#21
Ol Shy & Bashful wrote:
On Jun 25, 10:00 pm, E Z Peaces wrote: Yesterday I chatted with a retired man flying a model airplane. He said he'd taken lessons in a plane with conventional gear in the 1950s. On his third lesson, the instructor had him land. It was perfect. After that, every time he landed he would bounce and float above the runway. His instructor didn't know what caused it. A senior instructor went up with him and observed that when he touched down, he didn't continue to hold the stick back. That caused the tail to rise and the plane to lift off. That doesn't make sense to me. I've always understood that with conventional gear, excess speed is the cause of bouncing and floating. With the main wheels forward of the center of mass, your angle of attack will increase when you touch down, and the plane will rise if you still have flying speed. If a pilot touches down too fast, I've understood that he needs to keep the tail up and use the brakes without nosing over. If the instructor had told him he was touching down too fast because he wasn't holding the stick back far enough during descent, that would make sense to me because a higher angle of attack induces more drag. The man said the problem was that he had failed to keep the stick back after touchdown. Does his recollection make sense? Are you kidding? After nearly 60 years the recollections of a 3 hour student have any validity? The VAST majority of botched landings are due to flawed airspeed control and it doesn't matter what kind of airplane. Many instructors fail to recognize that, or, fail to do anything about it, especially when instructing. I see it all the time, harp about it daily,and continue to mentor less experienced pilots on this. In the case of taildraggers specifically, if the airspeed and vertical speed are not controlled, it will nearly guarantee a bounce with predictable control problems. For a three point to be executed properly, the airspeed MUST be near stall as in within Vso+ 5 mph or less. Anything in excess of that must be dissapated during the flare/ roundout or touchdown and will result in an unpredictable touchdown point. Now, are you talking about a full stop landing? Then the touchdown speed should be as low as possible. Are you talking about a gusty cross wind? Then you have a different set of conditons to deal with. Not to be a pushy butthead but I've got at least 6-7000 hours in tailwheel aircraft crop dusting in a broad variety of aircraft including twin engined and a lot of time instructing in them (couple of thousand hrs..?) taking a deep breath and just sitting back now ..... Ol S&B p.s. I realize you were asking and not postulating so please don't feel I was being gruff towards you personally? Thank you very much! I was postulating. From what I knew, a perfect landing with conventional gear means stalling so low that the wheels touch down gently, and you can't rise again unless you're going too fast. I lacked the experience to know if there was any way his recollection of the cause of his problem could be correct. I've never had a flying lesson. About second grade I began reading books about the mechanics of aircraft. Through my teens I often held papers at arm's length, curved for rigidity, to get a feel for the relationship between speed, angle of attack, lift, and drag. I studied pilot manuals for the Thunderbolt and the Mustang and and cockpit photos of other aircraft. I liked to pedal to the airport and watch the mechanic work. In the high-school library I found a 1948 book by an instructor named Lang, I think. It explained concepts learned from experience rather than laymen's theory. Throttle for vertical speed, elevator for airspeed. Ailerons for direction, rudder to center the ball. If you want to know where you're going, watch the way the scenery shifts against the windshield. As a CAP cadet, I was assigned to the simulator room at an Air Force base the summer I was 17. Those simulators had frosted windshields and no video. Other cadets tried and failed with the F-106. I was the only one to try the B-25. I wasn't familiar with bomber cockpits, but the individual instruments and controls were familiar. I toured Boston by radar, returned to the base, set the flaps, guessed a reasonable descent speed, and followed the instruments in, using the elevator for airspeed and the throttle for descent. In view of my awe of flight, it was disappointingly easy. The sergeant in the control booth played with me on my second flight. I had various problems including an engine fire and loss of hydraulics. Books had told me how to respond to such emergencies, and I made another adequate landing. Then a pilot came in to log some training time. The following October a parent in the squadron invited me flying. His invitation was very brief. I hadn't known he had a plane because he'd never spoken to me before. It was a Cessna 310. At the airport, he told the other three to sit in back and me in front, on the left. That was the second time he'd spoken to me. I figured he wanted me in front because I was taller. At 3,000 feet he told me, "Take over." I thought he intended to let me guide it a minute or so, but he didn't speak again, so I spent twenty minutes touring. I would have liked to hedgehop but refrained because I didn't have permission. Eventually he told me to find the airport. I knew the terrain and had a compass, and before long the airport was in sight. When we were almost there he said, "Traffic pattern is to the left." I'd forgotten that. I steered right and began circling left. Then he said, "Runway 1." That would mean a complete circle. I brought him around to a point far enough out that I thought he'd have a reasonable glide path. Instead of taking over, he cut the throttle to a whisper, dropped the gear, and set the flaps. He told me the descent speed. That was the fifth thing he'd said to me since taking off. I think he was the last thing he ever said to me. From a couple of miles out I could see we were overshooting the end of the runway, so I reduced our speed slightly by raising the nose. As we got closer, I saw a gusty crosswind on the sock. The other runway would have been better but he said nothing. He'd know how to handle the crosswind. He'd also know how to flare. I didn't know our rate of descent but figured we'd crash into the runway if he didn't flare or if he flared too soon. We were down around treetop level when I realized there was no longer time for him to take over. How could I flare safely without knowing our stall speed or how the aircraft would respond? In climbing aboard I hadn't noted the height of the window above the wheels. It seemed only realistic to predict that in two more seconds we would be a ball of flame. Still, I wouldn't have missed this opportunity for the world. At least I had tricycle gear, which tolerates landing too fast and crosswinds. As I flared, the sock showed a big gust from the left. Would we be drifting right when we touched down? I knew a responsible pilot would have let the gear absorb the stress, but I was a perfectionist novice. I dipped the left wing while kicking right rudder to stay aligned with the runway, then picked the wing back up. That was to skid into the crosswind. It seemed risky because I didn't know how well the airplane would respond at that speed and with the mass of the tanks on the wingtips. I expected a vertical bump and a lateral lurch. Instead, tire vibration was the only clue that we had contacted the runway. I didn't need brakes. When it was clear that we would need throttle to make it to the parking area, the pilot took over without a word. Beginner's luck: that deadstick landing in a crosswind was my first and last opportunity to fly an airplane. |
E Z Peaces wrote in
: Ol Shy & Bashful wrote: On Jun 25, 10:00 pm, E Z Peaces wrote: Yesterday I chatted with a retired man flying a model airplane. He said he'd taken lessons in a plane with conventional gear in the 1950s. On his third lesson, the instructor had him land. It was perfect. After that, every time he landed he would bounce and float above the runway. His instructor didn't know what caused it. A senior instructor went up with him and observed that when he touched down, he didn't continue to hold the stick back. That caused the tail to rise and the plane to lift off. That doesn't make sense to me. I've always understood that with conventional gear, excess speed is the cause of bouncing and floating. With the main wheels forward of the center of mass, your angle of attack will increase when you touch down, and the plane will rise if you still have flying speed. If a pilot touches down too fast, I've understood that he needs to keep the tail up and use the brakes without nosing over. If the instructor had told him he was touching down too fast because he wasn't holding the stick back far enough during descent, that would make sense to me because a higher angle of attack induces more drag. The man said the problem was that he had failed to keep the stick back after touchdown. Does his recollection make sense? Are you kidding? After nearly 60 years the recollections of a 3 hour student have any validity? The VAST majority of botched landings are due to flawed airspeed control and it doesn't matter what kind of airplane. Many instructors fail to recognize that, or, fail to do anything about it, especially when instructing. I see it all the time, harp about it daily,and continue to mentor less experienced pilots on this. In the case of taildraggers specifically, if the airspeed and vertical speed are not controlled, it will nearly guarantee a bounce with predictable control problems. For a three point to be executed properly, the airspeed MUST be near stall as in within Vso+ 5 mph or less. Anything in excess of that must be dissapated during the flare/ roundout or touchdown and will result in an unpredictable touchdown point. Now, are you talking about a full stop landing? Then the touchdown speed should be as low as possible. Are you talking about a gusty cross wind? Then you have a different set of conditons to deal with. Not to be a pushy butthead but I've got at least 6-7000 hours in tailwheel aircraft crop dusting in a broad variety of aircraft including twin engined and a lot of time instructing in them (couple of thousand hrs..?) taking a deep breath and just sitting back now ..... Ol S&B p.s. I realize you were asking and not postulating so please don't feel I was being gruff towards you personally? Thank you very much! I was postulating. From what I knew, a perfect landing with conventional gear means stalling so low that the wheels touch down gently, and you can't rise again unless you're going too fast. I lacked the experience to know if there was any way his recollection of the cause of his problem could be correct. I've never had a flying lesson. About second grade I began reading books about the mechanics of aircraft. Through my teens I often held papers at arm's length, curved for rigidity, to get a feel for the relationship between speed, angle of attack, lift, and drag. I studied pilot manuals for the Thunderbolt and the Mustang and and cockpit photos of other aircraft. I liked to pedal to the airport and watch the mechanic work. In the high-school library I found a 1948 book by an instructor named Lang, I think. It explained concepts learned from experience rather than laymen's theory. Throttle for vertical speed, elevator for airspeed. Ailerons for direction, rudder to center the ball. If you want to know where you're going, watch the way the scenery shifts against the windshield. As a CAP cadet, I was assigned to the simulator room at an Air Force base the summer I was 17. Those simulators had frosted windshields and no video. Other cadets tried and failed with the F-106. I was the only one to try the B-25. I wasn't familiar with bomber cockpits, but the individual instruments and controls were familiar. I toured Boston by radar, returned to the base, set the flaps, guessed a reasonable descent speed, and followed the instruments in, using the elevator for airspeed and the throttle for descent. In view of my awe of flight, it was disappointingly easy. The sergeant in the control booth played with me on my second flight. I had various problems including an engine fire and loss of hydraulics. Books had told me how to respond to such emergencies, and I made another adequate landing. Then a pilot came in to log some training time. The following October a parent in the squadron invited me flying. His invitation was very brief. I hadn't known he had a plane because he'd never spoken to me before. It was a Cessna 310. At the airport, he told the other three to sit in back and me in front, on the left. That was the second time he'd spoken to me. I figured he wanted me in front because I was taller. At 3,000 feet he told me, "Take over." I thought he intended to let me guide it a minute or so, but he didn't speak again, so I spent twenty minutes touring. I would have liked to hedgehop but refrained because I didn't have permission. Eventually he told me to find the airport. I knew the terrain and had a compass, and before long the airport was in sight. When we were almost there he said, "Traffic pattern is to the left." I'd forgotten that. I steered right and began circling left. Then he said, "Runway 1." That would mean a complete circle. I brought him around to a point far enough out that I thought he'd have a reasonable glide path. Instead of taking over, he cut the throttle to a whisper, dropped the gear, and set the flaps. He told me the descent speed. That was the fifth thing he'd said to me since taking off. I think he was the last thing he ever said to me. From a couple of miles out I could see we were overshooting the end of the runway, so I reduced our speed slightly by raising the nose. As we got closer, I saw a gusty crosswind on the sock. The other runway would have been better but he said nothing. He'd know how to handle the crosswind. He'd also know how to flare. I didn't know our rate of descent but figured we'd crash into the runway if he didn't flare or if he flared too soon. We were down around treetop level when I realized there was no longer time for him to take over. How could I flare safely without knowing our stall speed or how the aircraft would respond? In climbing aboard I hadn't noted the height of the window above the wheels. It seemed only realistic to predict that in two more seconds we would be a ball of flame. Still, I wouldn't have missed this opportunity for the world. At least I had tricycle gear, which tolerates landing too fast and crosswinds. As I flared, the sock showed a big gust from the left. Would we be drifting right when we touched down? I knew a responsible pilot would have let the gear absorb the stress, but I was a perfectionist novice. I dipped the left wing while kicking right rudder to stay aligned with the runway, then picked the wing back up. That was to skid into the crosswind. It seemed risky because I didn't know how well the airplane would respond at that speed and with the mass of the tanks on the wingtips. I expected a vertical bump and a lateral lurch. Instead, tire vibration was the only clue that we had contacted the runway. I didn't need brakes. When it was clear that we would need throttle to make it to the parking area, the pilot took over without a word. Beginner's luck: that deadstick landing in a crosswind was my first and last opportunity to fly an airplane. Sniff. Anyone smell a sock? Bertie |
Bertie the Bunyip wrote:
E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html |
E Z Peaces wrote in
: Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Bertie |
E Z Peaces wrote in : Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Have you stood by the wing tip and rocked the wing like a seesaw? If you can get it to rock higher and higher and it keeps rocking after you let go, then I guess the landing gear doesn't have effective shock absorbers. I remember touchdown bounces from my days with balsa, tissue and dope. None of my models would have bounced even slightly from a stationary drop because all had rigid landing gear. None had a movable elevator. I could climb and dive by changing thrust, which would move the center of lift by slightly changing the speed. If I wanted a plane to fly faster, I would move the center of gravity by weighting the nose so the model would balance at a higher speed. Without elevator control I couldn't make three-point landings. My Curtis Hawk had the biggest bounce, but the airspeed was low enough that it would rise only about five inches before mushing elegantly to the ground. My Corsair would bounce about two inches. My Spitfire landed much faster than the others because I weighted the nose with two flashlight batteries. With that much airspeed, it might have risen disastrously high if it had bounced on touchdown. It didn't bounce at all. The three models were different in the position of the main gear. The wheels of the Hawk were well forward of the center of gravity; apparently the Army plane was designed that way to counter the tendency of a short, high plane to nose over when landing on a rough field at low speed. When the wheels of my model touched down, the center of mass would continue to fall, lowering the tail and increasing the angle of attack. Naturally, it bounced. The problem wasn't as bad with the Corsair because the wheels weren't so far forward. The wheels of the Spitfire were farther back, and the weights brought the center of gravity forward as well as increasing inertia about the horizontal axis. This way, the tail didn't sink fast enough for the plane to lift off after touchdown. With my balsa models, bouncing came from the rapid sinking of the tail after touchdown. If I'd had elevator control, I might have managed three-point landings with the Hawk. I don't see how the model could have bounced in that case. (A neighbor used to fly his father's Stearman under his brother's instruction. He says he sometimes touched down tail first.) |
E Z Peaces wrote in
: Bertie the Bunyip wrote: E Z Peaces wrote in : Bertie the Bunyip wrote: E Z Peaces wrote in : I've read about oleo aircraft struts at least as early as the 1920s. Theyre not dampers, they're oleos and provide no damping. Shock absorbers are something different and have a different function, though tey're misnamed in any case, since its the springs that absorb and the shicks, as they;'re called, prevent the energy stored in the spring from rebounding the wheel off the road. Airplanes don't have shock absorbers. Here's an example: http://www.hangar9aeroworks.com/Aero...oncastrut.html Yeah, I know,. I was flying one a couple of days ago and I've had them apart, too. It does little or nothing to stop a bounce in spite of it's name. I can also stater that categorically since I was training two ab-initio tailwheel pilots in it. Have you stood by the wing tip and rocked the wing like a seesaw? If you can get it to rock higher and higher and it keeps rocking after you let go, then I guess the landing gear doesn't have effective shock absorbers. I remember touchdown bounces from my days with balsa, tissue and dope. None of my models would have bounced even slightly from a stationary drop because all had rigid landing gear. None had a movable elevator. I could climb and dive by changing thrust, which would move the center of lift by slightly changing the speed. If I wanted a plane to fly faster, I would move the center of gravity by weighting the nose so the model would balance at a higher speed. Without elevator control I couldn't make three-point landings. My Curtis Hawk had the biggest bounce, but the airspeed was low enough that it would rise only about five inches before mushing elegantly to the ground. My Corsair would bounce about two inches. My Spitfire landed much faster than the others because I weighted the nose with two flashlight batteries. With that much airspeed, it might have risen disastrously high if it had bounced on touchdown. It didn't bounce at all. The three models were different in the position of the main gear. The wheels of the Hawk were well forward of the center of gravity; apparently the Army plane was designed that way to counter the tendency of a short, high plane to nose over when landing on a rough field at low speed. When the wheels of my model touched down, the center of mass would continue to fall, lowering the tail and increasing the angle of attack. Naturally, it bounced. The problem wasn't as bad with the Corsair because the wheels weren't so far forward. The wheels of the Spitfire were farther back, and the weights brought the center of gravity forward as well as increasing inertia about the horizontal axis. This way, the tail didn't sink fast enough for the plane to lift off after touchdown. With my balsa models, bouncing came from the rapid sinking of the tail after touchdown. If I'd had elevator control, I might have managed three-point landings with the Hawk. I don't see how the model could have bounced in that case. (A neighbor used to fly his father's Stearman under his brother's instruction. He says he sometimes touched down tail first.) Wonderful, you should write a book. Bertie |
Runway | J.F. | Aviation Photos | 14 | September 14th 07 04:24 PM |
Runway ID | Lakeview Bill | Piloting | 55 | October 18th 05 12:53 AM |
Runway needs of F4U and F-4 ???? | vincent p. norris | Naval Aviation | 8 | October 6th 05 07:18 PM |
Bouncing ammeter hand on 76 Warrior | Leo | Owning | 5 | December 5th 04 08:24 PM |
Runway in Use | Sniper@SDU | Simulators | 11 | October 8th 03 10:57 AM |
