Wire sizes
Old July 31st 08, 10:58 PM posted to rec.aviation.soaring
Andy[_1_]
Default Wire sizes
On Jul 31, 1:31*pm, Andy wrote:
On Jul 31, 8:35*am, Darryl Ramm wrote:
Spade ... blade....
I thought they were the same thing so obviously I don't speak American
very well yet. *
This UK terminal catalog uses the terms blade and spade for the same
catalog items, so it's not just me.
http://www.toby.co.uk/content/catalo...sp?category=26
Andy
Old August 1st 08, 09:37 AM posted to rec.aviation.soaring
ContestID67
Default Wire sizes
Ring Lug - a closed loop shaped like an O
Spade Lug (blade) - an open end shaped like a U
Hook Lug - a open end shaped like a ?
The basic undying question is why are ring lugs to be used instead of
spade? It has to do with trying to prevent a connection failing due
to vibration. If the terminal screw works loose, a spade lug would
fall off while a ring lug will hang on (and the loose screw will
hopefully be caught during inspection). Now this is more of an issue
in powered airplanes due to the constant vibration from the engine.
Still gliders have to live by these rules too.
Faston - Shaped like a, ummm, hmmmm, well, that's kind of hard to
explain. From the end they look like a C that was flattened by a
hammer so that the ends are curved inward. They make a very tight
connection to the mating part which is a narrow flat piece of metal
(like on typical gel-cells). It is a male-female connection.
My $0.02.
- John DeRosa
Caption This !! (2 sizes) Square Wheels[_2_] Aviation Photos 18 December 18th 06 01:01 AM
instrument sizes Bill Chernoff Home Built 9 September 21st 06 09:28 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 09:51 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 06:11 PM
Cockpit sizes of standard Jantar goneill Soaring 2 December 28th 03 12:29 PM
