Constant speed prop question
Old July 20th 08, 06:58 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Default Constant speed prop question
" wrote in news:5d086d24-406f-
On Jul 20, 10:48 am, Bertie the Bunyip wrote:
"Mike" wrote innews:qNIgk.158$oU.42@trnddc07:
"Mike" wrote in
news:WPHgk.144$DS3.119@trnddc01:
"Terence Wilson" wrote in message
In the course of trying to understand how a constant speed prop
works I came across the following passage in one of the Jeppesen
books:
"If the throttle is advanced without decreasing the pitch of the
prop blades to increase ___ rpm, the manifold pressure increases
as
the prop mechanism attempts to keep ___ rpm constant by
increasing
the blade angle. The combination of high manifold pressure and
low
___ rpm can cause damage due to high internal manifold
pressures."
I found this paragraph to be confusing because it makes several
references to rpm but doesn't clarify whether it is engine or
prop
rpm. The blanks were inserted by me. Can someone help me out?
Thanks in advance.
As others have said, unless you have a gearbox (not many planes
do),
they are one and the same.
You may also want to ditch your Jepp book as the "theory" they
are
describing really doesn't apply to most small piston aircraft.
The
old "don't run oversquare" mentality which has been taught for
years
originated out of military teachings that applied to very
different
pilots doing very different things while flying very different
aircraft.
Actually, they dont, since most military aircraft,even smaller
ones,
were supercharged and they ran well oversquare.. A 985, for
instance,
is around 37 inches max and a typical cruise MP might be in the
order of 25 inches with a cruise rpm of something like 1850,
depending on how fast you want to go and how much you want to
burn.
The geared engines were even less relevant to this argument,
since
almost everything larger than about 1500 c.i.d. was geared. The
indicated RPM was usually engine rpm and max for somthing like an
1830 was around 2400 and max MP for takeoff was about 43 IIRC and
cruise was around 30/2,000.
The practice originates from a perceived need to simplify for
light
aircraft pilots new to variable pitch props.
And that need is even more of a necessity in military trainers
which
have considerably more power and are much more easily red lined.
That's why I always assumed the mentality came primarily from
military
instructors giving instruction in training aircraft. At any rate
myth still persists to this day even with instructors who should
know
better.
Well, outside of the T-34 I can't think of anything that would fit
"square" scenario, and military instructors would not have taken any
sort of soft route with the students in any case. For instance, I
happen
to know any Navy student would have to have memorised a very lengthy
series of checklists at the primary student stage for a T-28, for
instance. That's ALL of the checklists. Ever single one, emergencies
and
all. And having seen them I know they were very, very complicated
indeed.
They also had to be able to touch every single switch, dial, and
lever
in the airplane blindfolded. I can't see them going soft on a little
thing like not having to memorise a given MP RPM combo. Now, during
aerobatics, it would make sense to have a nominal max MP a bit shy of
normal max, as you say, but for operations outside of that, they
certainly would not have done that.
No, the only place I've ever seen he practice touted s by FBOs
renting
airplanes or using them for comercial instruction.
Bertie
The whole idea of don't run oversquare is not a military technique
taught, but rather a technique taught to radial pilots back in the
day. These pilots then moved over to our flat engines, and decided
running oversquare would still be a bad idea. I agree with the other
guys-and having been through an Advanced Pilot Seminar, I can
certainly say-you will know much more about your engine after going
through the seminar. There is another seminar coming up later this
year, and I'm thinking of attending it again.
Also those pelican perch articles are fantastic, and if Deakin ever
shows up to a seminar, you get to meet the author.
Nope. I've flown most of those old radials, and as I've just said, the
numbers on them weren't anything even close to square. If you can come
up with one that's even close it'd be the exception rather than the
rule. Anything that was big enough to have a variable pitch prop other
than a ground adjustable swung a prop big enough to run very low RPM or
was geared.
Also, engine management was taught at a whole different level in the
radial engine period.
Bertie
Old July 20th 08, 07:35 PM posted to rec.aviation.piloting
Martin Hotze[_2_]
RST Engineering schrieb:
Those cities would also have contained many more historic buildings if your
elected leaders hadn't invaded Poland, France, Czechoslovakia, and a few
other minor countries.
yes, true. no discussion about that.
but it is also true that "you" bombed (with "fire bombs" [wording?])
areas within cities (mostly old parts of town with no industry but with
worth to conserve buildings) that "you" found out to be endangered due
to fire on purpose, too. So you burned down many parts of many cities on
purpose.
you knew that, too?
#m
Old July 20th 08, 07:43 PM posted to rec.aviation.piloting
Martin Hotze wrote in
if your elected leaders hadn't invaded Poland, France,
Czechoslovakia, and a few other minor countries.
with worth to conserve buildings) that "you" found out to be
endangered due to fire on purpose, too. So you burned down many parts
of many cities on purpose.
you knew that, too?
#m
He's Bomber Harris? I thougth he was dead.
Bertie
Old July 20th 08, 09:35 PM posted to rec.aviation.piloting
purpose.
Start a world war, overrun most of Europe, bomb the **** out of England,
and get bombed in return.
The only thing the Allies have to be sorry for is we didn't get a
working A bomb prior to June, 1944.
Jim Pennino
Remove .spam.sux to reply.
Old July 21st 08, 12:20 AM posted to rec.aviation.piloting
Benjamin Dover
Mxsmanic wrote in
Thomas Borchert writes:
It seems your wink-o-meter might need adjustment.
The wink-o-meter tends to cloud up when it winks at 100 million dead.
It wouldn't be clouding up if you were one of those 100 million.
Old July 21st 08, 04:26 AM posted to rec.aviation.piloting
yod-yog+ais
On 7/20/2008 10:11 AM Mxsmanic ignored two million years of human
evolution to write:
The dip****-o-meter is pegged every time you post.
Old July 21st 08, 04:11 PM posted to rec.aviation.piloting
Darkwing
"Mxsmanic" wrote in message
Says the idiot.
Old July 21st 08, 04:41 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
Thomas Borchert wrote:
Actually, it couldn't have been all of the military. Many major cities in my
home country of Germany would contain many more historic buildings today, if
those B-17s hadn't run oversquare and lean of peak. The B-17s would never
have reached them.
It's been my experience that historic buildings are vastly overrated. They
never have enough bathrooms, the stairs are too steep and electrical service is
inadequate.
Now you have nice new buildings, with the compliments of the Eighth Air Force.
Quit yer bitching.
mschnerdatcarolina.rr.com
  #29
Old July 21st 08, 09:18 PM posted to rec.aviation.piloting
Morgans[_2_]
Force. Quit yer bitching.
Actually, for once (this time) I didn't take Thomas's remarks it as
bitching.
He was observing that the Eighth Air Force did indeed have a good grip on
running over square.
Read it again, and agree, or not.
  #30
Old July 22nd 08, 12:58 AM posted to rec.aviation.piloting
Tman
Jay Maynard wrote:
...and in geared engines, or engines with some other propeller speed
reduction unit (such as the Rotax 912), they're directly proportional. Thus,
it doesn't matter whether it's engine or prop rpm.
Yes, unless there is a torque converter between the crank and the prop.
PA28: Difference in constant speed prop vs fixed pitch Nathan Young Owning 25 October 10th 04 04:41 AM
Constant speed prop oil leak DP Piloting 23 April 21st 04 10:15 PM
Practicing SFLs with a constant speed prop - how? Ed Piloting 22 April 16th 04 02:42 AM
Constant Speed Prop vs Variable Engine Timing Jay Home Built 44 March 3rd 04 10:08 PM
Constant speed or constant attitude? Jim Soaring 37 September 3rd 03 12:41 PM
