over half of it protruding in flight. A deployed version of a Tsar Bomba carrier would of course had a bulging bomb bay enclosure added, but this would have further reduced range from the drag. Wouldn't a deployed Tsar Bomba carrier have been a militarized Proton, aka UR-500 aka 8K82? The space launch version uses only storable propellants, can put twenty tons into low orbit with the smallest fairing easily holding a 2 x 8 meter payload, and my references on the space launch side claim that it was developed with the ICBM role and the Tsar Bomba payload in mind from the start (1961). Which was a stupid idea from the start, and so never implemented, but rather less stupid than trying to send an overladen Bear across the arctic. The only references I recall seeing for models that were actually made were bomb versions. They could have been used against NATO (but this has nothing to do with MAD). It seems likely that they investigated the Proton idea since it is the only way to get it to America. Do you know of any attempts to develop an RV for this? Can you give me any specific citations? |
![]() "Carey Sublette" wrote in message ink.net... "WaltBJ" wrote in message om... Comments: 1) It is true that there is no theoretical limit to the size of a TNW. The practical limit is when the bomb vents to space rather than expanding across the surface of the earth. Big bombs are impractical since they blow the hell out of the hypocenter (spot directly under the bomb) but the radius of destruction increases as the cube root of the bomb's yield. One could take the same amount of critical material and make numerous smaller bombs and achieve a much greater area of destruction by carefully distributing them over the target zone. The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to the strategic balance was that it was undeliverable against the U.S. The weight of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum payload, and two and a half times its normal weapon load. Range of the Tu-95 was already marginal for attacking the U.S. even with a normal bomb load. Even worse, since the bomb's dimensions - 2 meters wide and 8 meters long - were larger than the bomb bay could accommodate part of the fuselage had to be cut away, and the bomb bay doors removed. The bomb was partially recessed in the plane, but not enclosed, with over half of it protruding in flight. A deployed version of a Tsar Bomba carrier would of course had a bulging bomb bay enclosure added, but this would have further reduced range from the drag. 2) I should think doctrine on the possible use of nuclear weapons took a serious hit when a real sober look was taken of the two nuclear accidents the USSR experienced - Chelyabinsk and Chernobyl. The USSR never ever achieved the capability to feed all its people from its own resources and what fallout from numerous nuclear weapons would do to the arable lands of the Ukraine really doesn't bear thinking about. The U.S. similarly vulnerable to this effect from the eastward fallout plumes of strikes on the Montana and Wyoming missile fields. What the heck! Back in the '50s you could buy tickets and go sit in abandoned uranium mines in Montana and elsewhere. It was supposed to help cure 'What ails you.' You could also put your feet in a special box in the shoe store and watch your toes wiggle. ...let you know how the new shoes fit. Wish I had one now to check out a broken little toe in my rt. foot. No pain and no handicap but not worth the doctors big fee. In Stalin's day of course he would have grown radioactive wheat and fed it to the population. It would have saved them from starvation and immediate death, but given them a lifespan much reduced from normal. In ten years or so, we may say the same about the Atkins diet. ![]() 3) FWIW I spent those Cold War years in Air Defense Command as an 86D, 102 and 104 pilot on active air defense alert, usually every third day, from 1954 through 1967, when I went to TAC and the F4. One got a real serious attitude about the Air Defense mission back then. And this would not have helped those Tu-95s at all. Carey Sublette |
![]() "Jim Knoyle" wrote in message news ![]() "Carey Sublette" wrote in message ink.net... "WaltBJ" wrote in message om... Comments: 1) It is true that there is no theoretical limit to the size of a TNW. The practical limit is when the bomb vents to space rather than expanding across the surface of the earth. Big bombs are impractical since they blow the hell out of the hypocenter (spot directly under the bomb) but the radius of destruction increases as the cube root of the bomb's yield. One could take the same amount of critical material and make numerous smaller bombs and achieve a much greater area of destruction by carefully distributing them over the target zone. The fundamental reason why 'Ivan', the Tsar Bomba, had no relevance to the strategic balance was that it was undeliverable against the U.S. The weight of this bomb - 27 tonnes - was nearly equal to the Tu-95's maximum payload, and two and a half times its normal weapon load. Range of the Tu-95 was already marginal for attacking the U.S. even with a normal bomb load. Even worse, since the bomb's dimensions - 2 meters wide and 8 meters long - were larger than the bomb bay could accommodate part of the fuselage had to be cut away, and the bomb bay doors removed. The bomb was partially recessed in the plane, but not enclosed, with over half of it protruding in flight. A deployed version of a Tsar Bomba carrier would of course had a bulging bomb bay enclosure added, but this would have further reduced range from the drag. 2) I should think doctrine on the possible use of nuclear weapons took a serious hit when a real sober look was taken of the two nuclear accidents the USSR experienced - Chelyabinsk and Chernobyl. The USSR never ever achieved the capability to feed all its people from its own resources and what fallout from numerous nuclear weapons would do to the arable lands of the Ukraine really doesn't bear thinking about. The U.S. similarly vulnerable to this effect from the eastward fallout plumes of strikes on the Montana and Wyoming missile fields. What the heck! Back in the '50s you could buy tickets and go sit in abandoned uranium mines in Montana and elsewhere. It was supposed to help cure 'What ails you.' snip There still there, but now its the radon doing the curing: http://cnts.wpi.edu/RSH/Docs/Radon/Index_RadSpas.htm http://www.outwestnewspaper.com/radon.html I guess suckers are still being born every minute. Joe Carey Sublette -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
