#21
Hi Paul, i will find you the tests showing 2 Claws failed in the centre
bracket with just 150 pounds shock loads (it was done in a South African magazine). They may be YOUR favourite but they are brittle and having sold them before we have a few reports on low wing aircraft of holes in the wings from the hammer (Obviously NOT the claws fault). Glad there are choices out there for the public that way you can buy what suits your needs, remembering these are NOT a replacement for a cable or underground concrete block. Cheers sisu1a wrote: On Sep 23, 4:16 am, user wrote: Tryhttp://www.screwits.com Small, light and they work ! The site has a comparison of all the tie downs available Hmmm, that's some comparison! Glad they definitively settled that one. According to their ultra scientific study (based on the risk of accidentally striking your wing while installing...) they have positively determined once and for all that their own system THEY sell is indeed actually "The Ultimate Aircraft Tiedown System". Good thing their team of crack scientists conducted such a thorough test of the parameters that really matter to pilots... Seriously, I wish I could find the photos Sporty's took of a large backhoe fitted with a tensiometer actually testing all the major available tiedowns to failure under the same conditions. The screw type and hockey puck thingies that (cheap) pilots are trying desperately to convince themselves can outperform the Claw (some of which are just as expensive), failed miserably LONG before the Claw anchors pulled out. Again, the Claw is substitute for permanent anchors, however there simply is not a portable solution that outperforms them for most situations (and by portable I mean no sledge hammers, no pipe wrenches, no parts longer than a foot, 10lbs, ie something you would actually carry in your ship) BTW, although they have spikes, that is the only system that does not rely on friction in the Z axis-hence the 10" long spikes. The forces are directed inwards at ~45deg in an equidistant triangle that is gripping the earth between the spikes. The harder you pull the harder they grab (until failure of course). The only situation they suck in is in loose gravel/ sand, and that's where the dittybag deal really shines. Actually I like when guys buy those screw types, as it is actually quite entertaining to watch people STRUGGLE to get them in (unfortunately they plane does not have to struggle much to pull them back out). The Claw gos in incredibly easy and hold far more then the competition. It's your plane though, so buy whatever you want. If your plane is parked next to mine though, don't be offended if you awake and see a Claw anchor or 2 added to your setup that almost let go in the middle of the night (happened several times already...). It's also nice not to have tripping hazards extending beyond the wing, not to mention having nothing to impale your wing/tire protruding above the ground, but to each their own. I think that one should carry both the Claw AND the dittybag system that Bill pioneered for a truly comprehensive and portable X/C set. That way your bases are covered whether you land on very loose or very hard ground, and one could use BOTH if really in trouble. (The Claw goes in fast enough to secure it in the wind, which would buy the time needed to fill the dittys) BTW, getting back to the OP, I for one am not a big fan of cam straps. The camstraps I have used in the past for securing loads on the road required re-cinching all too often (all brands I tried...). I stick w/ the ratchet types if using straps, but for going light/portable I have a little bit of 8mm spectra that fits the bill quite nicely. I trust my knots FAR more than cam buckles, but maybe I am just biased on that one. I don't like S-hooks either though, so I cut those off my straps and replace them w/stainless screw type D-shackles. -Paul |
Hi,
I think that you are assuming incorrectly that the many extremely positive reviews of the CLAW in this thread by "Paul" were written by me. I am not the Paul that wrote those notes. I wrote the note that started this tread and one or 2 others. I always include my last name in my posts. Paul __________, Please include your last name or an alias in your posts so people don't confuse your posts with mine. I don't disagree with your posts, but you have done some passionate posts and I think people are thinking it is me - pushing hard to sell products - which is not my style. I do sell them and I do like them. Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "user" wrote in message ... Hi Paul, i will find you the tests showing 2 Claws failed in the centre bracket with just 150 pounds shock loads (it was done in a South African magazine). They may be YOUR favourite but they are brittle and having sold them before we have a few reports on low wing aircraft of holes in the wings from the hammer (Obviously NOT the claws fault). Glad there are choices out there for the public that way you can buy what suits your needs, remembering these are NOT a replacement for a cable or underground concrete block. Cheers sisu1a wrote: On Sep 23, 4:16 am, user wrote: Tryhttp://www.screwits.com Small, light and they work ! The site has a comparison of all the tie downs available Hmmm, that's some comparison! Glad they definitively settled that one. According to their ultra scientific study (based on the risk of accidentally striking your wing while installing...) they have positively determined once and for all that their own system THEY sell is indeed actually "The Ultimate Aircraft Tiedown System". Good thing their team of crack scientists conducted such a thorough test of the parameters that really matter to pilots... Seriously, I wish I could find the photos Sporty's took of a large backhoe fitted with a tensiometer actually testing all the major available tiedowns to failure under the same conditions. The screw type and hockey puck thingies that (cheap) pilots are trying desperately to convince themselves can outperform the Claw (some of which are just as expensive), failed miserably LONG before the Claw anchors pulled out. Again, the Claw is substitute for permanent anchors, however there simply is not a portable solution that outperforms them for most situations (and by portable I mean no sledge hammers, no pipe wrenches, no parts longer than a foot, 10lbs, ie something you would actually carry in your ship) BTW, although they have spikes, that is the only system that does not rely on friction in the Z axis-hence the 10" long spikes. The forces are directed inwards at ~45deg in an equidistant triangle that is gripping the earth between the spikes. The harder you pull the harder they grab (until failure of course). The only situation they suck in is in loose gravel/ sand, and that's where the dittybag deal really shines. Actually I like when guys buy those screw types, as it is actually quite entertaining to watch people STRUGGLE to get them in (unfortunately they plane does not have to struggle much to pull them back out). The Claw gos in incredibly easy and hold far more then the competition. It's your plane though, so buy whatever you want. If your plane is parked next to mine though, don't be offended if you awake and see a Claw anchor or 2 added to your setup that almost let go in the middle of the night (happened several times already...). It's also nice not to have tripping hazards extending beyond the wing, not to mention having nothing to impale your wing/tire protruding above the ground, but to each their own. I think that one should carry both the Claw AND the dittybag system that Bill pioneered for a truly comprehensive and portable X/C set. That way your bases are covered whether you land on very loose or very hard ground, and one could use BOTH if really in trouble. (The Claw goes in fast enough to secure it in the wind, which would buy the time needed to fill the dittys) BTW, getting back to the OP, I for one am not a big fan of cam straps. The camstraps I have used in the past for securing loads on the road required re-cinching all too often (all brands I tried...). I stick w/ the ratchet types if using straps, but for going light/portable I have a little bit of 8mm spectra that fits the bill quite nicely. I trust my knots FAR more than cam buckles, but maybe I am just biased on that one. I don't like S-hooks either though, so I cut those off my straps and replace them w/stainless screw type D-shackles. -Paul |
Hi,
I like the CLAW and recommend them and sell them. But I agree (and state on my web site) that they are a temporary solution. I agree that an underground concrete block is a much better long term solution. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "user" wrote in message ... Hi Paul, i will find you the tests showing 2 Claws failed in the centre bracket with just 150 pounds shock loads (it was done in a South African magazine). They may be YOUR favourite but they are brittle and having sold them before we have a few reports on low wing aircraft of holes in the wings from the hammer (Obviously NOT the claws fault). Glad there are choices out there for the public that way you can buy what suits your needs, remembering these are NOT a replacement for a cable or underground concrete block. Cheers sisu1a wrote: On Sep 23, 4:16 am, user wrote: Tryhttp://www.screwits.com Small, light and they work ! The site has a comparison of all the tie downs available Hmmm, that's some comparison! Glad they definitively settled that one. According to their ultra scientific study (based on the risk of accidentally striking your wing while installing...) they have positively determined once and for all that their own system THEY sell is indeed actually "The Ultimate Aircraft Tiedown System". Good thing their team of crack scientists conducted such a thorough test of the parameters that really matter to pilots... Seriously, I wish I could find the photos Sporty's took of a large backhoe fitted with a tensiometer actually testing all the major available tiedowns to failure under the same conditions. The screw type and hockey puck thingies that (cheap) pilots are trying desperately to convince themselves can outperform the Claw (some of which are just as expensive), failed miserably LONG before the Claw anchors pulled out. Again, the Claw is substitute for permanent anchors, however there simply is not a portable solution that outperforms them for most situations (and by portable I mean no sledge hammers, no pipe wrenches, no parts longer than a foot, 10lbs, ie something you would actually carry in your ship) BTW, although they have spikes, that is the only system that does not rely on friction in the Z axis-hence the 10" long spikes. The forces are directed inwards at ~45deg in an equidistant triangle that is gripping the earth between the spikes. The harder you pull the harder they grab (until failure of course). The only situation they suck in is in loose gravel/ sand, and that's where the dittybag deal really shines. Actually I like when guys buy those screw types, as it is actually quite entertaining to watch people STRUGGLE to get them in (unfortunately they plane does not have to struggle much to pull them back out). The Claw gos in incredibly easy and hold far more then the competition. It's your plane though, so buy whatever you want. If your plane is parked next to mine though, don't be offended if you awake and see a Claw anchor or 2 added to your setup that almost let go in the middle of the night (happened several times already...). It's also nice not to have tripping hazards extending beyond the wing, not to mention having nothing to impale your wing/tire protruding above the ground, but to each their own. I think that one should carry both the Claw AND the dittybag system that Bill pioneered for a truly comprehensive and portable X/C set. That way your bases are covered whether you land on very loose or very hard ground, and one could use BOTH if really in trouble. (The Claw goes in fast enough to secure it in the wind, which would buy the time needed to fill the dittys) BTW, getting back to the OP, I for one am not a big fan of cam straps. The camstraps I have used in the past for securing loads on the road required re-cinching all too often (all brands I tried...). I stick w/ the ratchet types if using straps, but for going light/portable I have a little bit of 8mm spectra that fits the bill quite nicely. I trust my knots FAR more than cam buckles, but maybe I am just biased on that one. I don't like S-hooks either though, so I cut those off my straps and replace them w/stainless screw type D-shackles. -Paul |
![]() I think that you are assuming incorrectly that the many extremely positive reviews of the CLAW in this thread by "Paul" were written by me. *I am not the Paul that wrote those notes. *I wrote the note that started this tread and one or 2 others. *I always include my last name in my posts. Paul __________, Please include your last name or an alias in your posts so people don't confuse your posts with mine. *I don't disagree with your posts, but you have done some passionate posts and I think people are thinking it is me - pushing hard to sell products - which is not my style.. I do sell them and I do like them. Paul Remde Paul (Remde), My postings all say sisu1a at the top as well as in the Author column on the newsgroup page.... Early in this post (which I was going to stay out of...) I was mentioned by first and last name (misspelled Hansen) in reference to my Sisu getting flipped in a storm while tied out with the Claw, so I felt the need to add my personal feelings on the subject so my misuse of such a fine product was not used as ammo to dismiss it since there were relevant details to the scenario that I felt worth mentioning. I apologize for any issues this has caused for you with my ambiguous signature, although I'm not sure why you are convinced they have their Paul's confused... -Paul HANSON PS. I think we should coordinate an independent test on all the commonly available portable tiedowns out there using Bob Kuykendal's "Breakotron" in different ground types so we may all draw our own conclusions...I'll put up one or more of my Claws for the experiment, does anyone else have any tiedowns they are willing to destroy to make a point we can all benefit from? Bob, ya' listening? |
![]() I think that you are assuming incorrectly that the many extremely positive reviews of the CLAW in this thread by "Paul" were written by me. *I am not the Paul that wrote those notes. *I wrote the note that started this tread and one or 2 others. *I always include my last name in my posts. Paul __________, Please include your last name or an alias in your posts so people don't confuse your posts with mine. *I don't disagree with your posts, but you have done some passionate posts and I think people are thinking it is me - pushing hard to sell products - which is not my style.. I do sell them and I do like them. Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com Paul (Remde), At the top of all my posts it says sisu1a, as well as in the Author column on the newsgroup site...Early in this thread (which I was going to stay out of...) I was called out by first and last name (misspelled) in reference to my Sisu getting flipped in a storm while tied down with the Claw so I felt the need to add my personal testimony so that my misuse of such a fine product was not used as ammo to dismiss it since the extenuating circumstances were/are quite relevant. I apologize for my ambiguous signature causing any confusion, although I'm not sure why your so convinced they have their Pauls' confused. -Paul HANSON PS. I think we should coordinate an independent test of all the commonly available tiedowns in different ground types using Bob Kuykendal's "Break-O-Tron" so that everyone may draw their own conclusions based on real data. I'm willing to put up a Claw or two up for the experiment, does anyone else have any tiedowns they are willing to destroy to prove a point that we may all benefit from? Bob, ya listening? |
I purchased 3 sets of "Screwits". They are made in Australia, and shipping
to the USA doubles the cost for one set. My thinking, by buying 3, was to save on shipping and re-distribute them to friends locally. The Screwits website erroneously claims they have an anodized finish. Since all of the screw-in type anchors I've ever seen are made of steel (including the "Screwits" as it turns out) I was thinking the Screwits must be made of some super tough aluminum alloy - - as anodizing is an aluminum (and alloys) surface treatment, not done to steel. The "Screwits" look to be cadmium plated steel. The screw portion of the anchor is relatively small and the shaft is also thin compared to other screw anchors I have. This saves weight, but detracts from holding power. The weight savings and smaller size, would make it possible to pack the Screwits into many gliders. Bottom line, there's no way I would trust Screwits to hold my glider down in a "blow". There are many other screw-in anchors available in this country that less expensive and more robust (though at a slight weight penalty). On the flip side, the Screwits are nicely made, they come in kit w/ handle to turn in or remove the anchors, and they will do the job in some soil types. If they are in your glider, they'll work a lot better than heavier ones you left in the trailer. bumper "user" wrote in message ... Try http://www.screwits.com Small, light and they work ! The site has a comparison of all the tie downs available wrote: A very cheap solution that I use is to buy 2 18" long 2x2 steel angle iron. Cut 45 degree edges at one end to make a point (the metal supplier that you buy the angle from can do this). Drill a 0.5" at the other end. Drive the angles into the ground at a 45 degree angle with a sledge hammer at a place where the tie down rope will be at right angles to the stake. Total cost: $15-20, not including the sledge. You need as much surface area as possible for maximum hold strength. Consequently I don't favor any kind of tie-down that looks like a tent stake or an over-sized nail. It is important that the tie-down rope be at right angles, or as close to it as possible, to maximize this surface area. I also got a couple of cheap, small plastic buckets to put over the tie-down so I wouldn't stub my toes or drop a wing on them. If you want a permanent high-strength tie-down get 2 or 3 used tires, some cable or chain, and a shovel. Attach the chain to each tire and bury the tire as deep as you can. The tires are free, the chain about $1 a foot, and you probably already have a shovel. Tom Seim |
Com 11A pin out needed | [email protected] | Owning | 1 | June 12th 08 09:23 PM |
Do your straps up tightly for winch launches! | Derek Copeland | Soaring | 22 | October 23rd 06 09:34 AM |
Forming finger straps. | Mike | Restoration | 7 | April 16th 06 03:53 AM |
Discus Battery Straps | Brian Iten | Soaring | 6 | April 8th 04 12:20 AM |
HGU 55 needed | Chris Jamesson | Military Aviation | 0 | March 2nd 04 04:59 AM |
