Fuselage Vents
Old July 30th 08, 05:46 PM posted to rec.aviation.soaring
Ken Kochanski (KK)
Default Fuselage Vents
The performance claims look extremely good ... is this plausible ?
http://www.dg-flugzeugbau.de/mandl-absaugung-e.html
KK
Old July 30th 08, 06:14 PM posted to rec.aviation.soaring
PMSC Member
I love the timing. Right out of the XX playbook.
On Jul 30, 11:46 am, "Ken Kochanski (KK)"
KK
Old July 30th 08, 06:16 PM posted to rec.aviation.soaring
Uncle Fuzzy
On Jul 30, 8:46*am, "Ken Kochanski (KK)"
KK
Thanks for posting this!
Sounds plausible to me, but what do I know? I DO know that at 70
knots, opening the vent in my Speed Astir (AKA the 'Grob Solar Sauna)
will drive the altimeter down 100' instantly, so there is positive
pressure to deal with. I also know that I have a perfect spot to make
an 'experimental' vent that is completely removable. Increasing
airflow in the cabin is more important to me than the performance
gain.
Old July 31st 08, 05:17 AM posted to rec.aviation.soaring
Dear Uncle
If your altimeter changes indications when you open the vent, that
indicates your altimeter is not connected to STATIC. Best to check
you plumbing.
Guy Acheson, "DDS"
On Jul 30, 9:16�am, Uncle Fuzzy wrote:
Sounds plausible to me, but what do I know? �I DO know that at 70
pressure
Old July 31st 08, 06:48 AM posted to rec.aviation.soaring
sisu1a
On Jul 30, 8:17 pm, wrote:
Dear Uncle
you plumbing.
Or (dramatic pause) it means that someone (previous owner?) has chosen
the cockpit as the static source. If this is the case, I think Mr
Fuzzy just learned why it's an excellent BACKUP source and a poor
primary one (hint-use a pneumatic toggle to switch to cockpit static
only when your REAL static system is waterlogged/frozen) Use your
ships actual static system. It works better than the cockpit.
My 2 Pesos,
-Paul
Old July 31st 08, 04:58 PM posted to rec.aviation.soaring
Uncle Fuzzy
Dear Uncle
indicates your altimeter is not connected to STATIC. *Best to check
you plumbing.
My 2 Pesos,
-Paul
OR,
Uncle Fuzzy decided that he'd like his ALTIMETER to read the same
pressure as his FLIGHT RECORDER when the pneumatic switch is in the
CABIN position on his line to the Altimeter.
Old July 31st 08, 06:40 PM posted to rec.aviation.soaring
Jim White[_3_]
Now there is a thought.... Open the air vent if you are close to airspace
to make the logger think you are lower, and fit an extraction vent if you
want that height record.
jim
Old July 30th 08, 08:43 PM posted to rec.aviation.soaring
KK
Ventus mods have used a funnel behind the wheel well for years,
typically a 2" piece or pipe would form the exit.
Improvement here is the shape of the exit.
Regards
Al
Old July 30th 08, 11:40 PM posted to rec.aviation.soaring
Go Soaring
Yawn............See the below, 1972!! Wil Schuemann H301 Libelle
http://www.betsybyars.com/guy/soarin.../72-modif.html
At 18:43 30 July 2008, wrote:
On Jul 30, 8:46=A0am, "Ken Kochanski (KK)"
KK
Regards
Al
Old August 1st 08, 08:58 PM posted to rec.aviation.soaring
Soaring
On Jul 30, 12:43*pm, "
KK
Ventusmods have used a funnel behind the wheel well for years,
Regards
Al
Can someone e-mail more info on Ventus mods?
Andy
Cockpit air vents bartbrn Home Built 6 April 26th 08 03:24 AM
Trailer Vents... Gary Emerson Soaring 1 February 25th 08 08:38 PM
Solar Vents JJ Sinclair Soaring 2 February 14th 08 02:36 PM
Cessna air vents Matt Owning 30 January 14th 06 01:53 AM
C172 Air vents Matt Young Owning 8 July 2nd 04 01:53 PM
